Old Mar 06, 2012, 09:00 PM
dutchcommando is offline
Find More Posts by dutchcommando
making crashing a lifestyle!
dutchcommando's Avatar
The Netherlands, UT, Soest
Joined Feb 2012
chap1012.. yes i know, but it still is to much fun to fly..
gears and motors are ordered. so now i can check how long it survives..
the lipo i don't care much about.. it's a 220Mah but i got a batch of 400Mah's in transit..
the damage to the gears made the flying time shorter.. i lost about 2 minutes of flying time.
motors still aren't getting hot though..
damnit.. i'm hooked on these little fun copters.. i have to hold myself down not to order a second one..
dutchcommando is offline Find More Posts by dutchcommando
Old Mar 06, 2012, 09:10 PM
Chap1012 is online now
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
Dutch, I'm afraid you are too far gone. If I were there, I could help you NOT hit that "Buy" button. The heli crack really got to you faster than ever. Faster than I have ever seen before. You need to seek out help immediately. My name is Mike and I'm a heli addict
Chap1012 is online now Find More Posts by Chap1012
Old Mar 06, 2012, 09:22 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
I just ordered one of the Hobbyking spy helicopters. I threw in a 2200 3S Nanotech for the ride here on the slow boat from China.
Prof100 is offline Find More Posts by Prof100
Old Mar 06, 2012, 10:16 PM
Heli Pad is offline
Find More Posts by Heli Pad
Against Helicopter Cruelty
Heli Pad's Avatar
Joined Aug 2011
Dutch, Please start a new thread, so that people other than those who check the S107 thread will get a chance to discover this helicopter.
I would like to see what's under the canopy. Could you share pictures?
Heli Pad is offline Find More Posts by Heli Pad
Old Mar 06, 2012, 10:18 PM
Joined Feb 2012
.................. err... welll...................... uhmmmmm.......
*gulp*
errrr...
*sigh*...
hello...... my name is DutchCommando... and.. err.. well.... i am a heli addict to...
charging the copter for the 28th time today.. ..... killing time by browsing the forum, checking out 4ch micro coaxes and hoping my fresh quad frame will arrive this week..
(dangit.. still charging.. i need my fix!)
Old Mar 06, 2012, 10:19 PM
Joined Feb 2012
will do tomorrow!
Old Mar 07, 2012, 05:57 PM
Joined Feb 2012
here you are..
fresh thread klickety klick.
Old Mar 09, 2012, 07:55 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Mine now has the "toilet bowl" effect when hovering. That's from have too many sniper shots from Plasma TV interference causing the helicopter to fall out of the sky. Is there a fix or do I just have to live with the toilet bowl hover?
Old Mar 09, 2012, 08:22 PM
stickman0236 is offline
Find More Posts by stickman0236
My toilet water has TBE
Joined Dec 2011
stickman0236 is offline Find More Posts by stickman0236
Old Mar 09, 2012, 08:38 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Originally Posted by stickman0236 View Post
Howdy Prof100. Until somebody shows up to answer, you might check out Heli Pad's most excellent blog which might have your answer -
http://www.rcgroups.com/forums/member.php?u=370168
It's some really good info. Good luck!
Thanks, I will check it out.
Old Mar 09, 2012, 08:44 PM
TheTick is offline
Find More Posts by TheTick
Spoooooon!
TheTick's Avatar
San Fernando Valley, California, United States
Joined May 2003
Hi guys,
I spend most my time in the plane sections of this forum and dropped in here to see if I could get some info on a replacement battery for my S107. 739 pages!! This thread is epic! Can someone save me some time and guide me in the right direction? Looking for a larger capacity if possible.
Thanks!
TheTick is offline Find More Posts by TheTick
Old Mar 09, 2012, 08:52 PM
Joined Dec 2011
Old Mar 09, 2012, 09:08 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
I did some google searches and found some posts on the toilet bowl effect. Lubin the flybar and tightening up the upper blades helped but I still have the TBE but to a lesser degree.
Old Mar 09, 2012, 09:26 PM
Joined Dec 2011
Originally Posted by TheTick View Post
Hi guys,
Thanks!
TheTick flies S107s... I'll be darned!
I can appreciate your want for a larger battery. Doing so requires some weight mods and (probably, depending on your mods) belly mounting the battery.
The S107 speed mods thread might have more info. I haven't been in there-
http://www.rcgroups.com/forums/showthread.php?t=1227023
After which, you will still have to limit flights to 5 minutes before a cool down for the itty bitty motors.
I got 240 mAh batts from this guy on fleabay-
http://www.ebay.com/itm/280725477047...84.m1438.l2649
Fly for 5 minutes, rest for 10 and fly for the last 5 minutes.
If you don't strip weight and limit flight times, you're going to damage your copter with a bigger battery.
Old Mar 09, 2012, 09:52 PM
Joined Dec 2011
So, Prof100, you have looked closely at the head (per Heli Pad's blog) and didn't notice anything out o whack? Something else to check are the connect buckles/ flybar links to make sure they are LOOSE. I mean, really sloppy. Sometimes they can get pushed on too far and they cause binding. Can you unfurl the top blades to balance and bump the flybar and have the top assembly freely bounce?
For Sale 3-channel Micro IR S107 Metal HoneyBee Helicopter No.ES0107 (with Gyro) mictopwin Aircraft - Electric - Batteries & Chargers (FS/W) 8 May 09, 2011 01:47 PM
Discussion V-max .vs. Falcon-X .vs. Syma 3 S107? 7immy Mini Helis 12 Apr 07, 2011 04:11 PM
Discussion Mosquito 3CH Radio Control Helicopter Version 2 by Syma Wayno-san Micro Ready-to-Fly 39 Dec 26, 2010 02:36 PM
