Old Dec 30, 2012, 05:16 PM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
This could mean no flying in the wintertime! O THE HUMANITY!
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Dec 30, 2012, 05:40 PM
u2builder is offline
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Never! I'll use those handwarmers of yours if I have too. Maybe Frsky can offer an "all weather model" tested to -20C. That would be a lot lower than I am good for.
These are probably a lot better off inside a fuselage than hanging out in the breeze. I think I will make a little foam insulated box even for my "good" ones. Since they produce some heat (100mW?) even a 1/4" thick foam box should raise the temperature 20 degrees or so if I am figuring correctly.
u2builder is offline Find More Posts by u2builder
Old Dec 30, 2012, 07:05 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Wayne at Aloft got back to me immediately. He will provide replacement RX's for me and send mine to Frsky for testing and evaluation. Great service.
Here is an enclosure made out of 1/4" EPP that encloses the RX and the attached DAC RSSI circuit board that should provide some insulation as well as some protection for the exposed DAC board. The enclosure can easily be slid off the RX. There are little holes covered with clear tape to view the RSSI leds and the RX led.
Old Dec 30, 2012, 07:35 PM
jhsa is offline
Find More Posts by jhsa
Flying a Chipmunk in Portugal
jhsa's Avatar
NRW, Germany
Joined Sep 2010
Ok, My D8R-II Plus just spent over 15 minutes in the freezer. not a single glitch. was monitoring the RSSI on my radio's screen and actually was getting better and better as it got colder
Always with a beautiful solid red light
So, it might be a bad batch, or not even that but surely should be investigated by frsky..
jhsa is offline Find More Posts by jhsa
Old Dec 30, 2012, 07:45 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
My bet would be on a bad solder joint.
They are probably using lead free solder to comply with ROHS- and it is just a lot harder to get reliable joints with it.
pmackenzie is offline Find More Posts by pmackenzie
Old Dec 30, 2012, 08:21 PM
jhsa is offline
jhsa's Avatar
NRW, Germany
Joined Sep 2010
Yes, it could be, but it should be checked.. if it is a bad solder joint, sooner or later it will fail, whether is cold or not..
Maybe frsky should make the freezer test before sending them out..
Old Dec 31, 2012, 02:53 AM
Terry Rigden is offline
Find More Posts by Terry Rigden
Terry Rigden's Avatar
UK, Bedworth
Joined Apr 2004
It was routine to temperature cycle fibre optic components before shipping them . the test was -40 to +85C ramp time 60 seconds. So its not a test that is unfamiliar to the electronics industry.
Terry
Terry Rigden is offline Find More Posts by Terry Rigden
Old Dec 31, 2012, 04:59 AM
IceWind is online now
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
Is this one of the new FrSky "radios"?
http://www.youtube.com/watch?feature...zSEmT-E#t=122s
IceWind is online now Find More Posts by IceWind
Old Dec 31, 2012, 08:36 AM
davecrash is offline
Find More Posts by davecrash
Fly now crash later
davecrash's Avatar
Canada, ON, Newmarket
Joined Nov 2006
I got my frsky stuff about the same time. Guess I should test it in the freezer. i hope they report back their findings on the Rx's.
davecrash is offline Find More Posts by davecrash
Old Dec 31, 2012, 08:43 AM
Joined Mar 2012
I wish they sold this! I would buy 2-3 of em!
Old Dec 31, 2012, 09:02 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
It's a variation of fmkit nunchuk based controller, check his posts.
renatoa is online now Find More Posts by renatoa
Old Dec 31, 2012, 01:06 PM
snoopy_schulz is offline
Find More Posts by snoopy_schulz
snoopy_schulz's Avatar
Germany, lake of constance
Joined Oct 2010
Terry
Hi Terry
A Burn-in of consumer electronics is usually not carried out. The costs are too high. Some hardware
failures are detected by the SMD mounting machines. Usually is also an In-Circuit Test (ICT), but also expensive.
An ICT test and a Burn-in is normally carried out on aerospace electronics, somtimes even with random vibrations,
e.g. to simulate the vibrations of gunfire. Sure other high priced electronic products may also tested
by an ICT and/or a Burn-in.
Best regards and a happy new year!
Micha
snoopy_schulz is offline Find More Posts by snoopy_schulz
Old Dec 31, 2012, 01:48 PM
pmackenzie's Avatar
Joined Dec 2002
FWIW, they do lots of burn-in and in-circuit testing where I work, but I guess you could say our products are "high priced"
(Paradigm/Anthem/Martin Logan products)
Old Dec 31, 2012, 02:39 PM
Joined Oct 2010
Hi pmackenzie
I have two loudspeaker's from Klein + Hummel (SL 40), of course not a consumer electronic.
Micha
Old Dec 31, 2012, 02:42 PM
Levictus is offline
Find More Posts by Levictus
Crash Test Pilot
Levictus's Avatar
United States, NC, Raleigh
Joined Jul 2012
Wow, I love Paradigm speakers...I have an old pair of original Studio Monitors that shake the house!
Levictus is offline Find More Posts by Levictus
Mini-Review The video for FrSky 2.4Ghz Chase Wu Radios 0 Dec 16, 2009 01:18 AM
Discussion Realflight G5 Combat so far so good! splitpilot Simulators 0 Nov 22, 2009 06:36 AM
Discussion So far... So good rikks Mini Helis 35 Feb 17, 2006 12:42 PM
Aerofly Deluxe so far so good! Gary Morris Simulators 5 Aug 19, 2005 07:23 AM
Schulze 18.46K v7.02 - so far, so good! Jason M Electric Heli Talk 4 Aug 11, 2002 01:25 AM
