Old Jun 30, 2012, 01:22 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Let RSSI as is for start.
For flying visually you should get no beeps, any beep shows an antennas (placement) issue.
For FPV, if you get beeps under 2km, again I would investigate antennas. With good stock antennas first beeps should occur at 2.5-3km.
Only when you reached this threshold you should think lower RSSI.
From factory they are set at 45-42-40dB, start decrease them by 3dB maximim, fly, and if you feel the need to push the margin more...
renatoa is offline Find More Posts by renatoa
Old Jun 30, 2012, 05:06 AM
renatoa is offline
Joined Sep 2007
Originally Posted by scott page View Post
Nicely done. I'd like to see you put that into a blog post for easier location and reference in the future. I'm afraid that nugget of wealth will be lost among all of the posts here.
Added to Migrations section of links index in first post.
This is the second 6ex migration, the first is hack module based, and have its own thread, lots of technical details
Old Jun 30, 2012, 08:53 AM
flye is offline
Find More Posts by flye
Joined Sep 2010
I am a bit confused.
Is it on screen 10 as in the photos that I set it?
flye is offline Find More Posts by flye
Old Jun 30, 2012, 06:29 PM
jhsa is offline
Find More Posts by jhsa
Flying a Chipmunk in Portugal
jhsa's Avatar
NRW, Germany
Joined Sep 2010
Just a little report on my servo jitter problem..
Moved both anttenas outside the plane and problem solved.. no more jitter on the aileron servos. didn't have any glitch also..
I have the DHT module and today I was flying and trying to look at the RSSI on the radio screen. When the plane was to my left side (tip of the antenna pointing at the plane), and about 150 to 200 metres away, sometimes I saw the RSSI go down as far as 48. Is that normal?
also a friend's quad suddenly lost control.. he found out that the antenna coax cable came out of the ??U-FL?? connector in the module.
jhsa is offline Find More Posts by jhsa
Old Jul 01, 2012, 12:51 AM
renatoa is offline
Joined Sep 2007
1) this is in all RC manuals, the position to avoid !
2) Yes, when antenna point to the plane, it's a black hole of signal.
3) seems this check must be added to preflight checklist, for Chinese gear
Old Jul 01, 2012, 01:14 AM
scott page is offline
Find More Posts by scott page
ຮັກລູກຊາຍຫລາຍ
scott page's Avatar
United States, WA, Richland
Joined May 2009
This signal hole is much more serious -- or has a great magnitude with a 5db antenna than the stock 2db antenna.
Knowing this is also a way to find a lost model. Point the antenna out away from the transmitter and move back and forth in a sweeping motion. When the RSSI drops a bit -- it's pointing at the model (more or less). Keep checking as you proceed and you'll walk right to the model.
scott page is offline Find More Posts by scott page
Old Jul 01, 2012, 03:38 AM
jhsa is offline
jhsa's Avatar
NRW, Germany
Joined Sep 2010
Yes, i know about the holes
That was a test I was doing to check the RSSI. I just asked if it was normal reading 48.
And when I do a range test, I always check how far I can go also with the antenna pointed at the plane..
Sorry but I don't trust the frsky tx antennas, even less after yesterday. see my post above.. that cable should be well crimped and not come out of the connector like that..
Old Jul 01, 2012, 03:43 PM
xairflyer is offline
Find More Posts by xairflyer
Bleriot's R Us
xairflyer's Avatar
Ireland, Donegal
Joined Nov 2003
I would agree on the antennas, I broke the swivel on mine and fitted the one that came with my DHT-U and have had occasional unexplained beeps, replaced it recently with a new one and had 5 flights today an never heard a peep!
xairflyer is offline Find More Posts by xairflyer
Old Jul 01, 2012, 10:43 PM
ຮັກລູກຊາຍຫລາຍ
scott page's Avatar
Joined May 2009
I consider (completely subjective) 48 to be near my threshold for an alarm. I think mine are @ 40.
May I ask if you had a 2db antenna or 5db antenna?
Old Jul 02, 2012, 06:44 AM
Bleriot's R Us
xairflyer's Avatar
Ireland, Donegal
Joined Nov 2003
I bought a 5db one to see if it would help extend the range of my house wifi but made no difference, no matter which way I orientated it
Old Jul 02, 2012, 08:03 AM
jhsa is offline
jhsa's Avatar
NRW, Germany
Joined Sep 2010
Hi Scott, I have the original 2db antenna..
Old Jul 02, 2012, 08:05 AM
jhsa is offline
jhsa's Avatar
NRW, Germany
Joined Sep 2010
Did you replace it with a new frsky antenna, or with a different brand?
If another, could we please have the link?
Thanks a lot..
Joćo
Old Jul 02, 2012, 08:09 AM
kwmtrubrit is online now
Find More Posts by kwmtrubrit
Be an organ donor
Little Rock, AR. U.S.A via U.K
Joined May 2004
Well Cr#p!! I finally decided to enter in to the 2.4 realm a couple of months ago and purchased the frsky module for my Futaba 9C Super, plus a couple of recievers (a 6 and 8ch). Finally, yesterday I put the 6ch in to my E-Flite T34 and all appears to have gone well. I deided to check what's been going on here, and is see there are some issues I had not seen before. Oh well, another day in paradise.
kwmtrubrit is online now Find More Posts by kwmtrubrit
Old Jul 02, 2012, 08:15 AM
Mike Seale is offline
Find More Posts by Mike Seale
f5b-uk
Mike Seale's Avatar
United Kingdom, Dorset
Joined May 2002
Originally Posted by kwmtrubrit View Post
Well Cr#p!!
I wouldn't worry about it. All brands have issues and at least you can read here what to expect. Most of us are using FrSky with 100% reliability and no modifications or fixes.
Mike Seale is offline Find More Posts by Mike Seale
Old Jul 02, 2012, 09:09 AM
Bleriot's R Us
xairflyer's Avatar
Ireland, Donegal
Joined Nov 2003
Thanks a lot..
Joćo
Had suspected the DJT module so I bought a new one and used the antenna of that. Still have to fly the model that was more prone to giving me beeps first before I can confirm totally cured.
Mini-Review The video for FrSky 2.4Ghz Chase Wu Radios 0 Dec 16, 2009 01:18 AM
Discussion Realflight G5 Combat so far so good! splitpilot Simulators 0 Nov 22, 2009 06:36 AM
Discussion So far... So good rikks Mini Helis 35 Feb 17, 2006 12:42 PM
Aerofly Deluxe so far so good! Gary Morris Simulators 5 Aug 19, 2005 07:23 AM
Schulze 18.46K v7.02 - so far, so good! Jason M Electric Heli Talk 4 Aug 11, 2002 01:25 AM
