Old Dec 06, 2012, 09:04 PM
rcroadtrain is offline
Find More Posts by rcroadtrain
rcroadtrain's Avatar
Australia, NSW, Marsfield
Joined Feb 2012
Originally Posted by IceWind View Post
Dang... I usually use the snakes rods from gliders to help guide the antenna wires.
what are those rods made out of?
rcroadtrain is offline Find More Posts by rcroadtrain
Old Dec 06, 2012, 09:53 PM
jhsa is online now
Find More Posts by jhsa
Flying a Chipmunk in Portugal
jhsa's Avatar
NRW, Germany
Joined Sep 2010
actually, I have one of the antennas on my easystar running inside the tube for the 35MHz antenna on the bottom of the plane.. Noticed the RSSI going quite low a couple of times.. gotta check that
jhsa is online now Find More Posts by jhsa
Old Dec 06, 2012, 10:35 PM
BriGuy82 is offline
Find More Posts by BriGuy82
SemperFi!
BriGuy82's Avatar
United States, TX, Texarkana
Joined May 2012
Originally Posted by Rotozuk View Post
Some plastic tubes have graphite or metal in them.. You have been warned. use the microwave test (with a cup of water in the microwave.)
So am I looking for the tubes to get hot? That means its acceptable to use with my antenna?
BriGuy82 is offline Find More Posts by BriGuy82
Old Dec 06, 2012, 10:56 PM
Joined Feb 2012
no, not acceptable.
If the tubes get hot, they are absorbing the radio waves. Not Good.
What you want is tubes that stay cold.
Old Dec 06, 2012, 10:58 PM
gbmarsh is online now
Find More Posts by gbmarsh
Wait...what?
gbmarsh's Avatar
Canada, BC, Abbotsford
Joined Sep 2010
Nope, other way around. Hot means it has conductive/RF absorbing material in it.
Cheers,
Geoff
gbmarsh is online now Find More Posts by gbmarsh
Old Dec 06, 2012, 11:33 PM
BriGuy82 is offline
SemperFi!
BriGuy82's Avatar
Joined May 2012
Originally Posted by rcroadtrain View Post
no, not acceptable.
Can you reccomend a proven tube that is acceptable?
Old Dec 06, 2012, 11:47 PM
scott page is offline
Find More Posts by scott page
ຮັກລູກຊາຍຫລາຍ
scott page's Avatar
United States, WA, Richland
Joined May 2009
If you've seen the bulb pipetts used for C.A. -- you've got a source of tubes. Also called C.A. Applicators.
http://www.hobbyking.com/hobbyking/s..._Reg_1pc_.html
scott page is offline Find More Posts by scott page
Old Dec 07, 2012, 05:07 AM
IceWind is offline
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
They are Plastic.
Example:
IceWind is offline Find More Posts by IceWind
Old Dec 07, 2012, 09:02 PM
Joined Feb 2012
try 'antenna tubes' that 1/10 cars/buggies use:
http://www.ebay.com.au/sch/i.html?_t...at=0&_from=R40
Old Dec 07, 2012, 10:10 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Can you recommend a proven tube that is acceptable?
Clear plastic is generally OK but it would be well to test.
Daedalus66 is offline Find More Posts by Daedalus66
Old Dec 08, 2012, 05:50 AM
Nelapaty is offline
Find More Posts by Nelapaty
KK4NZS
Nelapaty's Avatar
Virginia
Joined Sep 2006
I tested couple of clearplastic tubes last night with the microwave test and no they didnot get warm or hot..
I had some white plastic tubes that came with a plane for antenna wire and boy they were really warm to touch after the microwave test..
Nelapaty is offline Find More Posts by Nelapaty
Old Dec 08, 2012, 06:02 AM
Joined Feb 2012
the white ones got hot?.. hmm.. thats a worry...
as frequency gets higher, attenuation (absorbtion) increases..
what might be ok at 27MHz, could be useless at 2.4GHz..
fortunately, a microwave oven IS 2.4GHz.. making it the best test.
Old Dec 08, 2012, 07:19 AM
u2builder is offline
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Ah, so this is why it may be OK to do this with 72 MHz as I have done before but it may not work with 2.4 which in my case it most assuredly did not and almost cost me my quad.
u2builder is offline Find More Posts by u2builder
Old Dec 08, 2012, 07:42 AM
Joined Feb 2012
it might still have a negative effect at 72M, but not as noticable.
same thing happens with coax cable, as the frequency gets higher, the cable absorbs more RF.
one would hope those plastic antenna tubes that get sold for buggies would be 'RF transparent'.
Old Dec 08, 2012, 08:00 AM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
As someone who is relatively new to 2.4, I have been wondering about the proper position for the antenna. With my 72 system of course the antenna comes straight out of the top of the radio, and based on the way I hold the radio I'd say maybe it is somewhere between horizontal and 30 degrees up from horizontal.
The 2.4 Frsky radio has a "joint" in it that allows it to be more vertical. When I was doing my "range testing" it did seem that a more vertical orientation gave me more range. What gave me a huge amount of additional range in range checking was holding the transmitter at head level.
Anyway, what is the optimum orientation of the antenna with respect to the ground. Does it vary with how high you fly? Does it matter?
Mini-Review The video for FrSky 2.4Ghz Chase Wu Radios 0 Dec 16, 2009 01:18 AM
Discussion Realflight G5 Combat so far so good! splitpilot Simulators 0 Nov 22, 2009 06:36 AM
Discussion So far... So good rikks Mini Helis 35 Feb 17, 2006 12:42 PM
Aerofly Deluxe so far so good! Gary Morris Simulators 5 Aug 19, 2005 07:23 AM
Schulze 18.46K v7.02 - so far, so good! Jason M Electric Heli Talk 4 Aug 11, 2002 01:25 AM
