Old Nov 26, 2012, 09:46 AM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
Originally Posted by Cervanchez View Post
Its a 2200mah 2S. And check this guy out, he's pushing 80+ km with the 1 W booster.
http://www.rcgroups.com/forums/showthread.php?t=1439219
So, you are providing all your power needs for both your radio as well as your 1w booster with a 2200mah2S battery?
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Nov 26, 2012, 09:52 AM
Rotozuk is online now
Find More Posts by Rotozuk
Rotozuk's Avatar
United States, CA, Novato
Joined Sep 2003
Originally Posted by mihlit View Post
From FrSky Facebook:
"""FrSky 2nd generation Variometer (with S.PORT and BRIDGE function) is available. High precision up to 0.1 meter!"""
Anyone seen it? (Focus on "is available".) I did not find it in any eshop I know. There's no information on frsky-rc.com neither.
Yeah, not sure who posted that.. They have not been made available to us yet. I do know they were very close to being ready a few weeks ago, but they did not know when. I guess we might be able to get them in our next order...? I'll try and get them in for you all.
-Wayne
Rotozuk is online now Find More Posts by Rotozuk
Site Sponsor
Old Nov 26, 2012, 09:55 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Antenna less than booster.
Antenna: from 2 to 14dB = 12dB = 4x range
Booster: from 14 to 30dB = 16dB = 6x range (aprox)
renatoa is online now Find More Posts by renatoa
Old Nov 26, 2012, 10:10 AM
Kilrah is offline
Find More Posts by Kilrah
Happy FPV flyer
Kilrah's Avatar
Switzerland
Joined Sep 2006
FrSky spec is 60mW = 18dBm, not 14
Although I found that actual output power from FrSky modules could vary quite a bit, and some are indeed closer to 30mW.
Kilrah is offline Find More Posts by Kilrah
Old Nov 26, 2012, 11:00 AM
Cervanchez is offline
Find More Posts by Cervanchez
Habitual Line Stepper
Cervanchez's Avatar
United States, WA, Redmond
Joined Dec 2011
Yes, just regulating it down to 5V for the booster.
Cervanchez is offline Find More Posts by Cervanchez
Old Nov 26, 2012, 11:05 AM
Cervanchez's Avatar
Joined Dec 2011
Based on the cert that Renatoa posted a couple pages back, I calculated about 6.5 x range. But, yes, there are many other factors involved and ElCheapo obviously knows what he's doing. I'm not trying to set distance records, just trying to have a solid link within 1-2 miles.
Old Nov 26, 2012, 01:20 PM
Joined Sep 2007
1-2 miles, Ok, let do some math...
If ElCheapo would remove the 14dB antenna and booster tomorrow, then his range will be 80 / 4 / 6.5 = about 3km. Here are your 1-2 miles !
This is an achievable range with naked Frsky, I can certify myself, and some other who were able to reach 5km with the 5dB stick or the 7 dB patch, and , more important, good dipole antennas at receiver side. Or, 8km with CP antennas at both sides
Also, an important factor is to use 5.8GHz on video, not 1.3Ghz, which make your life a lot harder regarding video Tx filtering and RC-video separation.
Using a booster doesn't add safety, exactly the contrary !
Old Nov 26, 2012, 02:00 PM
Cervanchez's Avatar
Joined Dec 2011
Thanks, I was getting rssi beeps at 500-1000 ft sometimes without the booster on both my quads, one with 1.3 GHz video and one with 5.8. Now, with my initial testing I still got some beeps with my 1.3 quad, even with a lpf on the video. Haven't gotten any yet on the 5.8 quad. But, I was already thinking i should do more work on improving the frsky antennas and maybe switching the 1.3 quad to 5.8, since I have an extra 5.8 tx. The booster isn't really giving me a warm fuzzy feeling. It does add more possible failure points.
Old Nov 26, 2012, 02:31 PM
jhsa is offline
Find More Posts by jhsa
Flying a Chipmunk in Portugal
jhsa's Avatar
NRW, Germany
Joined Sep 2010
-Wayne
Wayne, Does this vario need the hub, or can it be directly connected to the receiver??
Joćo
jhsa is offline Find More Posts by jhsa
Old Nov 26, 2012, 02:47 PM
u2builder is online now
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Where does one find dipole antennas for FRSKY?
I did some range testing today with my FRSKY V8R7SP on a DJI 550 and 450. Both have Immersion 600 mW 5.8 TX on them. On the hex the VTX antenna is on top and the RX antenna is on the bottom, separated by the plates of the machine. On the quad they are both on the bottom and pretty close together. On both of these machines the controller blinks when the signal is lost. In both cases the motors were not powered up. In both cases the machine was on a plastic bucket about 30 inches above the ground. I pressed the button on the module on my radio to go to the range check mode (1/30 range). On the hex I got about 50 meters of range with the transmitter held at waist level and interestingly about 100 meters with the radio held above my head. I tried the 7dbi patch antenna and it seemed to give about 30 percent more range, but lost signal about 30 degrees to either side of the centerline when at maximum range and it was also sensitive to the vertical orientation of the patch. On the hex it made no difference whether the VTX was on or off.
On the quad the range was about 40 meters or less than half that of the hex. I could not unplug the VTX as it is on the same battery as the RX. Whether this accounts for the reduced range or the proximity of the VTX and the RX antennas (about 6") is not clear. It is probably the latter. I need to experiment. There is very little room on the quad to move things as I have the batteries on top.
I had read that having "straight" antennas at 90 degrees was best so I tried putting nylon control rod enclosures over the covered part of the antennas but not over the active element and oriented them at 90 degrees. This was not a good idea. In the quad it reduced the range to only about 10 meters, and in the hex to about 25 meters. I removed the plastic and the range came back to normal.
I would like to explore dipole antennas for the RX if someone could link me to some that would work. I don't think I am going to use the 7dbi patch as it is too sensitive to orientation and with goggles on I don't really know where I am "pointing".
u2builder is online now Find More Posts by u2builder
Old Nov 26, 2012, 03:02 PM
Joined Sep 2007
You can build yourself, check the 2.4GHz receiver dipole antennas thread, or buy the 40/60cm antennas from alofthobbies, they come now built as dipoles.
On a multicopter I would place both antennas vertical with tip pointing down to ground, in the middle of two opposite arms. These long fed antennas allows this placement. The 90 degrees theory is no more valid on platforms that are level 99% of time, it is for acro flight.
Old Nov 26, 2012, 03:17 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Yes, this is what I am trying to "train" them to do. But I will look into the dipoles from Aloft right now.
Old Nov 26, 2012, 04:09 PM
Cervanchez's Avatar
Joined Dec 2011
Are you saying this one is a dipole? If so, that might also add to why I got better results with my 5.8 quad. I have the 40 cm routed through a straw sticking up above the center plate. i saw the thread about making your own and was going to do that, but do these give the same results?
http://www.alofthobbies.com/40cm-receiver-antenna.html
Man, I need to study up on my antenna book...
Old Nov 26, 2012, 05:30 PM
Rotozuk's Avatar
Joined Sep 2003
Joćo
Yes, that is my understanding. Hopefully I'll find out more soon.
-Wayne
p.s. Thanks all for the orders.. Busy day today!!
Site Sponsor
Old Nov 26, 2012, 05:43 PM
Nelapaty is online now
Find More Posts by Nelapaty
KK4NZS / RP sUAS
Nelapaty's Avatar
Virginia
Joined Sep 2006
Renatoa is there a reason for the tip pointing down?, on my TBS Disco I have them both attached to the outside of the same nylon control rod tubing tx part facing up and telemtry part facing down. im using the 40cm antenna it actually improved my range.
Unfortunately I have 1280GHz video link. the stock antenna's were really bad I lost signal then I tried the 40cm antenna and everything was back to normal but Id like a little more range currently I can only go up to 643 meters which is like .4miles before my rssi starts beeping need to try a patch on the tx see if that helps..
Also what happens to telemetry when you add a booster to the tx lets say 500mw..
Nelapaty is online now Find More Posts by Nelapaty
Mini-Review The video for FrSky 2.4Ghz Chase Wu Radios 0 Dec 16, 2009 01:18 AM
Discussion Realflight G5 Combat so far so good! splitpilot Simulators 0 Nov 22, 2009 06:36 AM
Discussion So far... So good rikks Mini Helis 35 Feb 17, 2006 12:42 PM
Aerofly Deluxe so far so good! Gary Morris Simulators 5 Aug 19, 2005 07:23 AM
Schulze 18.46K v7.02 - so far, so good! Jason M Electric Heli Talk 4 Aug 11, 2002 01:25 AM
