Old Oct 11, 2010, 03:35 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
This is 3db difference, that equates in 40% more range.
In their specs, Frsky is very conservative, distance is also reported as 1.5km only, while tests revealed much more. They report an output power of 60mW, while maximum allowed is 100mW, and FCC report show they are in this range.
Could be important for out of LOS flyers only.
renatoa is online now Find More Posts by renatoa
Old Oct 11, 2010, 03:49 AM
CrashAndFix is offline
Find More Posts by CrashAndFix
Joined Oct 2010
Thanks ! Of course +3db is a good thing. And yes i'm planning to use it for fpv
I saw your reports about range renatoa, very impressive. And if one day i want to go for long range i'll try to add a booster
CrashAndFix is offline Find More Posts by CrashAndFix
Old Oct 11, 2010, 03:51 AM
Joined Sep 2007
Booster is unidirectional, will kill telemetry.
Maybe is better in this case to use BEVRC solution. 3 times more costly though
Old Oct 11, 2010, 03:55 AM
Joined Oct 2010
I saw the BEVRC solution, but don't really want to invest on a system which have only one reseller... And if i use a booster it will be with a no-telemetry frsky system.
Old Oct 11, 2010, 03:57 AM
mark hitchman is offline
Find More Posts by mark hitchman
Zephyr 66" Blunt
mark hitchman's Avatar
New Zealand
Joined Sep 2009
I have tried mine on the ground with a 1 watt amp, at 3 km it worked without issue, this was on the ground and not elevated so I am picking 1 meter high low passes at 3 km and over 10 km with altitude. Just waiting for the right day to test distance to failsafe
Mark
mark hitchman is offline Find More Posts by mark hitchman
Old Oct 11, 2010, 04:01 AM
Joined Oct 2010
Mark
Thanks Mark ! Seems you exactly have the system i'm planning to use
Do you add an attenuator ( and which one) between the Frsky Tx and the booster ??
Old Oct 11, 2010, 04:03 AM
jhsa is online now
Find More Posts by jhsa
Flying a Chipmunk in Portugal
jhsa's Avatar
NRW, Germany
Joined Sep 2010
Hi, I just bought a FrSky module system with telemetry for using with a Turnigy 9x transmitter. is there a mod so I could use the antenna from the 9x connected to the FrSky module? or installing the frsky antenna replacing the original one?
jhsa is online now Find More Posts by jhsa
Old Oct 11, 2010, 04:05 AM
Zephyr 66" Blunt
New Zealand
Joined Sep 2009
Do you add an attenuator between the Frsky Tx and the booster ??
Nah, I assumed it was 60 mw output which is well within the limits of my amp, never thought they would have under stated it though. Still I suppose they are cheap enough if the module does fry but I doubt they will. I just started using the 7 channel with ppm out, brought 2 of them, also have the 8 channel telemetery one. They are too cool
Mark
Old Oct 11, 2010, 04:27 AM
Joined Sep 2007
Does HiModel already delivered so fast the PPM receivers to you ?!
Old Oct 11, 2010, 04:34 AM
Joined Sep 2007
Open the original 9x module.
If the 9x module antenna cable is fitted with the same U.FL plug as FrSky, just do a hole in FrSky module, reroute the 9x antenna cable accordingly, and replace the FrSky antenna cable in the board plug with the 9x cable.
If 9X module antenna cable is soldered... then we have a problem...
Old Oct 11, 2010, 04:36 AM
Zephyr 66" Blunt
New Zealand
Joined Sep 2009
Hi Renatoa, I ordered from Phlatkits.co.nz in New Zealand here (kneedrag on Rcgroups) he said they would take a week for delivery and emailed me 2 days later and said they had arrived too cool.
Makes hooking up the dosd+ a breeze. Be keen to get the firmware update for the telemetery receiver too.
Mark
Old Oct 11, 2010, 04:39 AM
jhsa is online now
jhsa's Avatar
NRW, Germany
Joined Sep 2010
Then I have a problem. it is soldered. nothing we can do about it??
Old Oct 11, 2010, 04:45 AM
Joined Oct 2010
I'm pretty sure the antenna cable is soldered on the board of the Turnigy 9c Tx.
I've seen a thread on hobbyking forum's with pics...
Old Oct 11, 2010, 04:51 AM
jhsa is online now
jhsa's Avatar
NRW, Germany
Joined Sep 2010
but would it be possible to buy a connector and soder it to the end of the cable from the original turnigy module antenna and then reroute it outside the radio back case and connect it to the FrSky module?? does that influence the transmission? also are all the antennas pretty much the same, or they may differ??
Sorry about all this questions but i don't want to do anything without being 100% sure that it will work..
Old Oct 11, 2010, 05:11 AM
Joined Oct 2010
I think the easiest way is to add this antenna http://www.hobbyking.com/hobbyking/s...idproduct=9204
You just have to glue it in the same place the original Turnigy antenna was,the cable goes inside the transmitter, then make a hole in the transmitter case to get the connector screw in the module.
Mini-Review The video for FrSky 2.4Ghz Chase Wu Radios 0 Dec 16, 2009 01:18 AM
Discussion Realflight G5 Combat so far so good! splitpilot Simulators 0 Nov 22, 2009 06:36 AM
Discussion So far... So good rikks Mini Helis 35 Feb 17, 2006 12:42 PM
Aerofly Deluxe so far so good! Gary Morris Simulators 5 Aug 19, 2005 07:23 AM
Schulze 18.46K v7.02 - so far, so good! Jason M Electric Heli Talk 4 Aug 11, 2002 01:25 AM
