Old Apr 19, 2010, 09:35 AM
Beau0090_99 is offline
Find More Posts by Beau0090_99
Eden Prairie, MN
Joined May 2008
Jonathan,
That looks great. Can you make it possible to simply buy the case for those of us that have already purchased the V8FT? BTW, I really love my system, it has been very stable and easy to use.
Curtis
Beau0090_99 is offline Find More Posts by Beau0090_99
Old Apr 19, 2010, 10:04 AM
Chase Wu is offline
Find More Posts by Chase Wu
Joined Mar 2009
Originally Posted by Beau0090_99 View Post
Jonathan,
Curtis
Hi Curtis,
Thanks for using our products
We will offer our distributors some new cases(free) for changing by yourself if need, it's very easy. You could get the new case from your local distributor.
Meantime, if you have any other question or suggestion please tell us or PM us
Chase Wu
Chase Wu is offline Find More Posts by Chase Wu
Old Apr 19, 2010, 10:15 AM
Iflyj3 is offline
Find More Posts by Iflyj3
Dan Thompson (MP8K developer)
Iflyj3's Avatar
USA, KY, Paris
Joined Dec 2002
Chase,
Any idea when the telemetry system will be available?
Iflyj3 is offline Find More Posts by Iflyj3
Old Apr 19, 2010, 10:34 AM
fernandez is offline
Find More Posts by fernandez
Joined May 2009
Most of aftermarket brands, do not use proper memory buffer capacitor inside the receiver, wich is in my eyes essential for security and stability.
At the RX input voltage 6v-4.8v, normally there is a diode, to protect for +/- invertion, then regulated down to chipset voltage 3v3, there are some small smd capacitors remove ac noise, but do not act as a proper buffer.
I apply (solder) a goldcap 5v .1Farad capicator behind 3v3 regulator. With this modification it act as very stable PSU for the 2.4ghz chipset and cpu, true buffer it stay locked even after short removal of input voltage. (Brownout voltage zero Volt, max 1sec)
Just placing capacitor at free servo channel is not a proper solution, as at a current drop due to heavy load to battery, broken servo etc, the capacitor at free channel will be also shortcutted.
fernandez is offline Find More Posts by fernandez
Old Apr 19, 2010, 10:39 AM
Chase Wu is offline
Joined Mar 2009
Originally Posted by Iflyj3 View Post
Chase,
soon,I think in one or two weeks
Old Apr 19, 2010, 10:53 AM
Eden Prairie, MN
Joined May 2008
Chase,
Thank you. Do you know when you might expect the local distributors to have them in stock? I would assume 1 or 2 weeks?
Hopefully I can have them throw one into the shipment when i buy some more receivers in the next few weeks.
Best Regards,
Curtis
Old Apr 19, 2010, 12:06 PM
ScottSails is offline
Find More Posts by ScottSails
Balsa addiction since age 3
ScottSails's Avatar
Upstate NY
Joined May 2005
Originally Posted by jonathan-FrSky View Post
V8FT's latest case is improved now.
Is there an equivalent version for the Hitec? I was going to use the DIY module but would prefer a complete plugin with the antenna in the correct position.
Scott.
ScottSails is offline Find More Posts by ScottSails
Old Apr 19, 2010, 12:41 PM
AirBornOne is offline
Find More Posts by AirBornOne
Life-abstract=conformity
AirBornOne's Avatar
S.F. Bay Area
Joined Aug 2002
All in all,this sounds like a system I'm interested in.
Thank you all for your reports.
Chase/jonathan; any plans for a 12channel DIY module for MPX radios?
Skies.
J.
AirBornOne is offline Find More Posts by AirBornOne
Old Apr 19, 2010, 01:00 PM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
If possible, I would love to see the above implemented as a modular dual box solution: a "normal" 8ch receiver, with a extension plug for a second box containing the additional 4 channels.
Somewhat like the new Futaba S-Bus concept.
renatoa is online now Find More Posts by renatoa
Old Apr 19, 2010, 05:20 PM
brubru is offline
Find More Posts by brubru
Joined Feb 2008
hello Flyer 5
How do you install the capacitor
Originally Posted by flyer5 View Post
Hallo Manuel Silva,
what you noticed is a problem I think with all the 2,4 Ghz stuff, because of not
contiued transmission.All moduls have a burstwise transmittting. We made hack with a
flysky modul and the same thing occurs.With a 47 uF capacitors on the input of the modul
it was no problem.
with friendly regards
Werner
brubru is offline Find More Posts by brubru
Old Apr 19, 2010, 08:04 PM
Modelholic is offline
Find More Posts by Modelholic
Modelholic's Avatar
Perth WA
Joined Feb 2007
Pictures please!
Modelholic is offline Find More Posts by Modelholic
Old Apr 19, 2010, 08:23 PM
PLMS is offline
Find More Posts by PLMS
Martin - AKA mr.sneezy
PLMS's Avatar
Joined May 2004
Hi Jonathan. I bought a set from HiModels new stock last week, would that have the new design Futaba case (it's still in the post).
Martin
PLMS is offline Find More Posts by PLMS
Old Apr 19, 2010, 10:33 PM
jonathan-FrSky is offline
Find More Posts by jonathan-FrSky
Wuxi, China
Joined Nov 2009
Scott.
Two way radio system will have the equivalent version for the Hitec. You will see it soon.
jonathan-FrSky is offline Find More Posts by jonathan-FrSky
Old Apr 19, 2010, 10:38 PM
Wuxi, China
Joined Nov 2009
Skies.
J.
We have the plan of two way radio system for 12channel in higher performance in the second half of this year.
Old Apr 19, 2010, 10:41 PM
Wuxi, China
Joined Nov 2009
Martin
V8FT with new case will be supplied in 1-2 weeks.
Mini-Review The video for FrSky 2.4Ghz Chase Wu Radios 0 Dec 16, 2009 02:18 AM
Discussion Realflight G5 Combat so far so good! splitpilot Simulators 0 Nov 22, 2009 07:36 AM
Discussion So far... So good rikks Mini Helis 35 Feb 17, 2006 01:42 PM
Aerofly Deluxe so far so good! Gary Morris Simulators 5 Aug 19, 2005 08:23 AM
Schulze 18.46K v7.02 - so far, so good! Jason M Electric Heli Talk 4 Aug 11, 2002 02:25 AM
