Old Jan 22, 2010, 04:02 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
The range check works very well, plenty of ground range even with the Tx powered down. So far I have flown it in small parkflyers all the way up to my 70 size 1700w chipmunk, no issues yet. Response time is excellent, feels very natural when flying my little Tucano in a pylon style pattern which requires quick responses from both me and the gear!
I have plots from an engineer friend and they emulate the FAAST plots quite closely. He has also done interference & brownout tests and could not get it to lock up no matter how he dropped the voltage on the rx. Failsafe works as described, you can turn the Tx off with the sticks in whatever position and all controls will go to neutral, throttle off, turn Tx back on it relocks almost instantly.
Here is a review just posted, this guy usually picks things to death if they are no good so it would seem FrSKY is on the right track:
http://www.rcmodelreviews.com/frskyreview.shtml
I have the module sets available in Australia with local certification.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Jan 22, 2010, 07:11 PM
ScottSails is online now
Find More Posts by ScottSails
Balsa addiction since age 3
ScottSails's Avatar
Upstate NY
Joined May 2005
"I have the module sets available in Australia with local certification. "
I am happy to see this system get such good ratings. However, those receiver prices (Australian) would push me towards Hitec most likely. Not trying to be a jerk, just blunt.
The $'s mentioned on the review site result in a different decision
Scott
ScottSails is online now Find More Posts by ScottSails
Old Jan 22, 2010, 10:52 PM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Scott
Yeah well USD$38.00 listed by the reviewer is the sort of price you would see without local taxes, our pricing is pretty competitive and includes local taxes. The Rx is more than half the cost of the kit to purchase so pricing is actually low on the Rx side of things. Plus we have to offer warranty, service, a product that is compliant with OZ laws which are different to the rest of the world...
Another forumer posted up about the hitec, seems when its set to hopping it wont lock back on if you turn the tx off?? Only if its set to fixed frequency mode. Having never played with one I cannot comment on the accuracy of this claim but he has an Aurora. I know the FrSKY locks back on instantly.
Old Jan 22, 2010, 11:41 PM
gmphoto is offline
Find More Posts by gmphoto
Novice builder and flyer!
brisbane australia
Joined Mar 2007
Scott
Hi Scott,
I actually thought the prices are very reasonable, especially considering that a CTick was sought and approved and that a degree of local support for warranty is implied.
And AUD$110 for a TX module and RX seems like a steal to me.
PS this is not a hint to raise prices though, Extreme RC
gmphoto is offline Find More Posts by gmphoto
Old Jan 23, 2010, 05:43 AM
ScottSails's Avatar
Upstate NY
Joined May 2005
Ah,
Was not aware of the local taxes required in OZ nor warranty and service issues. THAT explains a lot, i can imagine if the quality turns out bad, that would crush your business. So many sellers are literally just a web site that could come and go with no warranty (or a warranty that requires so much effort, no one bothers with it). Thanks for the clarification
Scott
Old Jan 24, 2010, 08:07 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
I don't know about Spektrum, but Hitec also has a range check reduced power of 1%, 1mW vs 100mW. I think "the others" too use a very low % in the same ballpark, because is a nonsense to reduce to 10% only.
Why? 10% power means range reduced 3 times compared to full range (square root of power ratio in both modes). Futaba for example advertise 3000m range in air, have you ever heard 1km range check for a Futaba radio?
@Chase: does this receiver has any pad to pick an analog RSSI signal.
CC2500 outputs digital RSSI, can't be used directly by existing OSDs on the market.
If negative, does the Rx LED change somewhat to warn about lost packets?
Originally Posted by BrumBob View Post
sorry, that bit I understand, what I should have said is that I've no idea how much other manufacturers reduce power by in range check mode, so I don't know how to compare ground range in range-test mode between the FrSky unit and, for example, a Spektrum set in range test mode. Does Spekturm reduce it's output power to 10%, 5% 1%?
What I do know is that 150 yards was impressive, and by that reasoning should give 1500 yards - nearly a mile - ground range! Unfortunately the only Spektrum module we had to hand on the day for comparison was faulty, giving just 2M range.
Chase - that's encouraging that you are taking action on the molding shape so promptly. Glad I could be of assistance.
renatoa is online now Find More Posts by renatoa
Old Jan 24, 2010, 09:12 PM
Chase Wu is offline
Find More Posts by Chase Wu
Joined Mar 2009
@RENATOA: Yes, the Rx LED will change the frequency of flashing to warn about lost packets
Chase Wu is offline Find More Posts by Chase Wu
Old Jan 24, 2010, 11:46 PM
Joined Sep 2007
Hitec has two modes: scan and normal
In Scan Mode, both Receiver and transmitter scan the whole band (120 channels) for the best 20 channels. Useful if you use a 2.4 GHZ Wireless video transmitter to avoid using the frequency occupied by video Tx. Yes, in this mode, if you turn off Tx and back on, you have no lock. But this mode is intended only when you change location, more as a sniffer for busy channels to avoid them.
After this scan, you normally switch to normal mode, pun intended because scan mode is more a binding mode than a regular usage mode, imo.
In Normal mode both Tx and Rx hop only the 20 channel that was previous choosen during the scan mode binding, so when you turn on/off again, they always select the same channel 20 channels, until next scan mode bindingfor this reason the reboot is much faster.
Old Jan 28, 2010, 03:32 PM
Fly2High is offline
Find More Posts by Fly2High
Chuck 'Em and Chase 'Em
Fly2High's Avatar
United States, NY, Plainview
Joined Aug 2005
Where are these available?
US?
Orient?
HobbyKing?
Fly2High is offline Find More Posts by Fly2High
Old Jan 28, 2010, 03:42 PM
Joined Sep 2007
Singapore and Australia. Soon UK
The two sites are in the threads about frsky
Old Jan 28, 2010, 03:45 PM
BrumBob is online now
Find More Posts by BrumBob
Birmingham, UK
Joined Apr 2007
looks like ExtremeRc in Australia have them listed, and GiantCod in the UK will have them available this weekend.
Personally I am going to swap my remaining 35MHz setups over as soon as I can get the receivers. Not that I've had a problem with 35, other than remembering to put the tx aerial up before taking off , and finding somewhere to loop the rx aerial in small models
edit - Renatoa beat me to it!
BrumBob is online now Find More Posts by BrumBob
Old Feb 04, 2010, 09:35 PM
kneedrag is offline
Find More Posts by kneedrag
Joined Apr 2007
In NZ we are accepting pre-orders and are getting them in shortly as well.
http://www.phlatkits.co.nz/
kneedrag is offline Find More Posts by kneedrag
Old Feb 05, 2010, 06:31 AM
phil_g is offline
Find More Posts by phil_g
Who let the dogs out?
phil_g's Avatar
Pontefract, Yorkshire, UK
Joined Jul 2007
Ordered two additional receivers from Giantcod on Wednesday evening, Friday morning here they are!
Nicely packaged, not 'loose' like previous Chinese gear:
phil_g is offline Find More Posts by phil_g
Old Feb 05, 2010, 06:55 AM
PLMS is offline
Find More Posts by PLMS
Martin - AKA mr.sneezy
PLMS's Avatar
Joined May 2004
Backing up a few posts.
Spektrum TX modules and radios show a 20dB drop in power when checked on a good (not a PC WiFi dongle) spectrum analyzer during range test.
Since they output about +20dBm (100mW) it means they drop to about 1mW when in range check mode. Chase has explained that FrSky has used the same power level drop, which is good I think.
I've done a lot of testing for Corona in the past (that's another story), also using the CC2500 chipset and RF amp, and so I'd bet the FrSky has the same power output as the Corona which is also approximately +20dBm.
In fact Corona, Spektrum and most others seem to be between +20dBm and +22dBm at the antenna connector.
Martin
Edit: Testing on much more recent Spektrum DSM2 TX modules (late firmware) shows they have a -30dBc power drop for range test. So the FrSky needs to be lower also.
PLMS is offline Find More Posts by PLMS
Old Feb 05, 2010, 07:10 AM
Joined Sep 2007
Corona is 40mW and FrSky is 60mW, as I read in various threads.
FrSky is FCC certified, so if you have the FCCID, you may read the exact tests results bulletin.
Mini-Review The video for FrSky 2.4Ghz Chase Wu Radios 0 Dec 16, 2009 01:18 AM
Discussion Realflight G5 Combat so far so good! splitpilot Simulators 0 Nov 22, 2009 06:36 AM
Discussion So far... So good rikks Mini Helis 35 Feb 17, 2006 12:42 PM
Aerofly Deluxe so far so good! Gary Morris Simulators 5 Aug 19, 2005 07:23 AM
Schulze 18.46K v7.02 - so far, so good! Jason M Electric Heli Talk 4 Aug 11, 2002 01:25 AM
