Romania, Dolj, Craiova
Joined Sep 2007
Both antennas being equal 2dB, you see close RSSI values for both direct and return signal. Pulse peak power matters for range, duty cycle affects only data quantity you can transmit. And there are more bytes in RC stream than telemetry stream. |
Latest blog entry: JRSky - birth of a dream radio
Joined Sep 2007
DHT-U is a transmitter / display, it doesn't receive anything than telemetry data.
CPPM is at the other side of the link. |
I got my Frsky diy unit today and have already mounted it into my 7CAP. with the Rx in the basement workshop I was able to go up stairs and even while holding the Tx antenna I didn't get any beeps. Putting it into Range check mode I got single beeps right away. Must be alot of interference in the basement. My 3 way switch is a little flakey. In the 1 way position it will bump out to the middle very easily.
-Wayne |
Latest blog entry: FrSky at the Toledo R/C Model Expo -...
I mounted the LED/Bind switch board, and the option switch, on top of my Futaba 7 channel. A little hot glue holds in the LED/bind switch board good. I was able to use the old 72mhz antenna base to work with the 2.4ghz antenna too.
Latest blog entry: My Low Wing plane
Joined Dec 2007
Thanks - Yeah, I kind of suspected that - I'm going to open the case and do some probing around, with a bit of luck I'll find separate TX/RX and processing/display boards. If so I'll try and lift the datastream from that, if not....DFT or DHT here I come....
Joined Sep 2007
The serial line is there, but used different in many ways:
- no more RS232, no max circuit for logic translation, it is now TTL serial, and available as an USB plug - the code use it for firmware updates - it outputs some cryptic non documented info when in normal service, if performing a data acquisition the module GUID can be found in the stream, amongst other unrecognizable binary data. |
Anyone ideas why my D8R-II is beeping on A1 (alarm on) and showing about 4.1v on switch on, the voltage slowly rises until the alarms go off and may settle about 5.1 This can take about 20secs.
It is connected to a 4 cell pack so nothing to do with a ESC or BEC. Servo pin voltage is pack voltage from switch on so again nothing to do with supply. I think in the past I may have accidentally with a screwdriver shorted some combination of the RX TX Grn A1 A2 pins on the side. I have opened the case but don't see any component burnt, seems like to me like a cap charging up. |
| Thread Tools | |
| Mini-Review The video for FrSky 2.4Ghz | Chase Wu | Radios | 0 | Dec 16, 2009 01:18 AM |
| Discussion Realflight G5 Combat so far so good! | splitpilot | Simulators | 0 | Nov 22, 2009 06:36 AM |
| Discussion So far... So good | rikks | Mini Helis | 35 | Feb 17, 2006 12:42 PM |
| Aerofly Deluxe so far so good! | Gary Morris | Simulators | 5 | Aug 19, 2005 07:23 AM |
| Schulze 18.46K v7.02 - so far, so good! | Jason M | Electric Heli Talk | 4 | Aug 11, 2002 01:25 AM |
