Old Dec 21, 2012, 09:05 AM
u2builder is offline
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Where to find driver for Upgrade USB?
I dunno. This stuff is always a stuggle. First the power goes out. So now working on the laptop watching the battery go down.
The update USB can't locate a driver. Of course. Where do I get the driver? Is it the XP driver from the Frsky site or something else?
Any help much appreciated.
OK, found the driver. Power back on. Ready for the next step.
u2builder is offline Find More Posts by u2builder
Old Dec 21, 2012, 11:10 AM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
OK, next problem.
I run the Update program. My USB is on Com Port 6 so I select that.
Then I open the FRK file.
I do not get the UID number. Where it is supposed to show up I get: Com Port 6 and the location of where I have the FRK file.
When I hit download there is no indication of anything happening.
I have tried many times.
Any suggestions?
Old Dec 21, 2012, 11:20 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
No UId could mean:
- Rx not powered - beware, when in update mode no LED lit, so it's difficult to diagnose this
- Rx not in update mode - are ch 7-8 signal pins jumpered ? surely you didn't shorted the ground pins ? no LED lit should tell you are in update mode
- rx-tx reversed - check them again
If no UID, don't hit download.
renatoa is offline Find More Posts by renatoa
Old Dec 21, 2012, 11:59 AM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
It worked, with Renatoa's help!
Originally Posted by renatoa View Post
No UId could mean:
What an idot I am. I did reverse the Tx and Rx wires. I actually had them correct, and "double checked" and thought they were wrong so I changed them.
It reflashed just perfectly. Now to try to see if I can get the DAC working.
Thanks, thanks, thanks!!!!!
Old Dec 21, 2012, 12:34 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
DAC seems to be working!
Very exciting. I attached the DAC to the D8R-XP, bound it to the TX, and the little LED showed full signal. Then I set the RX to range test. It still showed full signal so I moved the TX to another room. The module in the TX beeped and the RSSI led on the DAC moved to its center.
So now I guess I need to hook it up to one of my OSD's. I have a Skylark and an ET. I think I will try the Skylark. I expect that to be the biggest struggle.
I have another DAC on order from Magi, but it will be a while before it gets here.
Old Dec 21, 2012, 03:12 PM
rcroadtrain is offline
Find More Posts by rcroadtrain
rcroadtrain's Avatar
Australia, NSW, Marsfield
Joined Feb 2012
Originally Posted by u2builder View Post
Good plan, though "misery would love company".
The "flash" update we are supposed to use I believe is a special one specifically for the DAC and provided by Magi.
Roadtrain, what OSD do you have. I suspect once I get the DAC installed I'll have some hurdles to get through figuring out how to get the signal from the DAC to my OSD.
Is the update file the same one as on the frisky site? (if not, then may I have the link please?)
I'm using G-Osd, but I'm going to pull that off and put on a Black Stork2 unit I bought off another member of RCG.. It doesn't seem to have input for RSSI....
..if I use the Rx DAC, then where (how) do I plug in the FrSky telemetry hub?
rcroadtrain is offline Find More Posts by rcroadtrain
Old Dec 21, 2012, 03:47 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
The file is different. Get it from Magi website right below the red text below the picture:
http://www.rc-miskolc.emiter.hu/rc-m...124&Itemid=122
I don't know anything about the telemetry hub, but DAC plugs into the side of the RX and blocks all the ports so you may be out of luck on that.
I've got it all wired up but haven't tried see if it shows up on my OSD and/or calibrated it. But according to the LEDs on the DAC it definitely shows lower RSSI if I reduce the signal on my TX. Hopefully tomorrow I can see what shows up in the Goggles. Fingers crossed.
Old Dec 21, 2012, 03:52 PM
renatoa is offline
Joined Sep 2007
Why you say is different ?
Is the same as from Frsky site, fdd_rx_rev2_cppm_build110314.frk...
Old Dec 21, 2012, 04:05 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
I guess my comment was mistaken. Mr. Istvan sent me an attachment of the file he said to use. I just assumed incorrectly it was not available at Frsky site. It is the same as you show from the Frsky site. Sorry about the confusion. It has been a long day. But a good result
Old Dec 21, 2012, 04:28 PM
davecrash is online now
Find More Posts by davecrash
Fly now crash later
davecrash's Avatar
Canada, ON, Newmarket
Joined Nov 2006
My DAC is on order and i am using a Skylark Tiny II, I know whom to ask if it doesn't work. lol
davecrash is online now Find More Posts by davecrash
Old Dec 22, 2012, 01:54 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Well, since a few folks are getting the RSSI-DAC, I am happy to be able to report that the it works beautifully with my Skylark Tiny III OSD. I just plugged the wire from the DAC into the Skylark RSSI pin and it worked. I am unable to "calibrate" it because the Skylark software does not work on my computer, but it read about 4.1 on the OSD with full signal and I think 2.2 when I pushed the reduced power button on the TX and took it in the other room. I think I was getting one beep at that point. I'll do a better range check outdoors sometime to correlate the RSSI signal with "beeps" and distance.
Old Dec 22, 2012, 03:23 PM
Fly now crash later
davecrash's Avatar
Joined Nov 2006
I was unable to get it to work on my laptop but the desktop worked fine. Both are running XP but the USB on the laptop is less then 5V. I think that may have something to do with it.
Old Dec 22, 2012, 07:29 PM
SupraGo is offline
Find More Posts by SupraGo
SupraGo's Avatar
Canada, AB, Vegreville
Joined Jun 2009
Try using a powered USB hub.
Bill
SupraGo is offline Find More Posts by SupraGo
Old Dec 23, 2012, 09:49 AM
Terry Rigden is offline
Find More Posts by Terry Rigden
Terry Rigden's Avatar
UK, Bedworth
Joined Apr 2004
Frsky and digital servos
I've read various posts talking about issues with digital servos is this a general problem or just with specific mixes of equipment. I'm using the old V8 series with analogue servos at the moment and am wondering if I'm likely to hit problems if I switch to digital servos.
Terry
Terry Rigden is offline Find More Posts by Terry Rigden
Old Dec 23, 2012, 09:51 AM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
Why is everyone "updateing"? All the rx and tx stuff I baught 2 months ago work ok. If it works dont mess with it!
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Mini-Review The video for FrSky 2.4Ghz Chase Wu Radios 0 Dec 16, 2009 01:18 AM
Discussion Realflight G5 Combat so far so good! splitpilot Simulators 0 Nov 22, 2009 06:36 AM
Discussion So far... So good rikks Mini Helis 35 Feb 17, 2006 12:42 PM
Aerofly Deluxe so far so good! Gary Morris Simulators 5 Aug 19, 2005 07:23 AM
Schulze 18.46K v7.02 - so far, so good! Jason M Electric Heli Talk 4 Aug 11, 2002 01:25 AM
