Joined Dec 2006
how to upgrade d4r-ii firmware?
apologies if this has been mentioned before, i just can't find good info for my following problem:
are there a good link/guide/instructions for upgrading the d4r-ii rx with the 27ms cppm firmware using the fuc-3 interface? i have all the cables that came with the fuc-3 and d4r-ii, have downloaded all the manuals and the frmware files from http://www.frsky-rc.com, but am not sure how to connect the two. the cable that came with the rx seems to fit physically, but i want to double check the steps. and it also looks like i have to power up the rx separately? separately, is there a good place where all the pinouts and connection info is found? thanks very much! |
United Kingdom, England, Bristol
Joined Aug 2011
What sort of model have you put it in and how are the antennas positioned and mounted? You can have a look through this forum but can say the v8fr-ii hasn't had many (if any) people say they have faulty receivers - so not common. Of course nothing to say it isn't faulty. Si. |
Terry |
Joined Aug 2011
Thanks for the replies. |
Use a telemetry receiver, cuts down on the guess work of radio reception. Well worth the extra couple of bucks!!
-Wayne |
Latest blog entry: FrSky at the Toledo R/C Model Expo -...
Joined Aug 2011
For UK (and I guess EU) FrSky lovers, I've just noticed that GiantShark has the new SBus to 4 Servo converter or as they name it "Frysky SBUS to PWM Decoder". Plus they have the accompanying "Frsky Servo Channel Changer" too.
Frysky SBUS to PWM Decoder [sic] Frsky Servo Channel Changer Si. |
Hi
I'm still reading what is related to the Futaba 8FG TX and using it with the FRSKY ACCST module ... I'm doing this to have a longer safer range with a patch antenna and a 2.4 GHZ booster ... yes UHF didn't work for where I fly ... too much interference ... 1st of all I'd like to thank you guys for the informative posts .. I learnt a lot especially Scott Page So I got the FRSKY ACCSY module for JR ... I intended to use it on a 9X .. but I prefer using it with my 8FG... if this is possible and I have a strong feeling it is possible after some posts I read here ... so please bare with me and kindly correct me ... This is the module /RX combo I got ... 1- Open the module and look for the PPM, GND, +V 2- Open the 8FG and solder PPM, GND, +V from the module to the corresponding pins behind the trainer port .. (To keep it free for head tracker use ) 3-Setup trainer mode in the 8FG as a student to output PPM stream through the trainer port sounds too simple ... I'm sure I"m missing something ,,, I've checked the diagram of the Futaba trainer port made by Scott Page .. and there are 6 pins not 3 .. and there is PPM in . and PPM out ... So a little insight is greatly appreciated ... BTW ... Is there any difference between the boxed module in the link above and the DIY module... other than telemetry ... I don't need it since I already have OSD and I have all the info I need during flight in the video goggles .. Thanks a lot for your help ... much appreciated Khaled |
Romania, Dolj, Craiova
Joined Sep 2007
Non telemetry combo will give you a longer range, but if you intend to use a booster, this detail is no more important.
I am not a big booster fan, if 10 km is enough for you, can be achieved simpler and safer using CP antennas, with a 4 turn helix on Tx. |
Latest blog entry: JRSky - birth of a dream radio
Joined Aug 2011
Another cut-out today - ALMOST fatal...
| Thread Tools | |
| Mini-Review The video for FrSky 2.4Ghz | Chase Wu | Radios | 0 | Dec 16, 2009 01:18 AM |
| Discussion Realflight G5 Combat so far so good! | splitpilot | Simulators | 0 | Nov 22, 2009 06:36 AM |
| Discussion So far... So good | rikks | Mini Helis | 35 | Feb 17, 2006 12:42 PM |
| Aerofly Deluxe so far so good! | Gary Morris | Simulators | 5 | Aug 19, 2005 07:23 AM |
| Schulze 18.46K v7.02 - so far, so good! | Jason M | Electric Heli Talk | 4 | Aug 11, 2002 01:25 AM |
