Old Feb 24, 2013, 11:57 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Cable is enough, the interface was intended at the origins for the V1 receivers upgrade, and is used now in Futaba receivers upgrade process only.
But... you still need to adapt the pinout of black connector to the receiver, as explained here: http://www.rcgroups.com/forums/showt...9#post17169119
renatoa is offline Find More Posts by renatoa
Old Feb 24, 2013, 01:16 PM
IceWind is offline
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
Originally Posted by renatoa View Post
Try check alarms, and, even good, reflash them again to zero.
Happened to a friend who I am sure wouldn't be able to even enter in menu screen found an alarm set after the tx battery went very low voltage.
Thanks that was it. Had to reflash it and later re-bind will all my RX's.
Not sure how that thing got into that state.
If Frsky is listening, it would be good to have a way to reset the module without no extra tool required!
IceWind is offline Find More Posts by IceWind
Old Feb 24, 2013, 01:40 PM
TheNiceGuy is offline
Find More Posts by TheNiceGuy
Expat
Japan
Joined Apr 2010
Im about to order:
http://www.alofthobbies.com/futaba-t...ry-module.html
http://www.alofthobbies.com/frsky-d8r-xp.html
http://www.alofthobbies.com/40cm-receiver-antenna.html
This is all I need for 1 km solid on my kk2 tricopter? Is there a way to extend the TX antennae so its not behind the Futaba TX back?
I dont need the CCPM, but its the same price so might as well for upgradeability as its the same quality as the other RX?
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old Feb 24, 2013, 02:17 PM
IceWind is offline
IceWind's Avatar
Joined Feb 2005
Originally Posted by TheNiceGuy View Post
Im about to order:
Depends on your video gear. For me the 900Mhz totally kills the FrSky RX.
The best I could do was 600mts, today for example the alarm started kicking in at 300mts.
(haven't tried the balun antennas like that one yet, have a couple on it's way now. A friend with the same video gear as I do tried and got better results with them)
Old Feb 24, 2013, 10:59 PM
WendoNZ is offline
Find More Posts by WendoNZ
New Zealand, Canterbury, Christchurch
Joined Dec 2012
What power is the 900Mhz gear you're talking about? I'm assuming it's video rather than something like the 3DR Radio's used on APM's
WendoNZ is offline Find More Posts by WendoNZ
Old Feb 25, 2013, 02:30 AM
renatoa is offline
Joined Sep 2007
Flown this weekend at 650 meters distance, testing an ArduPlane setup, telemetry using 868MHz, but in low power mode 10mW.
RC not influenced at all by telemetry, both quite close on an EZ*.
Old Feb 25, 2013, 05:08 AM
Tony Hallo is offline
Find More Posts by Tony Hallo
Springdale, PA
Joined Mar 2008
Originally Posted by Rotozuk View Post
We will have some to show at Toledo, but may not be selling there. The logistics and expense of getting products there will determine how we proceed.
We think we will have them in April, and price is rumored to be around $150.
-Wayne
Don't see your name on the exhibitors list, where your booth ID?
Tony Hallo is offline Find More Posts by Tony Hallo
Old Feb 25, 2013, 05:29 AM
IceWind is offline
IceWind's Avatar
Joined Feb 2005
I'm using 500mW. I mentioned it as you said you're going to use it with a KK, so a multicopter, where the space is not much and electronics are too close together.
(speaking of balun antennas and they just arrived, hope to try them out soon. )
Old Feb 25, 2013, 02:15 PM
Rotozuk is offline
Find More Posts by Rotozuk
Rotozuk's Avatar
United States, CA, Novato
Joined Sep 2003
Look under FrSky. I think we are in the 200s unless it has changed.
-Wayne
Rotozuk is offline Find More Posts by Rotozuk
Site Sponsor
Old Feb 26, 2013, 05:01 AM
Springdale, PA
Joined Mar 2008
Don't see it there either, I do hope to see you there however. If I understand there will not be any for sale? Will you have other FrSky products available?
Old Feb 26, 2013, 06:23 AM
Jim Taylor is offline
Find More Posts by Jim Taylor
Wexford, PA
Joined Mar 2001
Where are you getting a 2013 Exhibitors List for Toledo? The only list I can find on line says "2012 Exhibitors List" at the top so I'm assuming it is last years.
Jim Taylor is offline Find More Posts by Jim Taylor
Old Feb 26, 2013, 08:23 AM
u2builder is offline
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Could someone explain the advantages of the new Frsky radio compared to putting the brand new modules that are coming out soon into a radio such as the Futaba 9C which I currently have? Also, when is the module that is going to be compatable with the new long range RX's expected to be released. I understand the Spectrum version is coming first but wonder when the Futaba version will be available.
I assume that with the plug in module approach it will be necessary to use switches on the module to switch between the new long range one way RX and telemetry RX's. Woul d this also be the case for the new radio,
Will the new radio bind to specific models, a feature not available with the plug in modules.
Is the build quality of the new radio comparable to a radio such as the Futaba 9C? (I like my 9C a lot).
Thanks.
u2builder is offline Find More Posts by u2builder
Old Feb 26, 2013, 08:43 AM
Kilrah is offline
Find More Posts by Kilrah
Happy FPV flyer
Kilrah's Avatar
Switzerland
Joined Sep 2006
The main one is telemetry, on-screen and speech. Second is model match type feature. 3rd is no DIP switches, settings can be stored along with the model settings.
Kilrah is offline Find More Posts by Kilrah
Old Feb 26, 2013, 08:50 AM
KC is offline
KC
Find More Posts by KC
KC
Registered Loiterer.
KC's Avatar
United States, FL, Orlando
Joined Sep 2006
Forth, but not the least, low latency. The new transmitters do not have the latency associated with the modules on the PPM line.
KC is offline Find More Posts by KC
Old Feb 26, 2013, 09:15 AM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Thanks guys, that is a lot of really nice features. I like them all, especially the ability to connect up to the RX without dip switches. Plus I guess I won't have to wait for the Futaba modules to come out. Does anyone know when this radio and the new LR one way RX's are going to hit the street?
One more question: will the new radio bind on a model specific basis even with the current generation of RXs like the DR8IIplus.?
Mini-Review The video for FrSky 2.4Ghz Chase Wu Radios 0 Dec 16, 2009 01:18 AM
Discussion Realflight G5 Combat so far so good! splitpilot Simulators 0 Nov 22, 2009 06:36 AM
Discussion So far... So good rikks Mini Helis 35 Feb 17, 2006 12:42 PM
Aerofly Deluxe so far so good! Gary Morris Simulators 5 Aug 19, 2005 07:23 AM
Schulze 18.46K v7.02 - so far, so good! Jason M Electric Heli Talk 4 Aug 11, 2002 01:25 AM
