Joined May 2010
Hello
I am trying to get V8 DIY TX module to work with my graupner mx-16s. Here is what i do: 1. With my graupner TX turned off i plug audio cable (stereo) to DSC socket, so TX starts working in DSC mode. 2. I double-check that TX is in PPM mode. 3. I connect audio cable (I've tried tip and ring) to ppm wire of DIY module 4. I connect + and - to charger socket of the TX and it powers DIY module nicely. It even binds with my 2 receivers. But module doesn't seem to see ppm signal. Diode in RX is constant red, in TX module is constant orange but nothing works, no servo movement, no engine beeping, nothing. What am I doing wrong? I am sure ppm signal is coming out of connected audio cable, because I'am using the same cable to connect my TX to computer to play FMS with smartpropoplus and its working like a charm either in ppm or spcm mode. Have any of you had similar issues? I hope i dont have busted V8 DIY TX module, as sending it back to China from Poland would probably cost alot ![]() Any kind of help would be really appreciated
Since the FrSky module is very tolerant of signal polarity and pulse count a simple PNP inverter may be all that's needed to get a suitable signal from the DSC output. But first take a look with an oscilloscope to check the waveform whilst connected to the module. It seems I was hasty in my comment regarding needing an active drive signal source. It appears my module has a fault partially shorting the PPM signal. Diagnosis is ongoing. FCC documents suggest the module input is direct to the Atmel CPU running at 5v -- Steve |
I still don't see the failsafe thing as an improvement. In a sense you can constantly reset the failsafe everytime you knowingly or unknowingly hit the F/S button. I had planned to get the telemetry module once available but I consider this "feature" to much of an accident waiting to happen so won't be getting it.
Joined Mar 2009
Hi, Yes, your words make sense. But I would like to clarify that we have already made improvement to our ready-to-release telemtry system as well as instruction manual, which can avoid the unknowingly hit. This is the new statements in instruction manual, for your reference: 8 Failsafe The receiver integrates the failsafe function for all channels. To set failsafe positions, press briefly(less then 1 second) the “F/S Range” button of the Receiver, the Tx module will make a long “beep” indicating the failsafe position is remembered by the receiver. Many thanks and best regards! Eva FrSky Electronic Co., Ltd |
Joined Mar 2009
FrSky Two Way manual and protocol
Dear all,
Please kindly find FrSky Two Way System's manual and protocol as attached. We have revised the contents, thanks for your sincere suggestions. two-way-manual two-way-protocol Your thoughts and feedbacks are highly appreciated. Many thanks and best regards! Eva Frsky Electronic Co., Ltd Website: www.frsky-rc.com E-mail: evafrsky@gmail.com MSN: liuyunjieeva@hotmail.com Skype: evaliu0409 |
Eva, I'm sorry to hear that, I for one much preferred the old method where the failsafe was set at the transmitter! That was an unprecedented feature, very practical, as failsafe could be set to the ideal trim, in flight. I dont see how anyone could accidentally press a small recessed button. By the same argument, if it was so easily done, this could inadvertently switch to low power too. Honestly, take it from an actual Frsky flyer (since the early beta releases), this 'accidental button-pushing' just doesnt happen!
Cheers Phil Quote:
Romania, Dolj, Craiova
Joined Sep 2007
Latest blog entry: JRSky - birth of a dream radio
Melbourne, Australia
Joined May 2006
I don't understand why you would care about trim in failsafe given that the orientation of the aircraft when failsafe occurs is completely arbitrary (unless you only ever fly easy circuits or circle in thermals I guess)? For me the most critical aspect of failsafe is cutting the motor and for that, in-flight trim is not an issue either.
I do understand that for applications like flying wings where the Rx is buried and hard to get to, being able to adjust the failsafe from the Tx alone could be useful. |
S.F. Bay Area
Joined Aug 2002
FrSky,I think you have missed a Giant opportunity here.A simple button sequence can provide security against the accidental button push. Sorry, but those that are in fear of pushing a button should prolly stay home. And if it turns out there is a 'chance' of a button being pushed by incidental contact,put a ring around it for crying out loud. Skies. Jay. |
Joined Mar 2009
Dear Phil g, Renatoa, Jay and others:
The failsafe method I stated in #773 of the thread is the acquiescent version of FrSky's telemetry system. As this system is firmware updatable, the old failsafe method as Phil g prefered (we call it version B for short) is also available. That means you can change to version B with great ease, if you are accustomed or prefer the version B. Thanks and regards! Eva |
| Thread Tools | |
| Mini-Review The video for FrSky 2.4Ghz | Chase Wu | Radios | 0 | Dec 16, 2009 01:18 AM |
| Discussion Realflight G5 Combat so far so good! | splitpilot | Simulators | 0 | Nov 22, 2009 06:36 AM |
| Discussion So far... So good | rikks | Mini Helis | 35 | Feb 17, 2006 12:42 PM |
| Aerofly Deluxe so far so good! | Gary Morris | Simulators | 5 | Aug 19, 2005 07:23 AM |
| Schulze 18.46K v7.02 - so far, so good! | Jason M | Electric Heli Talk | 4 | Aug 11, 2002 01:25 AM |
