Old Feb 02, 2013, 09:26 PM
jbrumberg is online now
Find More Posts by jbrumberg
Childlike Activity for Adults
jbrumberg's Avatar
United States, MA, Cummington
Joined Dec 2012
I am only a novice, but could something be out of balance under the cowl? Like the weight or is the battery out of alignment?
jbrumberg is online now Find More Posts by jbrumberg
Old Feb 02, 2013, 11:15 PM
Hotfire is offline
Find More Posts by Hotfire
United States, TN, Nashville
Joined Apr 2012
ll see.
Hotfire is offline Find More Posts by Hotfire
Old Feb 02, 2013, 11:36 PM
SAF_Dogface is offline
Find More Posts by SAF_Dogface
Joined Mar 2011
WWW.carbonfibers107.com
Yo, Wazzz up. I think it's about time I give you an up date on the tail shaft drive mod. Out of all the mods that I have ever done this was the hardest to figure out and do.
I think I will call it the SR3 shark. The forward speed is 4 times faster then the stock speed with a picoo-Z tail blade. If I use the MSR tail blade IT KICKS ASS. Plus as it comes to an abrupt stop, it will not kick back as much as the ZR3-GT will. By not using the 6mm tail motor at the tail end of the heli I have reduced allot of the weight. Less weight less kick back. The flight time is around 6 mints with a 150 battery. It was a lot of fun building this thing but now its time to move on to the next project. If you boys can come up with a cool idea, let me know
SAF_Dogface is offline Find More Posts by SAF_Dogface
Old Feb 03, 2013, 03:29 AM
stringrazor is online now
Find More Posts by stringrazor
Certifiable
stringrazor's Avatar
United States, CA, Burbank
Joined Dec 2012
I have a "Nano Hercules" by "World Tech Toys". From my searches, it seems to be very similar to the Syma S107. I've been flying it just about every day since my wife gave it to me for Christmas but today the B motor quit. I took it apart and found the fragile brush contact on one side had disintegrated. I suppose at the RPMs these tiny motors make, there's no way they can last long.
Since "World Tech Toys" seems to be just a rebranding import company, it's hard to tell what the correct replacement part is. The motor is about 20mm in size measured from the wire cap to the end of the shaft and 6mm in diameter. Is that the same size as the B motor for the Syma 107?
stringrazor is online now Find More Posts by stringrazor
Old Feb 03, 2013, 06:38 AM
Klippie is offline
Find More Posts by Klippie
Klippie's Avatar
Scotland
Joined Oct 2010
Guy's,
I have not been on here for a while and a see lots of new members with S107's if anyone needs PicooZ tail rotors please PM me for very cheap prices to anywhere in the world.
Happy flying...
Klippie is offline Find More Posts by Klippie
Old Feb 03, 2013, 11:21 AM
SysCrusher is offline
Find More Posts by SysCrusher
United States, FL, Jacksonville
Joined Jan 2013
The main motors are 7mm x 17mm.
SysCrusher is offline Find More Posts by SysCrusher
Old Feb 03, 2013, 11:45 AM
Hotfire is offline
Joined Apr 2012
S-107
I just love chinglish instructions.
Question 1 USB chger should it be yellow at the connection when charging?
Question 2. LED lights on copter when fully charged should all 4 be green?
Thanks, Jim
Old Feb 03, 2013, 02:28 PM
Certifiable
Joined Dec 2012
17mm from where to where?
Old Feb 03, 2013, 02:50 PM
Arr0wHead is offline
Find More Posts by Arr0wHead
United States, MA, Plymouth
Joined Jan 2013
Originally Posted by Hotfire View Post
S-107
Thanks, Jim
huh?
The yellow charger cable will light up red when fully charged. It should always be yellow. If yours stops being yellow, call a doctor.
My heli has only one LED, so I'm not sure what you're talking about. It's a re-brand, but I was under the impression that my nephew's S107 also has only 1 LED on the front.
Arr0wHead is offline Find More Posts by Arr0wHead
Old Feb 03, 2013, 02:57 PM
Joined Jan 2013
7mm dia. x 17mm length
Old Feb 03, 2013, 03:42 PM
TSquare123 is offline
Find More Posts by TSquare123
S107, S026
TSquare123's Avatar
Nashville, TN
Joined Aug 2010
S-107
Thanks, Jim
1. The light in the USB is off while charging, it comes on when charging is complete.
2. Genuine 107's have two LEDs on the copter. Neither have anything to do with charging. Flashing head light on the front. Small green LED on the circuit board, it flashes when the copter is switched on then goes on solid when the copter is stable and ready to fly.
TSquare123 is offline Find More Posts by TSquare123
Old Feb 03, 2013, 06:12 PM
Certifiable
Joined Dec 2012
yeah, that much was obvious but 17mm from cap to end of spindle or 17mm for the body of the rotor???
Here's a pic of what I have. Is this the same as the Syma's B motor?
Old Feb 03, 2013, 07:35 PM
Joined Jan 2013
Sorry, 17mm from one end of the motor to the other end, not including the spindle. I got an extra one to measure, I'll post again.
Old Feb 03, 2013, 07:48 PM
Joined Jan 2013
The body of the motor is actually 7mm diameter by 17mm length. Including the spindle it's 25mm in length. Looks like the spindle on what you have is a bit short. Looks like 21mm from that picture. If you got 22mm the pinion would just fit right to mesh with the gears. Anything shorter than that, looks like it wouldn't work unless it's the A motor.
Old Feb 03, 2013, 08:33 PM
Hotfire is offline
Joined Apr 2012
T Square, Thanks. Mine is a DMZ S-107 a Syma clone from Hobby Lobby on Franklin Pk.
What part of Music City do you live.
Jim
For Sale 3-channel Micro IR S107 Metal HoneyBee Helicopter No.ES0107 (with Gyro) mictopwin Aircraft - Electric - Batteries & Chargers (FS/W) 8 May 09, 2011 02:47 PM
Discussion V-max .vs. Falcon-X .vs. Syma 3 S107? 7immy Mini Helis 12 Apr 07, 2011 05:11 PM
Discussion Mosquito 3CH Radio Control Helicopter Version 2 by Syma Wayno-san Micro Ready-to-Fly 39 Dec 26, 2010 03:36 PM
