Old Dec 01, 2012, 03:13 PM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
Mine is already set to that and has been from the very start. As far as I know, the module beeps once when it finds the receiver, then you can see the signal strength and whatnot on the LCD.
Ah well, I'm gonna have to remove the receiver and put a different one on this quad I think.
WiseDuck is offline Find More Posts by WiseDuck
Old Dec 02, 2012, 02:24 PM
davecrash is offline
Find More Posts by davecrash
Fly now crash later
davecrash's Avatar
Canada, ON, Newmarket
Joined Nov 2006
After some more reading I think I'm going to get one of these. It would be awesome if we could get RSSI out of channel 7 for FPV. Just saying incase the powers that be are listening for future upgrades. I have been reading about a diy unit but don't see it anywhere. Was this discontinued. I have a diy Assan in a 7CAP that wasn't moduler. Otherwise I may just wait for the new 9x to come out.
davecrash is offline Find More Posts by davecrash
Old Dec 02, 2012, 04:35 PM
PyroMan is offline
Find More Posts by PyroMan
PyroMan's Avatar
United States, KY, Paducah
Joined Mar 2011
Originally Posted by Rotozuk View Post
What are your aircraft worth?
FrSky telemetry is the best bang for the buck when you consider how reliable the system has proven to be in the real world.
I have not had a single glitch or failsafe event since converting. This is IMPORTANT to me as some of my planes are large enough and fast enough to be lethal, I'm not willing to take the chance with inferior radio systems.
-Wayne
p.s. I'm biased as I do sell FrSky, but I switched over to the system long before I considered selling it.
My aircraft aren't always worth much. I do a lot of scratchbuilt foamies so the majority of my planes only cost like $5 max for the airframe. I do have a few nicer planes that have JR rx's in them, but other than that I use the cheap corona rx's that I think are something like $10 if I remember right and a few other brands that I've got for cheap in the FS/W threads.
I should've asked this earlier . . .. Are the only receivers that FrSky receivers the only brand of receiver that the FrSky modules are compatible with?
PyroMan is offline Find More Posts by PyroMan
Old Dec 02, 2012, 05:05 PM
Daedalus66 is online now
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Originally Posted by PyroMan View Post
Are FrSky receivers the only brand of receiver that the FrSky modules are compatible with?
Yes.
Daedalus66 is online now Find More Posts by Daedalus66
Old Dec 02, 2012, 05:10 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Originally Posted by WiseDuck View Post
I always use PCM, never tinkered with the settings on my transmitter. I will use PCM on my 4ch receiver, I use PCM on the rest.
I think you must mean PPM, as 2.4 modules simply don't work with PCM.
Old Dec 02, 2012, 06:20 PM
scott page is offline
Find More Posts by scott page
ຮັກລູກຊາຍຫລາຍ
scott page's Avatar
United States, WA, Richland
Joined May 2009
If it's not a FrSKY module you want - and your only priority it cheap receivers run from a module that fits the JR module bay then you want to use FLYsky. This will work well with some very inexpensive receivers.
3 channel for $6 http://www.hobbyking.com/hobbyking/s...eiver_3Ch.html
6 channel for $9 http://www.hobbyking.com/hobbyking/s...er_6Ch_V2.html
or http://www.hobbypartz.com/79p-r6b-receiver.html
8 channel for $9 http://www.hobbyking.com/hobbyking/s...eiver_V2_.html
or
http://www.hobbypartz.com/79p-r8b-receiver.html
The only trick will be to find the FLYsky module. Hobby King doesn't have them (that I can find) and leadershobby doesn't have them (that can find).
Lots of guys that bought the Flysky 9x have the modules because they have replaced them with FrSKY modules... so you can probably find one virtually unused for little money. The problem with the turnigy9x -- which is the same radio -- is that they had those modules hard wired into the unit so cutting the antenna coax was necessary to remove the module.. rendering the module useless to most folks.
scott page is offline Find More Posts by scott page
Old Dec 02, 2012, 08:39 PM
PyroMan is offline
PyroMan's Avatar
Joined Mar 2011
or
Awesome, thanks for the info. I think one of these days I will get a spektrum module as I would like to have access to the Spektrum Bricks. . . but that's a while down the road. . . .
Anyway, is this a flysky module like you're talking about? http://www.ebay.com/itm/FS-TH9X-B-Mo...item3f08818782
That's about $21
Old Dec 02, 2012, 08:54 PM
KC is offline
KC
Find More Posts by KC
KC
Registered Loiterer.
KC's Avatar
United States, FL, Orlando
Joined Sep 2006
Yes. That's the one. You could also ckeck out the Radio FS classifieds for modded Flysky modules as well. The Rx's also go up for sale often.
KC is offline Find More Posts by KC
Old Dec 02, 2012, 10:21 PM
ຮັກລູກຊາຍຫລາຍ
scott page's Avatar
Joined May 2009
That's about $21
I'll confirm.. that's the correct module.
Old Dec 02, 2012, 11:34 PM
rcroadtrain is offline
Find More Posts by rcroadtrain
rcroadtrain's Avatar
Australia, NSW, Marsfield
Joined Feb 2012
just found this thread, apologies for asking questions that have (probably) already been answered..
Ok, I'm about to upgrade my 9x to FrSky..
ordered the bits from HKing, the telemetry module, 8ch telemetry RX etc...
Im flying a quad, (Naza, escs only, no servos..) do I select FS or HS mode?
and,
How do I get RSSI out of this receiver?
the blurb with the D8R-II mentions 'upgrade'... ??
Thanks!!
rcroadtrain is offline Find More Posts by rcroadtrain
Old Dec 03, 2012, 05:51 AM
IceWind is offline
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
Yep, you'll need to flash it to have the RSSI out.
If you want to have RSSI without hassle just get a D4R-II RX and all it takes it to put a jumper between two pins.
IceWind is offline Find More Posts by IceWind
Old Dec 03, 2012, 05:55 AM
Kilrah is offline
Find More Posts by Kilrah
Happy FPV flyer
Kilrah's Avatar
United Arab Emirates, Dubai
Joined Sep 2006
Or D8R-XP.
BTW all 3 should be reflashed with the new firmware if used in RSSI+CPPM mode anyway.
Kilrah is offline Find More Posts by Kilrah
Old Dec 03, 2012, 06:07 AM
IceWind is offline
IceWind's Avatar
Joined Feb 2005
All 3? You mean the D4R-II RX as well?
Old Dec 03, 2012, 06:08 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Yes, even D4R-II, because in CPPM mode it outputs 8 channels and can be plagued by 18ms issue, IF using more than 6 channels.
renatoa is offline Find More Posts by renatoa
Old Dec 03, 2012, 06:23 AM
Joined Feb 2012
isnt the D4R-II a 4ch unit?
the one I got is the D8R-II plus.. I need 7channels for my quad..or at least 6...
flashed with new firmware? hmm....
from what Im reading, my Rx should already have been upgraded...
What bits do I need for any future upgrades?
Im looking in HKing's site, and Im seeing a FrSky USB cable, and a Telemetry Reciever upgrade USB/Serial lead interface ..do I need both?
Mini-Review The video for FrSky 2.4Ghz Chase Wu Radios 0 Dec 16, 2009 01:18 AM
Discussion Realflight G5 Combat so far so good! splitpilot Simulators 0 Nov 22, 2009 06:36 AM
Discussion So far... So good rikks Mini Helis 35 Feb 17, 2006 12:42 PM
Aerofly Deluxe so far so good! Gary Morris Simulators 5 Aug 19, 2005 07:23 AM
Schulze 18.46K v7.02 - so far, so good! Jason M Electric Heli Talk 4 Aug 11, 2002 01:25 AM
