Old Feb 18, 2013, 04:36 AM
heinduplessis is offline
Find More Posts by heinduplessis
Foam Snow
South Africa, WC, Cape Town
Joined Aug 2011
Originally Posted by renatoa View Post
In theory, in a clean area, and the perfect setup, it is 4-5km, and some people reached this distance.
Frsky was advised to be conservative and spec the system as 1-1.5km, just to not have surprises.
Your range is too small to have anything ok on your plane.
If the ground range check is under 50m, I would inspect antennas.
I get 87m on range check with stock antenna, 130m with patch, in a very wifi noisy area. I stop walking at the first glitch, where the red light comes on. The green light return and I can continue walking in theory, but that's where I measured the 87m.
According to the manual I can multiply that with 30 on full power, which I don't even want to think about, because I lose all control between 600-700m. Same as my old Spektrum setup.
I've taken some pictures now for you to see if I've missed anything, or botched up anything.
What the pics don't show is the 5x1mm CF strip running the width of the wing in an arc, along with a 5mm diameter CF rod in the nose from side to side.
heinduplessis is offline Find More Posts by heinduplessis
Old Feb 18, 2013, 04:41 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
This is the real strange thing... you really must have 30x more range, no joke...
Unless you have a very noisy RF source on your wing, not active in ground range check.
renatoa is online now Find More Posts by renatoa
Old Feb 18, 2013, 04:59 AM
Kilrah is offline
Find More Posts by Kilrah
Happy FPV flyer
Kilrah's Avatar
United Arab Emirates, Dubai
Joined Sep 2006
What's the big fat video transmitter you have there? Which freq/power?
Kilrah is offline Find More Posts by Kilrah
Old Feb 18, 2013, 05:22 AM
Joined Sep 2007
Based on antenna size it's 5.8G, either 200 or 400mW, both are same look.
Old Feb 18, 2013, 06:59 AM
Foam Snow
Joined Aug 2011
Wow you guys are quick on the forum Yes, it's a 5.8 500mW. What you see there is the heat sink, it had the board beneath it, which I've disconnected and laid flat next to it.
All systems were turned on when I was ground testing.
Maybe that's flooding the rx at a distance? I don't understand how, though. But who the heck flies 1.5km LOS??
Old Feb 18, 2013, 07:02 AM
cold wombat is offline
Find More Posts by cold wombat
cold wombat's Avatar
Australia, WA, Perth
Joined Jul 2011
Was the FPV setup turned on for the range check? Not my expertise at all, but when troubleshooting, try and replicate as much of the environment as possible, and then change one factor at a time.
cold wombat is offline Find More Posts by cold wombat
Old Feb 18, 2013, 07:06 AM
Joined Sep 2007
5.8G shouldn't affect 2.4GHz RC, I say this having some longer than 5km flights with 200mW video, not boosted RC, just patch panel antenna.
Old Feb 18, 2013, 07:22 AM
Kilrah is offline
Happy FPV flyer
Kilrah's Avatar
Joined Sep 2006
The 200mW is usually OK indeed, but the 500mW version has a different amplifier that could be not as well filtered...
And who uses 500mW for just 1.5km...
Old Feb 18, 2013, 07:25 AM
Joined Jul 2011
Fine, but I've often seen "shouldn't" that doesn't match "doesn't" because something is not doing what is "should've". Just a thought.
Old Feb 18, 2013, 08:08 AM
Foam Snow
Joined Aug 2011
Exactly! I've done 3km with my RangeLink receiver on the same plane - this is when it starts getting snowy.
I'll try with my patch next time.
Yes, of course everything turned on as if I was flying for real.
Old Feb 18, 2013, 01:42 PM
GaryO is offline
Find More Posts by GaryO
United States, AZ, Arizona City
Joined Sep 2001
After spending an hour searching thru the threads, I just need to ask this question.
BACKGROUND: I have 2 Multiplex Evo xmtrs. One converted to FrSky non telemetry, 3 hlg gliders flying using V8R7SP non telemetry rcvrs.
I want to convert the other Evo to FrSky. Only the telemetry xmtr module seems to be available. We have tested that module and it can control the non telemetry rcvrs in my planes.
I'm not particularly interested in the telemetry options, as battery capacity is limited in a hlg, so I'd rather just recharge between rounds. Telemetry rcvrs draw more current, but maybe that is insignificant compared to the draw of four servos?
So, which rcvrs should I go with? Size is a problem in the small hlg fuse, the 7 channels barely fit. Oh, horizonal pins are needed.
Thanks in advance.
Gary
GaryO is offline Find More Posts by GaryO
Old Feb 18, 2013, 01:54 PM
Fly2High is offline
Find More Posts by Fly2High
Chuck 'Em and Chase 'Em
Fly2High's Avatar
United States, NY, Plainview
Joined Aug 2005
Gary,
Do you have any Jr digitals? If yes, you should use the non telemetry V8 series. D285, 290 and 287 Jr digitals all jitter when too close to the telemetry receivers.
Either non-telemetry, the 8 channel without case (V8FR: specs: 14gr 49mm×24.5mm×15 mm) or 7 (v8-7SP spec: 9g, 49mm×23mm×12mm) might fit depending on plane. I think they end up being the same width without the case. both have 8 sets of pins out the side.
I just built a CX2 and am using the D4R telemetry receiver in them. I have the digitals in the wing and the upgrade elevator servo from Roland. No jittering and current draw was fine. Flew it all day in a contest on Sat. (LISF Aug contest). I tend to recharge between rounds (well, every 2 or 3 rounds actually and that depended on when I would have to fly next) but I did fly it for about an hour without recharging just the day before. Still had power but I do not recall how much was left when I finally recharged it. I also could just barely fit a D6R in the CX2 as well.
I was using the stock 400mAh NiMH that Roland give me in the plane.
One more thing, Occasionally, I would get an odd beep from time to time when farther out. I guess as I turned in a thermal, the connection lost a frame or something and it indicated that my RSSI was near the limits and would beep. I have the antennas ouat a 45 deg. out the top and bottom and my Tx antenna was bent downward as much as I could with my 9303 (handle prevents it from being fully downward but it is most of the way). Never did I see any loss of control or anything that would suggest I lost it though. It was in control the entire day. Straight runs never beeped, only in turns and not always. It was niced being able to look down and know how much voltage I had and whether I was ranging too far.
Those are my results so far
Hope that helps,
Frank
Fly2High is offline Find More Posts by Fly2High
Old Feb 18, 2013, 02:04 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
I have been using the V8R7, but to get them to fit my Stobels I remove the servo connectors something like Phil did here with a 72 rcvr.
http://www.rcgroups.com/forums/showp...&postcount=510
This was to get the receiver in front of the servos. Behind there was lots of room, but then you can't get ballast in.
On my last one I simply soldered all the wires directly to the rcvr, simpler and lighter.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Feb 18, 2013, 02:38 PM
xairflyer is online now
Find More Posts by xairflyer
Bleriot's R Us
xairflyer's Avatar
Ireland, Donegal
Joined Nov 2003
I am using a JR 8411 and two JR 811 digitals in one plane with the D8R-II+ with no issues, but using 4 cell 4.8v NIMH packs as JR servos dont like 5 cell (6v) packs no matter what receiver they are connected to.
xairflyer is online now Find More Posts by xairflyer
Old Feb 18, 2013, 02:47 PM
Fly2High is offline
Fly2High's Avatar
Joined Aug 2005
How close are the digitals to the receiver antennas?
I had even the Jr 368 jittering when close to the antenna ends.
It all depends on proximity. the farther away the antennas are, the less they jitter and draw current.
things get pretty tight in a DLG...
Mini-Review The video for FrSky 2.4Ghz Chase Wu Radios 0 Dec 16, 2009 02:18 AM
Discussion Realflight G5 Combat so far so good! splitpilot Simulators 0 Nov 22, 2009 07:36 AM
Discussion So far... So good rikks Mini Helis 35 Feb 17, 2006 01:42 PM
Aerofly Deluxe so far so good! Gary Morris Simulators 5 Aug 19, 2005 08:23 AM
Schulze 18.46K v7.02 - so far, so good! Jason M Electric Heli Talk 4 Aug 11, 2002 02:25 AM
