Old Jan 18, 2013, 07:24 AM
Daedalus66 is online now
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Originally Posted by Rotozuk View Post
I'll see if Eva can make up some 250mm length antennas for Aloft.
-Wayne
That would be great. But don't scrap the simple ones, which are ideal for many models. Charge a little extra for the "dipole" type and keep the plain ones available.
Daedalus66 is online now Find More Posts by Daedalus66
Old Jan 22, 2013, 10:30 AM
A10FLYR is offline
Find More Posts by A10FLYR
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
Question here.
A friend wants to use a 4 channel rx in his wing. Can he use it without the jumpers and still get rx voltage and rssi? If he has to use jumpers he can't mix ele & ailer channels. I don't have one of these so I can't help him.
A10FLYR is offline Find More Posts by A10FLYR
Old Jan 22, 2013, 10:46 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Not for a D4R, when ch 3 and 4 are jumpered, even ch 1/2 no more have real meaning.
Without jumper he can get rx voltage but no rssi for osd, only RSSI on tx display.
Maybe he can use a D8R and mix ch 1/2 into an upper channel, any 5-8, this is possible. And still have RSSI on ch2.
renatoa is offline Find More Posts by renatoa
Old Jan 22, 2013, 12:06 PM
A10FLYR is offline
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
Thx Ren....I think he should just use a 6 ch rx, take the "case" off and be done with it!
Old Jan 22, 2013, 12:12 PM
renatoa is offline
Joined Sep 2007
Still not sure what RSSI he needs, on radio side, to have a signal quality check, or on receiver side, for OSD.
If not need for receiver side RSSI, then D4R unjumpered works very well.
Old Jan 22, 2013, 01:16 PM
A10FLYR is offline
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
At this point I think he just wants rssi for "plane locator".
Old Jan 22, 2013, 01:43 PM
Rotozuk is offline
Find More Posts by Rotozuk
Rotozuk's Avatar
United States, CA, Novato
Joined Sep 2003
Originally Posted by A10FLYR View Post
Question here.
Yes.. No jumpers it acts as a normal receiver with 4 channels. The telemetry will report the receiver voltage and RSSI back to the transmitter module.
You only need the jumpers if you are going to use CPPM or RSSI output for an OSD (On Screen Data).
-Wayne
Rotozuk is offline Find More Posts by Rotozuk
Site Sponsor
Old Jan 22, 2013, 01:45 PM
Rotozuk is offline
Rotozuk's Avatar
Joined Sep 2003
In about a week we will have the new 250mm length antennas with the little "cans" on them. We will also have all of the other antennas.
-Wayne
Site Sponsor
Old Jan 22, 2013, 02:09 PM
A10FLYR is offline
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
Thx Wayne....
Old Jan 22, 2013, 02:19 PM
jhsa is online now
Find More Posts by jhsa
Flying a Chipmunk in Portugal
jhsa's Avatar
NRW, Germany
Joined Sep 2010
-Wayne
Wayne, you're the man.. thanks..
jhsa is online now Find More Posts by jhsa
Old Jan 22, 2013, 02:22 PM
phil alvirez is offline
Find More Posts by phil alvirez
Windsor, Canada, near Detroit
Joined Jul 2007
http://www.microtechnics.eu/detail.p...qhs9srbd8g2ig7
and the price?
phil alvirez is offline Find More Posts by phil alvirez
Old Jan 22, 2013, 03:20 PM
Fly2High is offline
Find More Posts by Fly2High
Chuck 'Em and Chase 'Em
Fly2High's Avatar
United States, NY, Plainview
Joined Aug 2005
Wayne or Chase or Eva,
The X9D lists it has an internal 2.4 system.
Internal FrSky telemetry module with new PXX protocol
- One slot for external module, Graupner/JR format, which allows use of many already existing modules and their corresponding receivers like:
. FrSky DJT ( if you want double emission system or to continue using V8FR, V8R7 and V8R4 FrSky first generation receivers)
Will the internal system be compatable with the current FrSky telemetry and non telemetry receivers or will I need to get a DJT module to use them? Is the internal only the PXX format or will it also work PPM?
If it has an internal, under what conditions would one want to do double emmission as listed in the quote above from the previous post's link?
It sounds like without a DJT, we will not be able to use exisiting non telemetry receivers. Is this true?
Since I am a 9303 fan, I like the looks of the prototype.
thanks
Frank
Fly2High is offline Find More Posts by Fly2High
Old Jan 22, 2013, 05:42 PM
maximal is offline
Find More Posts by maximal
AutoQuad OS developer
maximal's Avatar
near Ithaca, NY, US
Joined Aug 2004
That's great, and quick, thank you! I got the 400s and as I suspected there is way too much extra cable for my needs. The 250mm length should be perfect!
-Max
maximal is offline Find More Posts by maximal
Old Jan 22, 2013, 07:39 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
thanks
Frank
Good question.
If it does not support the V series in native mode then this is a big negative for me.
pmackenzie is offline Find More Posts by pmackenzie
Old Jan 22, 2013, 10:16 PM
Calla969 is offline
Find More Posts by Calla969
United States, FL, Indialantic
Joined Mar 2012
Hello,
I've recently began using FrSky equipment on my modded 9x radio with Open9x firmware. I have 2 different 2 way RXs and I've been getting low RSSI alarms at very short ranges (<500'). I haven't changed the levels in my radio, I think they are set at around 45 or 50 before the alarm goes off. Does anyone know what an acceptable level is for the alarms to be set or if what I'm experiencing is unusual? I get the same results with 2 different receivers. When performing a range check, I get about 150' before I notice any glitching, unless I put my body between the TX and RX. Then it's slightly shorter.
Thanks for any help,
Chris
Calla969 is offline Find More Posts by Calla969
Mini-Review The video for FrSky 2.4Ghz Chase Wu Radios 0 Dec 16, 2009 02:18 AM
Discussion Realflight G5 Combat so far so good! splitpilot Simulators 0 Nov 22, 2009 07:36 AM
Discussion So far... So good rikks Mini Helis 35 Feb 17, 2006 01:42 PM
Aerofly Deluxe so far so good! Gary Morris Simulators 5 Aug 19, 2005 08:23 AM
Schulze 18.46K v7.02 - so far, so good! Jason M Electric Heli Talk 4 Aug 11, 2002 02:25 AM
