Old Oct 22, 2010, 06:38 AM
erazz is offline
Find More Posts by erazz
erazz's Avatar
United States, NJ
Joined Jun 2004
Originally Posted by RENATOA View Post
uphiearl issued a similar request today in the other thread.
Do you guys think would be a good ideea to start spawning unofficial versions of firmware here and there?
Even in open source world, the versions are under a certain control
Oh yes!
That's the neat thing about OS. Anyone can do anything. You don't HAVE to use the unofficial version but you CAN.
It's called "free software" not because it doesn't cost anything but rather because you have the freedom to choose.
Why do you think multiple versions are a bad idea?
erazz is offline Find More Posts by erazz
Old Oct 22, 2010, 06:47 AM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
I order to change the downlink I think you would have to modify both the tx and rx firmware.
Do we really want to risk changes to (for example) the hopping sequences that could affect other users of the band?
Could it be that the downlink is already pretty close to capacity, so not much to be gained anyway?
Pat MacKenzie
pmackenzie is online now Find More Posts by pmackenzie
Old Oct 22, 2010, 11:26 AM
nick.sargeant is offline
Find More Posts by nick.sargeant
Perth, Western Australia
Joined Dec 2005
Originally Posted by Chase Wu View Post
Dear George and all,
We presume new ROM to provide PPM on D8R would be available the end of November or early December. Let's look forward to it.
Thank you all for your attention!
Eva
I very much look forward to it!
I'm counting down the days
nick.sargeant is offline Find More Posts by nick.sargeant
Old Oct 22, 2010, 04:32 PM
yurdakut is offline
Find More Posts by yurdakut
Joined Jul 2010
Originally Posted by splitpilot View Post
Hello!!!
May I ask where did you buy the Upgrade Lite???
yes I bought it himodel.
Dear JollyJoker, I m not complaining system or range.I accept everything works fine from the beginning..unfortunately I could not have second RX from the beginning.Why?first introducing the V2 is very early...I can order it from HK not a market on the beginning of the street..and adding all these problems fighting with upgrading is very hard...I have two plane I need two RX..but I could not..now upgrade lite is not working and again I have only one RX again..this is my problem and I m tired of these fighting...
yurdakut is offline Find More Posts by yurdakut
Old Oct 22, 2010, 05:30 PM
eariii is offline
Find More Posts by eariii
United States, CO, Pueblo
Joined Jan 2002
Rom A or Rom B - that is the question
I just received my V2 Telemetry Futaba COMBO from HK. With a home-brew adapter board it fits my Airtronics Stylus perfectly.
I was able to bind the V2 D8R successfully. Range test to come. Also ordered and was able to bind V8R4 (once I found earlier tip to set xmitter to V8 mode with switch 2).
Now my question is:
What version of ROM do I have? How do I determine this?
What are the advantages of upgrading?
Frsky newbie...
Skip
eariii is offline Find More Posts by eariii
Old Oct 22, 2010, 08:00 PM
pmackenzie's Avatar
Joined Dec 2002
Originally Posted by eariii View Post
Now my question is:
Frsky newbie...
Skip
You can determine the version by pressing the bind button on the receiver to set the failsafes. If it is ROMA then the tx module will beep to indicate that the failsafes were set. ROMB failsafes are set from the tx module, (Telemetry versions only, non telemetry uses the receiver bind button)
As far as advantages, I think one is that V2 works better with non telemetry receivers. Not sure what benefit there is for the telemetry ones, but any new ones you buy will probably be V2, so you will have to upgrade at some point.
edit - ROMA and ROMB are not "upgrades", just different in how fail safes are set.
Pat MacKenzie
Old Oct 23, 2010, 10:53 AM
Kansas is offline
Find More Posts by Kansas
USA, KS, Lawrence
Joined Oct 2008
Solved: Frsky hack module in a Tracker 3 from Polk hobbies
Solved!!!! Regarding the power problem with a Frsky VH8T hack module in a Polk Hobbies Tracker III Transmitter.
If interested, see posts 1777-1793 on pages 119-120, and Posts 1887 and 1925
The PROBLEM is: (from post 1777)
Only servos plugged into only even numbered channels in the receiver work, channels 2,4,6,8. And, with the Tx set to "Standard receiver", (the Tracker 3 will transmit to "standard" = Futaba, JR, and Airtronics) the order is: aileron, elevator, throttle, rudder. The others don't work. Tried it with the battery in number 8 and number one. Unquote.
and
from Post 1887, page 126
I'm getting a lot closer to making this thing work
and especially Post 1925 on page 129
The really weird (and great) thing is, when I put the probes on to test the voltage from PPM OUT to Ground, all the servo chattering stops, AND, the receiver works PERFECTLY, on the channels it is supposed to work on. Take the probes off and its right back to chattering. Unquote
Thanks to many, but especially JMP_Blackfoot, we found that soldering a resistor between PPM Out and Ground helped, but the range wasn't sufficient. Adding a capacitor in the same spot helped. But then removing the resistor and just leaving the capacitor helped the most. Flew yesterday for the first time 2.4. Wonderful.
Please feel free to PM me for help with this issue with Tracker III
See also http://www.rcgroups.com/forums/showthread.php?t=1235628
And thanks again JMP!!!
Kansas is offline Find More Posts by Kansas
Old Oct 23, 2010, 01:40 PM
yurdakut is offline
Joined Jul 2010
dear friends,
at the end the happy end.I have working two D8R RX'es now.
I have updated my D8R RX in my office desktop PC.I dont know what is wrong but today I have updated the RX.I think important points are RS232 port connection, XP and jumper conntection on 7 th and 8 th channels on RX.on the other hand nothing happened to upgrade lite by readjusting right sides.maybe this is a good new for everyone.thanks for everyone including Miss EVA from FrSky..
Old Oct 24, 2010, 08:08 AM
maaaarius is offline
Find More Posts by maaaarius
Norway
Joined Oct 2010
I heard some rumours that the beta version of FrSky didn't work in cold weather (-1C/30F).
My FrSky module and telemetry receiver seems to work fine in -19C/-2.2F, although I was unable to fully test the range (I have a small freezer...). I've been out flying in -2C/28.4F a few times, and never noticed any problems.
The winters up north (Norway, Sweden, Finland, Russia etc.) are quite brutal, so it's nice to see that the equipment can withstand the low temperatures. The freezing point is a scary limit
maaaarius is offline Find More Posts by maaaarius
Old Oct 24, 2010, 08:14 AM
PLMS is offline
Find More Posts by PLMS
Martin - AKA mr.sneezy
PLMS's Avatar
Joined May 2004
I think that one would have been caused by a bad solder joint somewhere opening up when cold. This Lead Free solder stuff is much harder to get right in production than the old solder...
Hopefully FrSky will spend some time getting continuous quality improvement embedded in their business structure, and become the best producer out there.
PLMS is offline Find More Posts by PLMS
Old Oct 24, 2010, 08:44 AM
MGeo is online now
Find More Posts by MGeo
MGeo's Avatar
New York
Joined Nov 2003
Is the Tx connector interface to the DFT telemetry module documented anywhere (pin assignments, ppm format, voltage levels)? I'm working on a custom transmitter, I am searching but there is alot of info to sift through.
George
MGeo is online now Find More Posts by MGeo
Old Oct 24, 2010, 09:01 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
George
See here:
http://www.rcgroups.com/forums/attac...mentid=3336412
Voltage levels are 0 to 3.3V maximum allowed.
If the module is shipped in August or newer, then a diode should be there to limit input voltage bigger than 3.3V.
renatoa is offline Find More Posts by renatoa
Old Oct 24, 2010, 10:25 AM
MGeo is online now
MGeo's Avatar
New York
Joined Nov 2003
See here:
Thanks again Renatoa. Are the other 2 pins of the 5 pin connector unused?
From this post (http://www.giantcod.co.uk/forum/view...&sd=a&start=50) and your post, it looks that that pin 1 is PPM, pin 2 is V+ (3.3v) , and pins 3, 4 are Gnd, an pin 5 is open.
George
Old Oct 24, 2010, 10:47 AM
Charley38 is online now
Find More Posts by Charley38
United States, TX, Kerrville
Joined Oct 2003
Subscribe
Subscribe
Charley38 is online now Find More Posts by Charley38
Old Oct 24, 2010, 11:37 AM
alexcmag is offline
Find More Posts by alexcmag
alexcmag's Avatar
Sao Paulo, Brasil
Joined Aug 2004
On full-JR 27..72MHz compatible modules the two additional connections are for 72MHz aerial (no use here) and RF power. On Futaba they are for RF indicator (to show on TX when module is transmitting) and antenna.
In both cases the additional pins are useless for 2.4GHz modules.
alexcmag is offline Find More Posts by alexcmag
Mini-Review The video for FrSky 2.4Ghz Chase Wu Radios 0 Dec 16, 2009 02:18 AM
Discussion Realflight G5 Combat so far so good! splitpilot Simulators 0 Nov 22, 2009 07:36 AM
Discussion So far... So good rikks Mini Helis 35 Feb 17, 2006 01:42 PM
Aerofly Deluxe so far so good! Gary Morris Simulators 5 Aug 19, 2005 08:23 AM
Schulze 18.46K v7.02 - so far, so good! Jason M Electric Heli Talk 4 Aug 11, 2002 02:25 AM
