Romania, Dolj, Craiova
Joined Sep 2007
Well, we are talking about 3 different product lines:
- the actual line, that is on sale right now, you said they are speced as 4.8-6V, probably you are right, and I can't speak about them - the near future (this week ?) telemetry enabled line, which are speced as 4-7.2V - the future HV (High Voltage) line, non telemetry only, so far, probably on sale in August, rated as you wrote above, up to 16V. There is a very small possibility that the 8ch receiver from HV line have dual power port, as Hitec. There is no HV and telemetry announced so far, as I know. |
USA, CA, San Francisco
Joined Feb 2004
The output from your soundcard may be a bit marginal. I don't have the DIY module handy to check, but if I had to guess I'd expect they're using a passive voltage limiter protecting a 3.3v logic input. Logical 1 for low-voltage CMOS is usually half the supply voltage, or 1.65v in the 3.3v case. You should check the MSP431 datasheet. = Mike |
Joined Sep 2007
See Robbe Futaba replacement antennas, two for 10 Eur or so.
http://www.europemodels.eu/src_R606-6014/ |
Latest blog entry: JRSky - birth of a dream radio
It works with Spektrum, Futaba and Hitec modules. No response so far from the FrySky module. Quote:
Ari. |
Joined Sep 2007
A guess that 1.65V is the Frsky pulse trigering level, thus an input swing under this value could be not sensed.
Joined Feb 2004
I would use a level shifter of some sort to convert your 0/1.2v swing up to 0/3.3. If you use an op-amp, be sure to configure for plenty of hysteresis, as the range for logic zero is fairly small. Alternatively, a level shifter specifically designed for interfacing between 1.2 and 3.3v circuits would do the job. http://www.maxim-ic.com/app-notes/index.mvp/id/3007 It would be good to hear from Jonathan or one of the other FrSky technical folks re: the actual input levels supported by the module. = Mike |
United States, MD, Lusby
Joined Nov 2003
Are two-way modules/receivers on their way to the dealers? None of the ones I've visited online have the telemetry systems in stock. I am eagerly awaiting these products, and like others don't want to spend money on one-way tx modules at this point.
The main point is that the module took the inverted JR logic and didn't care... Nice. Martin |
I believe they are ready. It's worth waiting a little longer.
Latest blog entry: Polaris Aileron Pushrods
Joined Mar 2009
That should be above 1.65V. Regards! Eva |
| Thread Tools | |
| Mini-Review The video for FrSky 2.4Ghz | Chase Wu | Radios | 0 | Dec 16, 2009 01:18 AM |
| Discussion Realflight G5 Combat so far so good! | splitpilot | Simulators | 0 | Nov 22, 2009 06:36 AM |
| Discussion So far... So good | rikks | Mini Helis | 35 | Feb 17, 2006 12:42 PM |
| Aerofly Deluxe so far so good! | Gary Morris | Simulators | 5 | Aug 19, 2005 07:23 AM |
| Schulze 18.46K v7.02 - so far, so good! | Jason M | Electric Heli Talk | 4 | Aug 11, 2002 01:25 AM |
