Old Feb 07, 2012, 02:30 PM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Originally Posted by Flybynyte View Post
When turned off, none of the other lights are on, including the blue LED and the lights inside the body. The chopper won't power up, either, using the controller.
Ok, that would indeed indicate the heli being switched off. They must have wired the led the wrong way, not attached to the part behind the switch, but to a point before that, so the switch has no effect.
SoloProFan is online now Find More Posts by SoloProFan
Old Feb 07, 2012, 03:06 PM
cgpirre is offline
Find More Posts by cgpirre
cgpirre's Avatar
Belgium
Joined Dec 2011
Does anyone know where I can get the clone charging plug, with the round connector?
I fixed my friends' chopper, he borked his battery, and it seems like his charger doesn't indicate when the battery is full, which is quite inconvenient.
Also, is there any way to bind a clone to a genuine syma controller?
Or is it perhaps possible to switch out the pcb from a clone controller to a syma controller, so the control sticks have a better resolution (or how do you call it?).
I think this would greatly improve the responsiveness of the clone helicopter, because right now for the first 3 minutes of a flight it's either way too much throttle, not enough, or just enough to hover but not do anything else...
cgpirre is offline Find More Posts by cgpirre
Old Feb 07, 2012, 04:14 PM
cgpirre is offline
cgpirre's Avatar
Belgium
Joined Dec 2011
And a little video:
Startup of a Syma S107 at 1000 FPS (0 min 22 sec)
next time we'll try filming crashes n such under better lighting conditions, we think this might result in some interesting footage
Old Feb 07, 2012, 04:29 PM
rprebel is offline
Find More Posts by rprebel
rprebel's Avatar
United States, TX, Texarkana
Joined Dec 2011
Originally Posted by cgpirre View Post
And a little video...next time we'll try filming crashes n such under better lighting conditions, we think this might result in some interesting footage
How cool is that?! Yes, most definitely you should keep filming!
rprebel is offline Find More Posts by rprebel
Old Feb 07, 2012, 09:29 PM
IceRail is offline
Find More Posts by IceRail
We NEED a LiPo w a USB plug!!!
IceRail's Avatar
Orland Park, Illinois
Joined Feb 2010
<------- Has been corrected by dave1993 .
IceRail is offline Find More Posts by IceRail
Old Feb 07, 2012, 10:28 PM
slim1357 is offline
Find More Posts by slim1357
slim1357's Avatar
United States, OR, Portland
Joined Dec 2010
And a little video: http://www.youtube.com/watch?v=UDP7THilbLQ
+1000
Please film 30 s107s all bound to the same controller taking off at the same time.
slim1357 is offline Find More Posts by slim1357
Old Feb 07, 2012, 11:07 PM
XDRoX is offline
Find More Posts by XDRoX
United States, CA, San Diego
Joined Jan 2012
Need some help...
OK guys. My Grandfather called me tonight and said he crashed his heli and it wasn't working any longer.
Here's a video.
I believe this is what as known as TBE, but I see nothing wrong with the heli. Everything seems to be perfectly fine.
Any help is appreciated.
http://www.youtube.com/watch?v=OpllJ...ature=youtu.be
XDRoX is offline Find More Posts by XDRoX
Old Feb 07, 2012, 11:09 PM
Stamp is offline
Find More Posts by Stamp
Visit My Blog
Stamp's Avatar
Outskirts of Chicago
Joined Nov 2008
That was very nice.
I knew that slight snapping noise was the blades being jarred back on startup
Jim
Stamp is offline Find More Posts by Stamp
Old Feb 08, 2012, 01:00 AM
arbilab is offline
Find More Posts by arbilab
Fly Runaway Fans
United States, TX, Fort Worth
Joined Jan 2009
Here is the most frequent cause of "flying/crashed/not flying/TBE for S107:
http://www.rcgroups.com/forums/showt...6#post20304349
arbilab is offline Find More Posts by arbilab
Old Feb 08, 2012, 01:22 AM
XDRoX is offline
Joined Jan 2012
That is the problem. Thank you.
Old Feb 08, 2012, 02:03 AM
arbilab is offline
Fly Runaway Fans
Joined Jan 2009
Glad to be of service. It is VERY common and VERY hard to detect on cursory examination. The credit goes to HeliPad for documenting and illustrating it.
Old Feb 08, 2012, 03:41 AM
Heli Pad is offline
Find More Posts by Heli Pad
Against Helicopter Cruelty
Heli Pad's Avatar
Joined Aug 2011
AFAIK, Genuine SYMA S107s are shipped with 150mAh Lipo. I have seen clones shipped with 180mAh.
I installed a 240mAh in my S105. It did not have lift issue. It flies better than I had expected and the flight times are about 8.5 minutes.
Heli Pad is offline Find More Posts by Heli Pad
Old Feb 08, 2012, 03:59 AM
stickman0236 is offline
Find More Posts by stickman0236
My toilet water has TBE
Joined Dec 2011
And a little video: next time we'll try filming crashes n such under better lighting conditions, we think this might result in some interesting footage
That's COOL cgpirre!!
Had to watch that a few times.
stickman0236 is offline Find More Posts by stickman0236
Old Feb 08, 2012, 04:13 AM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
Originally Posted by IceRail View Post
It's nothing but a 2.5 mm mono (only two contacts) DIN male plug. ETA: Do you have any old obsolete earphones/headphones laying around?
the one used in headphones is called a "phono" plug. "din" is the type used by mouse/keyboard. neither is for the clone charger.
the one in the post after this one this is called "coaxial power" plug and is the one in the clone chargers. it is just coincidence that it is used in "coaxial" helis.
dave1993 is offline Find More Posts by dave1993
Old Feb 08, 2012, 04:27 AM
Heli Pad is offline
Heli Pad's Avatar
Joined Aug 2011
One of the biggest issue with clones/fakes is that the PCB could be completely different and incompatible with the genuine SYMA electronics, making them impossible to work with Syma controllers. Switching out the main PCB is possible, but it is costly, and most people would be overwhelmed by the procedure. IMHO, it's not worth the effort, and I'd probably just buy a new helicopter.
But it seems to me that you were able to repair your friend's. And the USB charging cable that you're looking for might be this USB cable with round plug. I have pointed another member to this cable in the past. He has a different helicopter. It turned out to be a perfect match for his. I couldn't guarantee that it will work for yours. But I think the odds are pretty good. Should you take the bet and go for it, when you get it, be sure to check fitting size and POLARITY before using.
Good luck, Pirre.
For Sale 3-channel Micro IR S107 Metal HoneyBee Helicopter No.ES0107 (with Gyro) mictopwin Aircraft - Electric - Batteries & Chargers (FS/W) 8 May 09, 2011 01:47 PM
Discussion V-max .vs. Falcon-X .vs. Syma 3 S107? 7immy Mini Helis 12 Apr 07, 2011 04:11 PM
Discussion Mosquito 3CH Radio Control Helicopter Version 2 by Syma Wayno-san Micro Ready-to-Fly 39 Dec 26, 2010 02:36 PM
