Old Nov 30, 2012, 03:13 PM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Not compatible, you must check the orange hk dsm compatible module to enter in the realm of plastic fantastic $6 receivers.
renatoa is online now Find More Posts by renatoa
Old Nov 30, 2012, 03:28 PM
scott page is offline
Find More Posts by scott page
ຮັກລູກຊາຍຫລາຍ
scott page's Avatar
United States, WA, Richland
Joined May 2009
Originally Posted by PyroMan View Post
Hello,
I have been flying 72mhz for close to two years now and I have been thinking about upgrading to 2.4ghz. I don't really have any problems with 72mhz as I have a synthisized module for my JR8103 so I can fly on any channel and not deal with xtals. What really bothers me is the long antennas on both the rx and the tx.
So I have heard the name FrSky quite a bit and decided to look at this thread. Is the FrSky 2.4ghz module for JR compatible with the $6 HK 2.4ghz rx's? Also is it compatible for BNF models?
I'm completely new to 2.4ghz so I don't know much about it and I may be asking stupid questions
Also, what's the average range when using one of these modules and one of those cheap HK rx's?
Nicholas
The Turnnigy 9x radio will accept the FrSKY DJT nodule http://www.alofthobbies.com/jr-trans...ry-module.html (in the USA)
Note -- there are two different companies at play here.
FLTsky makes the transmitter knows as the Turnigy 9x
FrSKY (pronounced Freesky) makes the modules and telemetry sensors.
So...
I'll go out on a limb and simply make a recommendation.
Buy a Hobby King http://www.hobbyking.com/hobbyking/s...arehouse_.html and pull the transmitter module.
Buy a Smartieparts card to put in that transmitter so you can connect the transmitter to the computer and change the POS (Piece of Stuff) firmeware that it comes with for some really exciting firmware like er9x or open9x. See http://9xforums.com for more information there.
Pitch the module the transmitter came with. Buy the http://www.alofthobbies.com/jr-trans...ry-module.html DJT and use the ACCST protocol for your models. It's comparable with FASST. For 8 channel receivers use http://www.alofthobbies.com/frsky-d8...telemetry.html For 4 channel receivers use http://www.alofthobbies.com/frsky-d4r-ii.html
When you are ready you can add telemetry sensors to these receivers.
The FrSKY system is not as cheap as the FLYSKY --- but it's infinately better.
The upgrading to the better software in the transmitter sounds frightening -- it's not and it's amazing how much transmitter you get. http://www.smartieparts.com/shop/ind...roducts_id=331 If you're electronnically inclined you could do the same as the smartieparts board -- but I'm not really inclined to solder on the circuit board -- and this solution is a set in place and screws to hold.
Last option you might consider is the hobby king backlight for the Turnigy 9x It's only about $5 -- but I don't know if it's in the U.S. warehouse... but next time you order from China.
I know that's alot of stuff in a short post -- but it represents a couple years of trial and error for me and hundreds and hundreds and hundreds of posts read.
I highly suggest using Aloft Hobbies based here in the U.S. because the prices are comparable to China alternatives, the shipping is very fast. and customer service is remarkable.
scott page is offline Find More Posts by scott page
Old Nov 30, 2012, 04:23 PM
PyroMan is offline
Find More Posts by PyroMan
PyroMan's Avatar
United States, KY, Paducah
Joined Mar 2011
Thanks for the info, but I'd like to stick with my JR8103. The main reason is because I don't want to have to switch all of my 72mhz planes over to 2.4ghz. What I want is to have a 2.4 module when I'm flying 2.4ghz and when I want to fly 72mhz I'll just pop in my 72mhz module.
So if the FrSky JR module isn't compatible with the orange hk receivers, then what is?
Nicholas
PyroMan is offline Find More Posts by PyroMan
Old Nov 30, 2012, 04:32 PM
KC is offline
KC
Find More Posts by KC
KC
Registered Loiterer.
KC's Avatar
United States, FL, Orlando
Joined Sep 2006
HK will be re-releasing the Orange DSM2/X module soon. These will fit right in the 8103 module bay and will fly all the spektrum/compatible orange Rx's.
KC is offline Find More Posts by KC
jj604 is offline
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Just get one of these.
It won't be FrSky but DSM2/X which is what you want I think. That way you have your existing 72 or DSM2/X to work with the Orange receivers by changing the module.
The recommendation to convert to FrSky seems to be overkill for what you are seeking IMO. Folks are understandably enthusiastic about FrSky on this forum (I am!) but I don't think converting makes sense in your situation.
http://www.hobbyking.com/hobbyking/s...dProduct=24656
Nicholas
jj604 is offline Find More Posts by jj604
Qhobby is offline
Find More Posts by Qhobby
Joined Nov 2012
HK should be getting back above water with the Orange Spektrum DSM2 / DSMX compatible JR module. Should drop in to your 8103 and work.
I have some from the first shipment and have tested them in a JR 9303 & 10X systems. Bound to HK Orange 6 & 9 channel receivers and to Spektrum DSMX 4, 6 and 8 channel receivers.
No problems what so ever. Should get some flight time this weekend.
Qhobby is offline Find More Posts by Qhobby
Old Nov 30, 2012, 04:54 PM
Kilrah is online now
Find More Posts by Kilrah
Happy FPV flyer
Kilrah's Avatar
Switzerland
Joined Sep 2006
Spektrum DSM radios.
Kilrah is online now Find More Posts by Kilrah
Old Nov 30, 2012, 05:59 PM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
IMO no one should recommend others to buy the Orange DSMX module.
It is known to be bad right now (ch2 glitches), and is there any guarantee that they will be able to fix it?
They only use a few GUID, and there is therefore the chance that you could shoot another Orange user down if he happens to be on the same one.
(The theory is that they did not reverse engineer the DSMX hopping sequence algorithm, which is a function of GUID. Instead they simply observed it for some GUID and used only those ones. How many did they copy? Who knows)
Pat MacKenzie
pmackenzie is online now Find More Posts by pmackenzie
Old Nov 30, 2012, 06:43 PM
jj604 is offline
ancora imparo
jj604's Avatar
Joined Jul 2005
Thanks, pat. That's useful info.
So the only sensible option for a JR user who wants to use a bunch of DSM2 receivers and not change their whole system to FrSky is a proper Spektrum DSM2 JR module which is now retailing at $109 and won't give you DSMX.
John
Pat MacKenzie
Old Nov 30, 2012, 06:48 PM
pmackenzie's Avatar
Joined Dec 2002
All of the BNF will work with DSM2.
If you are a 9X custom firmware user then the module from a DX4e will work fine and supports DSM2, DSMX and model match. But only 6 channels
Pat MacKenzie
Old Nov 30, 2012, 11:57 PM
ຮັກລູກຊາຍຫລາຍ
scott page's Avatar
Joined May 2009
Nicholas
http://www.horizonhobby.com/products...ble-SPMMSJR720
Old Dec 01, 2012, 03:36 AM
kristaps_r is offline
Find More Posts by kristaps_r
kristaps_r's Avatar
Latvia, Riga
Joined May 2010
Originally Posted by RENATOA View Post
But this way you busted the module upgrade functionality... true, not so often required as for receivers.
I cut the small connector wire for telemetry sensor hub. RC module still upgradeable.
kristaps_r is offline Find More Posts by kristaps_r
Old Dec 01, 2012, 09:10 AM
PyroMan is offline
PyroMan's Avatar
Joined Mar 2011
Wow. I guess I though it would be a lot cheaper than $100 to convert to 2.4ghz. Since I don't have that much to spend right now, I'll guess I'll wait…
Thanks everyone for all the help, URLs, and the advice. I really appreciate it.
Old Dec 01, 2012, 09:26 AM
KC is offline
KC
KC
KC's Avatar
Joined Sep 2006
Most people wanting just the spek module will sell the Rx for $75 and Net the module for $35-45 shipped... That's when they are in stock, of course.
You may also check the Radio FS forum. The module will come up for sale every once in a while for $65-$85 usually.
Old Dec 01, 2012, 10:22 AM
debianhot is offline
Find More Posts by debianhot
RC Soarer & wheel re-inventer
debianhot's Avatar
Antarctica
Joined Jul 2003
HKs orange line equivalent (all backordered )
http://www.hobbyking.com/hobbyking/s...mpatible_.html
$29.99(backordered) plus
http://www.hobbyking.com/hobbyking/s..._Failsafe.html
$19.95 (backordered) plus
http://www.hobbyking.com/hobbyking/s..._Receiver.html
$11.83(backordered) = $ 61.77 plus shipping
Or switch to frsky insted...
$22.09 plus
$25.45 = $47.54 plus shipping .
debianhot is offline Find More Posts by debianhot
Mini-Review The video for FrSky 2.4Ghz Chase Wu Radios 0 Dec 16, 2009 01:18 AM
Discussion Realflight G5 Combat so far so good! splitpilot Simulators 0 Nov 22, 2009 06:36 AM
Discussion So far... So good rikks Mini Helis 35 Feb 17, 2006 12:42 PM
Aerofly Deluxe so far so good! Gary Morris Simulators 5 Aug 19, 2005 07:23 AM
Schulze 18.46K v7.02 - so far, so good! Jason M Electric Heli Talk 4 Aug 11, 2002 01:25 AM
