Yes, that is a great mod. I did the same thing. One other thing is to move the battery slightly forward and add a little bit of weight to the inside of the nose. This way the heli will naturally want to move forward. Careful though...blade strikes are a good possibility if you take a sharp turns too fast ![]() Jim Ps...with this different tail rotor...you may not get good backward speed. We don't need no stinkin' reverse though ![]() All my r/c land vehicle have the reverse cut out so I'm used to not having reverse. |
Hi
Can anyone cast some light on my problem. Just got one of these today, the controls are pretty useless move a stick and nothing happens for about a second if I'm lucky, is the transmitter LED supposed to stop flashing because mine doesn't. This is a big disappointment because the reviews are so good! |
Re: Syma s107 Helicopter
Sounds to me like you ***MAY*** have a joystick that's out of whack in some manner -- the pot (variable resistor) that it's physically connected to may be defective. |
@olof To test to see if your TX is putting out signals, get a digital camera, turn the camera on, now turn on the TX and give it some throttle. If you look through the camera while giving the TX input you should see "sparking" coming from the little bulb on top of the TX. You'll need to push the button down on the camera half way like you are about to take a picture to see this "sparking" as you look through the camera. If you do see "sparking" WITHOUT giving any input to the TX, go with Melnic's idea. BTW, when you turn on the TX, you throw the throttle all the way up and back down right?
Mike. |
![]() Another "genius/madman" came up with that on this thread![]() Mike. |
| Thread Tools | |
| For Sale 3-channel Micro IR S107 Metal HoneyBee Helicopter No.ES0107 (with Gyro) | mictopwin | Aircraft - Electric - Batteries & Chargers (FS/W) | 8 | May 09, 2011 01:47 PM |
| Discussion V-max .vs. Falcon-X .vs. Syma 3 S107? | 7immy | Mini Helis | 12 | Apr 07, 2011 04:11 PM |
| Discussion Mosquito 3CH Radio Control Helicopter Version 2 by Syma | Wayno-san | Micro RTF | 39 | Dec 26, 2010 02:36 PM |
