http://www.xheli.com/s107-14.html Quote:
http://www.xheli.com/s107.html http://www.focalprice.com/search.html?keyword=s107 |
Mine was doing the same as yours and I made it work better by SLIGHTLY crushing the plug, (heli end not the USB end), with a pair of pliers. But I did have another cable just in case I messed up faulty cable. |
Re: Discussion Syma s107 Helicopter
When I used the USB "wall wart" charger from this product however, this behaviour ceased -- the red light in the USB-end of the cord appears to function as intended. I have no issues with this USB port when other USB devices are used in it. |
Joined Mar 2011
independent verification? did narrowed amazon search to only include amazon as seller and saw photos showing pink green motors... so faster youd say? anyone else? r |
Joined Apr 2011
can someone help me diagnose a slipping rotor? I am almost positive that's what it is based on the flight problems, but i can't seem to verify it.
heres why i think it is: 1)i all of the sudden have to "trim" to the left a lot more 2)the bottom rotor stops spinning a few seconds faster than the top one, where as they used to stop simultaneously 3) low hover, if any, with full charge but i am not sure that is it.... i figured it was shot anyway, so i tried an experiment. To see if it was slipping, i grabbed the bottom rotor holder and hit the throttle. the gears DID NOT SPIN, meaning they were still pretty attached to the rotor. any ideas? could it still be slipping? i dont think its anything easy like a dirty shaft or anything. any ideas appreciated
Joined Apr 2011
The 3 we got were faster changing yaw and seemed to take off faster. They only need about 1/4 throttle to take off instead of about 1/2 for the R5 board. The throttle might just be more sensitive. Forward flight is the same except for one that is slower. I would say the overall quality is not quite as good. The main rotor blades are also closer together than the ones on the R5 that I have. The clones have had a lot of broken blades, but none on the R5. My R5 has about 60 flights and the clones have less than 10 each. The transmitters are different and we have had all 4 flying at the same time.(3 clones and 1 R5) I would personally try to get the real syma s107, unless you wanted to fly more at the same time. I would have sent them back, but I didn't know they were clones right away. I haven't paid attention to charge time between them. So I can't comment on that. They are reverse polarity and each of three came with different looking usb chargers and lengths. They were all shorter than the R5 charge cord. The board has "YS" on the corner and has four spot for LEDs? that line up with the holes in the frame. |
Joined Feb 2011
Joined Jan 2007
Losing Lift
After about 2 minutes it loses lift and slowly goes down on the floor.
The blades continue to spin if I give it throttle. After it lands I release the throttle and then give it full throttle and it goes up to the ceiling for a bit and then slowly goes back down to the floor. ![]() The battery in the helicopter is charged and the TX batteries are good. There's no IR interference. I have over 5 hours of flight time on it so far. Any suggestions? I did a search here and know this was answered somewhere in the 8300+ posts but I couldn't find the answer. Sorry! |
| Thread Tools | |
| For Sale 3-channel Micro IR S107 Metal HoneyBee Helicopter No.ES0107 (with Gyro) | mictopwin | Aircraft - Electric - Batteries & Chargers (FS/W) | 8 | May 09, 2011 01:47 PM |
| Discussion V-max .vs. Falcon-X .vs. Syma 3 S107? | 7immy | Mini Helis | 12 | Apr 07, 2011 04:11 PM |
| Discussion Mosquito 3CH Radio Control Helicopter Version 2 by Syma | Wayno-san | Micro RTF | 39 | Dec 26, 2010 02:36 PM |
