Old Dec 15, 2012, 07:42 AM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
1.5 kilometers is equal to 0.932 miles ! I thought these would work a little farther.
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Dec 15, 2012, 07:57 AM
u2builder is online now
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Originally Posted by Kilrah View Post
Both receivers have exactly identical hardware, only the firmware is different (offers PPM and RSSI on the XP), and you can flash a II-Plus with the XP's firmware if you want.
Thanks. Very helpful. I just range tested my D8R II plus. I got about 50 meters before I got a beep and 90 meters before I was getting 3 beeps or almost continuous beeps but even then the receiver was giving a signal to the controls. What is even better is that while I am pretty hard of hearing and can't hear my Futaba timer alarm I could actually hear the Telemetry Beeps very clearly. This is great.
BTW, and FYI I tried a double dipole 15" antenna I bought on Ebay on my TX and it really didn't increase the range in a noticeable way.
u2builder is online now Find More Posts by u2builder
Old Dec 15, 2012, 08:08 AM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Originally Posted by scott page View Post
At this point you seem to have your bases covered. But I've included a photo of the DHT to assure this is what you mean. (a picture is worth 1000 words). If you have these two switches off and do the jumper correctly and are not binding -- then I'd say you do have receiver problems.
That's the old DHT you are showing. From his reference to "switch in middle position" I assume he has the newer toggle switch version. In that case, middle is 2-way.
Daedalus66 is offline Find More Posts by Daedalus66
Old Dec 15, 2012, 08:55 AM
davecrash is offline
Find More Posts by davecrash
Fly now crash later
davecrash's Avatar
Canada, ON, Newmarket
Joined Nov 2006
I will be using a higher gain antenna, I hope to get better. Mine should be here some time this week.
davecrash is offline Find More Posts by davecrash
Old Dec 15, 2012, 09:01 AM
richard hanson is online now
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
It's nice to hope - but don' expect any wild increases
The approved power output is what really controls things
richard hanson is online now Find More Posts by richard hanson
Old Dec 15, 2012, 09:21 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Lot of hams will tel you are wrong on this, we know the antenna is the best amplifier.
There are lot of reports about 3-8km range of standard Frsky stuff only by changing stock antennas. Not speaking about something fancy, a good dipole on receiver and a 5-7db omni/patch on Tx and you are done. Cost under $10.
The only exotic (and the best) solution was using CP antennas at both ends, it's the 8km case.
renatoa is online now Find More Posts by renatoa
Old Dec 15, 2012, 09:54 AM
Joined Mar 2012
I wonder why FrsKy doesn't sell these type antennas if they make the product work so much better?
Old Dec 15, 2012, 09:59 AM
Joined Sep 2007
Again, little or no documentation, wrong conclusions
Try a google: "frsky antenna"
Anything but the CP solution will come in first page with relevant links.
Old Dec 15, 2012, 10:04 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
As standard, because for most users the standard antenna work perfectly.
Only FPV needs more than 1 or 2 km.
But they do sell patches, and the extended BODA type for the receivers.
http://www.alofthobbies.com/7db-patc...e-antenna.html
http://www.alofthobbies.com/60cm-receiver-antenna.html
pmackenzie is offline Find More Posts by pmackenzie
Old Dec 15, 2012, 11:06 AM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Probably because the vast majority of users are flying LOS. That is what the telemetry system seems to be aimed at, as it provides information at the TX. All of their equipment seems to have more than enough range for LOS.
Some people are choosing to use this equipment for FPV and those that want to go a great distance are enjoying the challenge of modifying things. Remember that any FPV that meets AMA guidelines is only going to be out about a mile which I believe is what they designate as the maximum LOS, though it would take some pretty good eyes to see something out that far. I will be happy to get a mile of range, and heck, I'll probably run out of battery before I get that far and back with my quad. I choose to fly under AMA guidelines so as to have their insurance cover me.
But I sure like having those little beeps to warn me or assure me. I am waiting for the RSSI-DAC to arrive so I can hopefully show the RSSI signal in my goggles too.
Old Dec 15, 2012, 11:38 AM
aesmith is offline
Find More Posts by aesmith
Joined Apr 2010
Partly because they'd break compliance, certainly in Europe where the max power is a combination of power and antenna gain. There's also the fact that higher gain comes with reduced coverage (by definition), so a 14dB antenna would need to be pointed at the model.
aesmith is offline Find More Posts by aesmith
Old Dec 15, 2012, 11:47 AM
Joined Mar 2012
"I choose to fly under AMA guidelines" that is your choice! as long as you have fun doing it according to the rules. Everyone has their preferences in life.
Old Dec 15, 2012, 12:17 PM
A10FLYR is offline
Find More Posts by A10FLYR
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
Easy for you to say...Sidewinders won't sue you when you hit them!!! Elsewhere the are humans...and in some cases LOTS of 'em......and they are so sue happy!!
A10FLYR is offline Find More Posts by A10FLYR
Old Dec 15, 2012, 12:24 PM
Joined Sep 2007
Better sue happy than trigger happy
Old Dec 15, 2012, 12:39 PM
A10FLYR is offline
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
Yes indeed...so sad.
Mini-Review The video for FrSky 2.4Ghz Chase Wu Radios 0 Dec 16, 2009 01:18 AM
Discussion Realflight G5 Combat so far so good! splitpilot Simulators 0 Nov 22, 2009 06:36 AM
Discussion So far... So good rikks Mini Helis 35 Feb 17, 2006 12:42 PM
Aerofly Deluxe so far so good! Gary Morris Simulators 5 Aug 19, 2005 07:23 AM
Schulze 18.46K v7.02 - so far, so good! Jason M Electric Heli Talk 4 Aug 11, 2002 01:25 AM
