United States, WA, Pasco
Joined Mar 2011
SYMA S107R5 PCB analysis
Here are the traces I have so far. The photos aren't very clear on the right-hand side, so I did some guessing. Also, there are some vias under U1 that probably go to some U1 pins but I can tell yet. When I receive the boards I'll be able to correct it.
Also, the schematic is interpreted from the photos, so I've organized it as it appears in the images. Once I'm *sure* it's correct, I'll reorganize it to make it easier to read. Thanks to jrgroucho and others on the net for the original photos. This is being posted to make you think I'm not just sitting on my sas, even though I have. Michael
Joined May 2010
Has my S107 croaked? Fully charged my 107 just now via the USB port on my computer as I usually do and now the battery power seems very low as only the top rotors spin and occassionaly the boottom ones, however the heli has not enough power to lift off more than a couple inches. What could be the problem here??
Karol |
Joined May 2010
Will do, but I was of the opinion that once the charge light is on, no charge is going through to the battery. If this is the case I am assuming that the battery can be overcharged. Karol |
@Karol ... first take off the canopy and check that your lipo is not bubbled, then check the wiring going from the bottom motor to the pcb (front motor w/black insulation on top)... if all that checks out its possible that particular motor is going bad though it sounds like a loose wiring connection somewhere
as far as differing speeds on same version units thats a typical manufacturing/assembly variance, mine are like that as well. |
Kelowna, BC Canada
Joined Nov 2010
Joined Feb 2011
Joined Feb 2011
SYMA Charger
http://www.amazon.com/gp/offer-listi...&condition=new Hope that works. I believe this charger is the best option - safer then converted none brand plug chargers and faster then the USB charger. A converted charger may damage the heli charge circuits. |
Joined May 2010
Karol |
Gillette, WY
Joined Feb 2011
| Thread Tools | |
| For Sale 3-channel Micro IR S107 Metal HoneyBee Helicopter No.ES0107 (with Gyro) | mictopwin | Aircraft - Electric - Batteries & Chargers (FS/W) | 8 | May 09, 2011 01:47 PM |
| Discussion V-max .vs. Falcon-X .vs. Syma 3 S107? | 7immy | Mini Helis | 12 | Apr 07, 2011 04:11 PM |
| Discussion Mosquito 3CH Radio Control Helicopter Version 2 by Syma | Wayno-san | Micro RTF | 39 | Dec 26, 2010 02:36 PM |
