yeah, we make good stuff
![]() I usually leave after production has left. That is when they do the burn-in of the higher end subs. Even though they try to do them in out of phase pairs to lessen the SPL, they do make an ominous thunder. And if you really want to shake your house (and have very deep pockets) then look at a Sub1 or Sub 2
Latest blog entry: er9x heli 450 heli set up (flybar)
As part of product testing they should have one, as well as an oven.
Not only to determine the safe operating temperatures, but also to make sure they will survive the sort of temperatures they could experience during shipping. |
I don't think a freezer is going to be cold enough to duplicate the issue on these receivers. The original poster was experiencing the issue at 0F, that is much lower then a typical freezer goes to. They should be able to use some dry ice to reach this range though.
![]() I'm surprised the guys Lipos were still working at those temps. -Wayne |
Latest blog entry: FrSky at the Toledo R/C Model Expo -...
When I tested them in the freezer with just a battery on them (as opposed to being on the quad) they failed every time. When on the machines, I carefully monitiored the voltage to the RX's and it was constant from my BEC at 5V; when tested alone they were on a fresh Eneloop 2000 mah NiMh, so I don't believe these problems were caused by cold lipos or a bad BEC. And, of course, I had three Frsky RX;s that did not fail any tests, and just got another one today that has not failed my initial testing (at 15F, it was cold here today). I was also able to reproduce it in my freezer. |
I did a whole bunch of searches trying to find out what makes the frsky system have so much more range than the competitors, but I didn't find anything. With an output power of 60mw, you'd think it would be short range compared to spektrum's 200mw output. I see many people getting over 2.5 km with frsky and only a few with other radios.
So, what is the actual reason behind the longer range? |
Joined Oct 2010
Bad new for the theory from me. I did the freezer test in my deep freeze for 15 minutes and never lost signal. I took it out still connected and let it warm up to room temp while keeping an eye on it. It stayed on the whole time. Now I have to figure out why I keep loosing signal before it cost me another repair job.
Joined Oct 2010
I have the older original v8ht diy module that is discontinued now and the rx that may be giving me problems is the v8fr-II. I have noticed that at times when I turn on the tx and then plug in the battery to the bec and rx, it sometimes takes up to 10 full seconds to link up or boot up. Sometimes it is quicker. It is already bound. The tx eventually grabs a hold of the rx. If you then turn off the tx and turn it back on, it is almost instant. You can turn off and on the tx all day and it links with the rx instantly. Why does it take so long when I plug in the battery to the rx? Is this normal behavior? Are these two items compatible without any updates? Could this be a problem with loosing signal in the air?
Joined Mar 2009
Please post the two receivers back to us directly if you have not sent them to Aloft Hobbies yet, or Wayne will do instead if you already have, so that we could take a look into it immediately. |
I have an aileron servo that's been giving me the same situation -- works fine at room temperature, but not in freezing temperatures -- I'm pretty sure it's a cold solder joint (strange unintended pun) where two metals are having differential contraction in the cold and opening a circuit. |
| Thread Tools | |
| Mini-Review The video for FrSky 2.4Ghz | Chase Wu | Radios | 0 | Dec 16, 2009 01:18 AM |
| Discussion Realflight G5 Combat so far so good! | splitpilot | Simulators | 0 | Nov 22, 2009 06:36 AM |
| Discussion So far... So good | rikks | Mini Helis | 35 | Feb 17, 2006 12:42 PM |
| Aerofly Deluxe so far so good! | Gary Morris | Simulators | 5 | Aug 19, 2005 07:23 AM |
| Schulze 18.46K v7.02 - so far, so good! | Jason M | Electric Heli Talk | 4 | Aug 11, 2002 01:25 AM |
