Old Sep 27, 2012, 12:16 AM
JMP_blackfoot is offline
Find More Posts by JMP_blackfoot
JMP_blackfoot's Avatar
United States, OH, Galena
Joined Jul 2003
I tried two different servo types, with different results:
- Four older Hitec servos (purchased in 1994)
- Two HXT900 servo (purchased in 2010)
When connected to different receivers:
- Futaba FP-R114H (Single conversion 72 MHz)
- ACE Pro 810 (Double conversion 72 MHz)
- Hitec Micro 05 (Single conversion 72 MHz, DSP)
- JR R720UL (Synthesized 72 MHz, DSP)
- FSky V8R4 (2.4 GHz)
- FrSky D6FR (2.4 Ghz, telemetry),
both servo types twitched a switch-on.
If the signal wire was pulled from the connector, the older Hitec servos did not twitch at all at switch-on, but the HXT900's twitched as before.
I then tried to connect the signal wire of the HXT900's to ground, they still twitched at switch-on.
Conclusion: disconnecting the signal wire will prevent some servos (maybe of older technology) from twitching at switch-on, but some others will not stop twitching, signal wire connected or not, or even grounded.
Twitching is greatly reduced with the older receivers (Futaba FP-R114H and Ace Pro 810) if the transmitter is on before switching receiver on. These receivers use a simple shift register decoder which requires a very short initialising time and bring the servo back to the intended position almost instantaneously.
For the other receivers (DSP or 2.4 GHz), having the transmitter on before the receiver does not really reduce the twitching.
Solution looks like applying power to servos after transmitter and receiver.
JMP_blackfoot is offline Find More Posts by JMP_blackfoot
Old Sep 27, 2012, 12:31 AM
A10FLYR is offline
Find More Posts by A10FLYR
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
I tried this out tonite. If reciever was only bound, servos would jump on switch on. After setting failsafe they would not jump when switched on...you might try that.......
A10FLYR is offline Find More Posts by A10FLYR
Old Sep 27, 2012, 12:53 AM
scott page is offline
Find More Posts by scott page
ຮັກລູກຊາຍຫລາຍ
scott page's Avatar
United States, WA, Richland
Joined May 2009
Well Played!
scott page is offline Find More Posts by scott page
Old Sep 27, 2012, 01:21 AM
SteveM is offline
Find More Posts by SteveM
Joined Dec 2002
Just tried setting f/s......... no difference .
I'm going to independantly power the flap servos at least, as these linkages are at most risk, being bottom hinged, not able to move up.
I have plenty of 2mm gold connex, so no pbm.
Makes me wonder what battering my throttle linkages are getting in my ic models, ramming against the end stops!
Many thanks for your interest, steve
SteveM is offline Find More Posts by SteveM
Old Sep 27, 2012, 01:22 AM
SteveM is offline
Joined Dec 2002
Whoops...double post!
Old Sep 27, 2012, 01:55 AM
Kilrah is online now
Find More Posts by Kilrah
Happy FPV flyer
Kilrah's Avatar
United Arab Emirates, Dubai
Joined Sep 2006
Originally Posted by SteveM View Post
It is not consistent.....there is a very brief delay in tx/rx synching, during which all servos will move to a random position away from neutral, then immediatly back.
D8R II plus rx.....does it every time.
All my flavours of frsky receivers do this. (9 in all)
It is not good, Steve
Never seen that on any of my frsky RXs. Not even if I power the rx up before the radio. I'd check the servos indeed.
Kilrah is online now Find More Posts by Kilrah
Old Sep 27, 2012, 02:27 AM
SteveM is offline
Joined Dec 2002
Twitching
Kilrah,
".. I'd check the servos indeed."
In what way?......as above, happens on Futaba, GWS,Hitec,HXT,Corona, Turnigy,JR etc.
Same regardless of D8R, D8R-II, D8R-II plus.
What concerns me, is that I am yet to convert my Sceadu Heli over to Frsky in the near future, and that has very powerful expensive Futaba digitals on the swash!!
Better stock up on connectors/solder etc, otherwise I will be flinching every time I switch on
Steve
Old Sep 27, 2012, 02:48 AM
Happy FPV flyer
Kilrah's Avatar
Joined Sep 2006
Sorry, hadn't seen your post with the tests, wasn't present in my email notification...
Old Sep 27, 2012, 02:56 AM
SteveM is offline
Joined Dec 2002
Servo Twitch on power-on
That's OK.......as a last resort, have just emailed Eva to comment on what exists on the signal wires during this brief sync period......I guess there is nothing, and that the servos don't have anything meaningful to work with, so "throw a brief wobbly" (technical term!).
Will put this issue to bed, as there are far more interesting things to discuss than this "feature".
Rgds, Steve
Old Sep 27, 2012, 03:28 AM
Zeeland is offline
Find More Posts by Zeeland
Joined May 2012
Kilrah,
Steve
Hi Steve,
When you power-up your receiver, there will be a "reboot time". During this period, receiver will output nothing. Some of the clutter may cause analogue servo move to "random position".
When reboot is finished, the receiver start to output normal signal (or failsafe in case the Tx is power off). That's the "move back".
This is nothing to do with the Rx. Because all the receivers do have the reboot time.
For analogue servo it's very normal, because they are more sensitive to these clutter; but on digital servo, you won't see this happen.
e.g. in video you use Corona CS239, which jitters, if you try Corona DS239 (the digital version of the same servo), you will see no jitter at all.
So, your problem might be solved by replace those "jitter" with digital servo.
Just my $.02
Regards,
K
Zeeland is offline Find More Posts by Zeeland
Old Sep 27, 2012, 03:31 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Hitec HS55/81, Robbe FS550 / BMS380 / MG16 / here, in various gliders, all flavors on D8R, since alpha pre-production to current II Plus, no jumping, I can post video.
renatoa is offline Find More Posts by renatoa
Old Sep 27, 2012, 03:55 AM
Trevor_G is offline
Find More Posts by Trevor_G
Trevor_G's Avatar
Bedfordshire, UK
Joined Feb 2006
I have never seen this problem with a variety of analogue servos and FrSky Rx's.
It occurs to me that I power everything from a BEC on my ESC which gives a soft power on. A glider would presumably use direct battery power which would give a sudden, and possibly noisy, power on. A digital servo would wait until the supply is stable before attempting to move whereas an analogue would move as soon as it gets power.
Trevor_G is offline Find More Posts by Trevor_G
Old Sep 27, 2012, 04:07 AM
SteveM is offline
Joined Dec 2002
Zeeland,
YOU'VE HIT THE NAIL ON THE HEAD!!!!!
Just tried a couple of Corona digitals......all well-behaved at switch on, only once was the VERY slightest twitch observed.
Its funny....I was actually after digital slims for wings.....hk were out of stock for DS-239MG, so bought CS's instead.
Will keep these and pwr on after rx.
Many tks again for all your interest.....I think I have now worn this subject out.
Rgds , Steve
Old Sep 27, 2012, 04:11 AM
SteveM is offline
Joined Dec 2002
Trevor....just seen this...just looking for small electrolytic............
Old Sep 27, 2012, 04:22 AM
SteveM is offline
Joined Dec 2002
Only have 10 uf......no change
Mini-Review The video for FrSky 2.4Ghz Chase Wu Radios 0 Dec 16, 2009 01:18 AM
Discussion Realflight G5 Combat so far so good! splitpilot Simulators 0 Nov 22, 2009 06:36 AM
Discussion So far... So good rikks Mini Helis 35 Feb 17, 2006 12:42 PM
Aerofly Deluxe so far so good! Gary Morris Simulators 5 Aug 19, 2005 07:23 AM
Schulze 18.46K v7.02 - so far, so good! Jason M Electric Heli Talk 4 Aug 11, 2002 01:25 AM
