USA, WI, Fond du Lac
Joined Dec 2010
It goes up.
Just tried again and the bottom rotor stops way before the top rotor quits spinning.It always did spin a little more,but now it is real noticeable. It will fly right up to the ceiling and stay there if you want it to.You can hold it at elevation of your choice and watch it spin. |
Battery replacement
Just bought this heli and flew it several times already with no issues (getting exactly 7 ½ minutes of flight time). I was wondering about battery replacement and how easy it is. I bought several batteries from Focalprice thinking these were easy swaps while waiting to charge. I haven’t received the extra batteries yet and didn’t want to mess with all the wires and take it apart yet. It appears that you have to solder?
Thanks. |
The lipo battery for this toy heli is not "swappable", must be soldered. |
Joined Sep 2010
More info on battery voltages. I just charged and flew my new Phoenix 6010 tonight, and did the same battery voltage measurements that I did on the S107. The 6010 was at 3.805 V out of the box. Put it on the USB charge and took ~17 min to top it off. The charging voltage was 5.11 V at end of charge ... I think the USB charge on the 6010 is running "hotter" than the one with the S107. That's why 6010s charge up faster than S107s. Not sure if the battery in the 6010 will like it after many charge cycles or not ... time will tell.
So flew the 6010 for 6~7 min until it would not hover any more ... I do the same with the S107. Popped off canopy and felt battery and motors ... all cool, couldn't even detect any heat with my finger. Here's the interesting part. I waited about 10 min before I measured the battery after the long flight. It as at 3.738 V. I think the first time I measured the S107 after a long flight I didn't wait long enough for the battery to "bounce back" ... that's why I saw 3.3 V when I checked it just a couple of minutes after flight. I bet if I waited 10 min after the flight it too would bounce back up to around 3.7 V. UPDATE - I just flew my S107 until it would not hover any more. Let it sit 10 minutes and measured the rest voltage on the battery ... it was 3.694. Conclusion - I don't think flying it until it loses enough power to maintain a hover is going to hurt the Lipo battery. Once the heli can't hover anymore, then land it and call the flight done. |
Joined Mar 2010
No, that will damage the cell, running it to noticeable low power.
If you ever used nicads, treat these the opposite, and never, ever let them get weak. |
Latest blog entry: Minigun: auction ends in 3 Hours.
Latest blog entry: Vintage Kyosho Buggies, why I love 'em...
United States, FL, The Villages
Joined Oct 2010
Joined Dec 2010
I checked for hair and anything else that is normal to check for.What I did notice with the tx, is that the trim controller is very wobbly.I took off the cover and had to laugh.The little board that the trim control is attached to has an L on the right side and an R on the left. The pod for the trim could be replaced if that ends up being the problem.It is even a plug and play type connection .No soldering needed.part #S107T1A.I would think the LHS may have a similar one available. |
Joined Dec 2010
I love beans |
| Thread Tools | |
| For Sale 3-channel Micro IR S107 Metal HoneyBee Helicopter No.ES0107 (with Gyro) | mictopwin | Aircraft - Electric - Batteries & Chargers (FS/W) | 8 | May 09, 2011 01:47 PM |
| Discussion V-max .vs. Falcon-X .vs. Syma 3 S107? | 7immy | Mini Helis | 12 | Apr 07, 2011 04:11 PM |
| Discussion Mosquito 3CH Radio Control Helicopter Version 2 by Syma | Wayno-san | Micro RTF | 39 | Dec 26, 2010 02:36 PM |
