Old Dec 11, 2012, 04:35 AM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
Originally Posted by TheCure View Post
Thats a logical question. Unfortunately i dont want to open any of my transmitters to get at the switch.
I have another of the same receiver model, and it binded fine using the same technique, i just thought maybe there is a new firmware revision that isnt compatible with my older dht.
Dont think thats the case though.
I've opened a ticket with hobbyking. I had to go through the whole video proof thing.
Wish me luck.
"I've opened a ticket with hobbyking" well, see ya next YEAR! LOL
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Dec 11, 2012, 07:16 AM
debianhot is online now
Find More Posts by debianhot
RC Soarer & wheel re-inventer
debianhot's Avatar
Antarctica
Joined Jul 2003
Originally Posted by Nelapaty View Post
I tested couple of clearplastic tubes last night with the microwave test and no they didnot get warm or hot..
I had some white plastic tubes that came with a plane for antenna wire and boy they were really warm to touch after the microwave test..
The most used pigment for white is titanium oxide so maybe its your case with the white plastic tubes .
debianhot is online now Find More Posts by debianhot
Old Dec 11, 2012, 11:27 AM
Fly2High is offline
Find More Posts by Fly2High
Chuck 'Em and Chase 'Em
Fly2High's Avatar
United States, NY, Plainview
Joined Aug 2005
Chase and Eva,
Back a little, you asked for some Jr digital servos to test their chattering with FrSky telemetry receivers.
I was wondering :
1. Were you able to duplicate the problem with them?
2. Do you have a solution to solve the problem yet?
thanks
Frank
Fly2High is offline Find More Posts by Fly2High
Old Dec 11, 2012, 12:39 PM
tigar is offline
Find More Posts by tigar
tigar's Avatar
Athens, Greece
Joined Sep 2001
Hi.
Any way i can get ppm sum from V8FR HV frsky rc?
tigar is offline Find More Posts by tigar
Old Dec 11, 2012, 01:07 PM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
No, external encoder, or V8R7SP, if transmitter is one way V8 series.
renatoa is online now Find More Posts by renatoa
Old Dec 11, 2012, 02:22 PM
Rotozuk is offline
Find More Posts by Rotozuk
Rotozuk's Avatar
United States, CA, Novato
Joined Sep 2003
Originally Posted by Fly2High View Post
Chase and Eva,
I was wondering :
thanks
Frank
Someone posted up their fix. I'm pretty sure their solution was to wrap the servo in aluminum ducting tape available from your local hardware store.
-Wayne
Rotozuk is offline Find More Posts by Rotozuk
Site Sponsor
Old Dec 11, 2012, 06:56 PM
jim e is offline
Find More Posts by jim e
Closed Account
Joined Sep 2005
getting DJT module to fit old apollo (jr) radio
Finally got the radio gear to go frysky but the fit is a no go.
See pics of original module (NET-J72P FM) and DJT module:
1. Original pin receptacles (sockets) are deeper in the case
2. New sockets have a much larger inside diameter so pins in radio do not contact sockets- even if depth were adjusted. Pins are .033" approx.
I was hoping for a plug and play situation as my soldering skills and understanding of electronics are not that good.
jim e is offline Find More Posts by jim e
Old Dec 12, 2012, 12:09 AM
Joined Sep 2007
You can get thicker pins (the actual standard used in electronics) and replace the originals, this should fix everything.
The length shouldn't worry, inside Frsky module case the connector is open, a longer pin can pass through, and there is empty space above connector.
You still need to solder
Old Dec 12, 2012, 07:33 AM
jim e is offline
Closed Account
Joined Sep 2005
size of pins
Anyone know the size of the pins needed? If esc style bullets would work then i could slip them over the approx .8mm radio pins and then the module would be plugged in securely. Also is it correct to assume that the layout of the pins on my radio is standard so that plus minus and signal etc. are where they should be??
Module will still protrude from back of case. Goop!
Old Dec 12, 2012, 07:58 AM
Joined Sep 2007
Yes, 0.8mm square will fit, or even less, like this: http://www.tme.eu/en/details/zl2038-...eaders/ninigi/
The layout is your greatest worry, not knowing this radio to be sure it is 100% JR. I would check other 2.4GHz migrations of same radio.
Old Dec 12, 2012, 08:49 AM
Fly2High is offline
Fly2High's Avatar
Joined Aug 2005
-Wayne
I had commented that it can help but it wasn't a perferct solution. After that, I think it was, the guys at FrSky offered to look into the issue.
It was around Sept 25, 2012 when the desire by FrSky to check into this was made.
Frank
Old Dec 12, 2012, 09:27 AM
davecrash is offline
Find More Posts by davecrash
Fly now crash later
davecrash's Avatar
Canada, ON, Newmarket
Joined Nov 2006
Where's my Frsky, I want to play with it. lol.
davecrash is offline Find More Posts by davecrash
Old Dec 12, 2012, 03:40 PM
Rotozuk is offline
Rotozuk's Avatar
Joined Sep 2003
Frank
They asked me to source some servos for them, but I dropped the ball. Thought we had a cure. My bad.
-Wayne
Site Sponsor
Old Dec 12, 2012, 03:42 PM
Rotozuk is offline
Rotozuk's Avatar
Joined Sep 2003
Got one of the new hubless varios in to beta test. It is nice and small, and doesn't way much at all. Was hoping to take it out for a glider test, but not sure about the conditions today... I might go anyway.
-Wayne
Site Sponsor
Old Dec 12, 2012, 04:51 PM
debianhot's Avatar
Antarctica
Joined Jul 2003
-Wayne
Picture , manuals ?
Please !
Mini-Review The video for FrSky 2.4Ghz Chase Wu Radios 0 Dec 16, 2009 01:18 AM
Discussion Realflight G5 Combat so far so good! splitpilot Simulators 0 Nov 22, 2009 06:36 AM
Discussion So far... So good rikks Mini Helis 35 Feb 17, 2006 12:42 PM
Aerofly Deluxe so far so good! Gary Morris Simulators 5 Aug 19, 2005 07:23 AM
Schulze 18.46K v7.02 - so far, so good! Jason M Electric Heli Talk 4 Aug 11, 2002 01:25 AM
