Joined Feb 2008
Dear Manuel
Could you explain more your mod with the capacitor I have the same trouble with a MX 16 and an Assan module and a baregraph flickering Thank's Quote:
brubru, Dont worry, I have 7 radios (yes its true
)And some of them have 2.4ghz "hacks" some are also dual hack with a switch. I see this flicker in voltage to most of my radios and different systems, so dont worry. I can see it in my JR PCM9XII radio with the Assan v2 JR Module and also with the FrSky JR module. If there where any problems having these moduls in radios that are module based just because the voltage flickers, then they wouldnt been sold. Of course you can solder a capacitor to reduce some of the voltage flicker, but it is not doing any harm. I also see this flicker in my WFT 09 radio with a Futaba Corona 2.4ghz module in the back. As you see these are all module based radios with modules made to use in these radios. I also have a Graupner mx-12 with a FlySKy "hack" in it, it also flickers a bit, but no problem at all, been flying it for over 1 year.. If you want to get ride of the flicker a bit, yes you can solder a capacitor, but if you are wooried about the module or radio to break because of this, dont panic, it wont break.. |
Oporto Portugal
Joined Sep 2007
Hello Brubru.
I had the problem of TX voltage bargraph flickering. First I installed 2X4,7 tantalum capacitors in the power input line (PCB) of the module in parallel with the already existing 40uf capacitor (I guess), and the problem disappear. After some use of the transmitter the battery went down a little and the problem came again, but with less variation, then I removed the 2X4,7uF and installed a 47uF tantalum capacitor and a .01uF ceramic capacitor to decouple RF. With these capacitors there are no problems. Regards, Manuel Silva |
Manuel Silva, its very interesting, that you did get jitter on servos first, then they went away with a capacitor, I havent noticed this in any of my radios with or without an internal "hack".
Maybee its something with the mx-16 and FrSky ? do you have the JR FrSKy module "hacked" into your mx-16 ? Sebbe.. |
The two-way flickers when receiving packets from the RX (remote). V8 I don't know yet. |
It could be a sign that it's time for a fresh TX pack or move to LiPo's. Has anybody tried that (new fresh TX pack) to see if I'm right or partially right here ? Also, if you are going to fit a capasitor, I'd use at LEAST 100uF and I'd buy a Low ESR type like designed for switching power supplies (more expensive). I'd fit it inside the radio, across the two power pins going to the module socket. The power pins are different positions for Futaba or JR, you need to get it right. Ground pin is the same. Martin |
Information on FrSKY 2.4, DIY Hack Module, Photos.
Got my FRSKY Hack Module today, for converting my Airtronics Vision 8SP radio fron 72mhz to 2.4 ghz. The module is very small. It should fit easily in most any 72mhz radio needing to be converted to 2.4ghz. The RF board has separate Led board with Binding button attached with a 148mm long wire harness. This will let you mount the LED and button where you want it.
I've attached a photo of the module. The basic size info is: RF Board 45mm x 35 mm x 6mm thick Power/PPM cable 85mm LED/Bind Board 25mm x 15 mm Led/Bind cable 148mm Antenna Cable 120mm with remote mount Antenna 110mm....87mm bent 90 degrees |
| Thread Tools | |
| Mini-Review The video for FrSky 2.4Ghz | Chase Wu | Radios | 0 | Dec 16, 2009 01:18 AM |
| Discussion Realflight G5 Combat so far so good! | splitpilot | Simulators | 0 | Nov 22, 2009 06:36 AM |
| Discussion So far... So good | rikks | Mini Helis | 35 | Feb 17, 2006 12:42 PM |
| Aerofly Deluxe so far so good! | Gary Morris | Simulators | 5 | Aug 19, 2005 07:23 AM |
| Schulze 18.46K v7.02 - so far, so good! | Jason M | Electric Heli Talk | 4 | Aug 11, 2002 01:25 AM |
