Old Sep 10, 2011, 12:43 AM
Jake8131 is offline
Find More Posts by Jake8131
Jake From Planet Mascoutah, IL
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
Another flight of my old syma s107g.
http://www.youtube.com/watch?v=yWArTr70k3M
Jake8131 is offline Find More Posts by Jake8131
Old Sep 10, 2011, 12:21 PM
air_crash is offline
Find More Posts by air_crash
Ελλάς, Αττική, Αθήνα
Joined Apr 2011
Originally Posted by Chap1012 View Post
Please share your secret. I've been trying to switch 3 TX's with 3 S107's. I'm trying to put a package together for an 11 year old. I already got a badly damaged S107 in the air yesterday (still trying to work out some TBE) but the TX that came with it has issues. It will throttle up when you hit the half way mark on the TX. After that it is fine. My other two TX's won't bind to this heli I fixed up. And one of them is an R5 like the one I fixed up.
Mike.
If the heli are the same, as there are some clones and/or fakes, then one Tx can work with any heli.
Unless you have different helicopters, some original, some fake.
I have 5 S107.
2 of them work with one Tx.
2 of them work with another one Tx.
1 of them work with another different one Tx.
So 3 different versions run with different Tx.
The same version helicopters run with the same Tx though.
air_crash is offline Find More Posts by air_crash
Old Sep 11, 2011, 01:46 AM
Jake8131 is offline
Jake8131's Avatar
Joined Dec 2010
Actually there are two different transmitters out. One has A, B, C. Mine only has A & B and I can fly on either one. It says A,B,C on the Tx, but the switch only moves in two positions. You may have the 2 switch one.
Old Sep 11, 2011, 02:32 AM
Jake8131 is offline
Jake8131's Avatar
Joined Dec 2010
Tbe
After installing new blades and a new flybar, I still had TBE. Drove me nuts. Well, I tightened all 4 blades to where they barely move, and the TBE went away...hmmmm
http://www.youtube.com/watch?v=TgheiKNWAoo
Old Sep 11, 2011, 03:27 PM
woods2007 is offline
Find More Posts by woods2007
Joined Mar 2009
my syma s107 came with very small li-po, 150mah only, fly 5 minutes each full charge. I tested my new Lishi L6019 with 180mah li-po, fly 9 minutes. leave S107 in the dust.
woods2007 is offline Find More Posts by woods2007
Old Sep 12, 2011, 07:55 PM
Jake8131 is offline
Jake8131's Avatar
Joined Dec 2010
You can install a 240mah in the s107.
Old Sep 13, 2011, 03:36 PM
stackz is offline
Find More Posts by stackz
Joined Sep 2011
think I may have broken mine.
it fell on its side and I just hit the throttle to use the blades to prop itself up. been doing this for a little while now as I got lazy from always having to pick it up lol.
anyway, it went to do it this last time then suddenly the lights on the copter went out.
I picked it up and flipped it off and then back on.
lights came on but it doesnt respond to the controller.
think I blew out the board or the motors?
stackz is offline Find More Posts by stackz
Old Sep 13, 2011, 05:33 PM
Jake8131 is offline
Jake8131's Avatar
Joined Dec 2010
Shut all down...make sure to turn on tx then heli. check the batts in the tx.
Old Sep 13, 2011, 09:12 PM
Hayabusa Heli is offline
Find More Posts by Hayabusa Heli
Heli Mania
Hayabusa Heli's Avatar
PNW
Joined Dec 2010
That practice is hard on the heli ... can put high loads on the motors, etc. This could have eventually caused the failure.
Hayabusa Heli is offline Find More Posts by Hayabusa Heli
Old Sep 13, 2011, 09:56 PM
Stamp is offline
Find More Posts by Stamp
Visit My Blog
Stamp's Avatar
Outskirts of Chicago
Joined Nov 2008
Ok so...
I got the three bladed tail rotor from Ebay that was discussed earlier in the thread.
Not worth it. I'll stick with the tail rotor I got from Klippie.
The heli moves slower, even though it is a three bladed rotor.
Jim
Ps...the inner dia of the three rotor is a teeeeenie bit bigger than the tail motor shaft. I had to use a miniscule amount of ca to keep it from spinning.
All is well now though. I have the known high perf tail rotor installed
Stamp is offline Find More Posts by Stamp
Old Sep 14, 2011, 04:03 PM
stackz is offline
Joined Sep 2011
dont know how but I got it working again.
just sat there and kept maxing the throttle and it came back to life. quit trying to upright it via the remote after it crashes though lol.
Old Sep 14, 2011, 04:55 PM
Heli Pad is offline
Find More Posts by Heli Pad
Against Helicopter Cruelty
Heli Pad's Avatar
Joined Aug 2011
That's good news, Stackz. I don't know where you got your S107. I once had a clone and its Tx/Rx binding procedure is different from my other S107s. After turning both of them ON, I have to go full throttle up, bring it back down, before I could fly it. The first throttle up would not cause the blade to spin, until you go Full throttle then cut it. If you have one of those, you might think that they are not communicating before you haven't pushed it all the way. I'm not saying that you have the same kind of clone I had. But just in case, give that procedure a try. Until you know for sure, though, you may want to hold your heli in your right hand, so it won't hit the ceiling if my suggestion is wrong.
Heli Pad is offline Find More Posts by Heli Pad
Old Sep 14, 2011, 08:21 PM
Purple Aki is offline
Find More Posts by Purple Aki
Joined Jul 2011
Just got mine, but shouldn't of bought it really as i'm bored of it already. I've only flown it twice.
Can anyone confirm if this looks like the genuine article?
Also, i'm planning on flying it another couple of times and putting it in storage.
As Lipos should be stored at 50% charge (3.85v), does anyone have any idea how long I should time my flight from a full charge to roughly get to this voltage?
Cheers
Purple Aki is offline Find More Posts by Purple Aki
Reply With Quote  (Disabled)
Old Sep 14, 2011, 09:01 PM
Jake8131 is offline
Jake8131's Avatar
Joined Dec 2010
Looks like the real McCoy to me..fly for about 4 mins.
Old Sep 14, 2011, 09:04 PM
Heli Pad is offline
Heli Pad's Avatar
Joined Aug 2011
Aki, That looks like the real McCoy to me. Bored of it already? You must be more advance than you give yourself credit for. Make yourself a flying course and challenge yourself to some precise flying. That's what I do, and that's where the S107 shines. Try landing it on top of a tall bookcase that is close to the ceiling. That give me trouble and hours of challenge. I sincerely hope that you'd get more fun out of your purchase. Otherwise, when you're done with it, give it to your favorite kid in your neighborhood and make a friend. Cheers.
For Sale 3-channel Micro IR S107 Metal HoneyBee Helicopter No.ES0107 (with Gyro) mictopwin Aircraft - Electric - Batteries & Chargers (FS/W) 8 May 09, 2011 01:47 PM
Discussion V-max .vs. Falcon-X .vs. Syma 3 S107? 7immy Mini Helis 12 Apr 07, 2011 04:11 PM
Discussion Mosquito 3CH Radio Control Helicopter Version 2 by Syma Wayno-san Micro Ready-to-Fly 39 Dec 26, 2010 02:36 PM
