Old Nov 05, 2010, 10:32 AM
salazam is offline
Find More Posts by salazam
Joined Sep 2010
Originally Posted by Kurt View Post
If you find a Huey body that weighs the same or less than the S107's I'm in!
That's my predicament. Assuming I even get it off the ground, after its first test flight I'm going to maybe shave sections out of the body just to make it lighter (a la x-wing ufo!). Maybe even remove the tail boom and just mount the motor directly into the huey frame.
salazam is offline Find More Posts by salazam
Old Nov 05, 2010, 10:37 AM
salazam is offline
Joined Sep 2010
Originally Posted by killbucket View Post
Almost all of the baby copters look/fly better without the skids, IMHO.
I agree! I couldn't believe the improvement in performance once I took the skids off, it just sucked not being able to land and take off again without it toppling over. I just put the skid "prongs" back on and it fixed my problem without adding too much wieght.
Old Nov 05, 2010, 01:08 PM
Kurt is online now
Find More Posts by Kurt
Upstanding Member
Kurt's Avatar
United States, TX, Houston
Joined Sep 2003
Yeah they look cool and lose some weight, but spot landings on the bar, coffee table, speaker etc is IMO at least 1/2 the fun of flying these. I almost landed my S107 perfectly on top of my blackberry at the poker game last weekend, and did do a touch-and-go on the very peak of my buddies buzz-cut head.
I also have an empty desk in my office that is perfect for throttling up, hitting FF and shooting off the end carrier-launch style.
How did you mount the 'prongs' without their support structure? Photo?
Kurt is online now Find More Posts by Kurt
Old Nov 05, 2010, 02:15 PM
ToMaT is offline
Find More Posts by ToMaT
Joined Nov 2010
I think that my TX is not working. The LED blinks in a green light. I tried to see the IR with a camera, not succesfully. Could somebody tell me if the TX IR is visible with a camera or what can I do to solve my problem? Thanks!
ToMaT is offline Find More Posts by ToMaT
Old Nov 05, 2010, 02:27 PM
Kurt is online now
Upstanding Member
Kurt's Avatar
Joined Sep 2003
how old are the batteries? If you've been charging from the tx instead of the USB they go really fast.
Old Nov 05, 2010, 03:07 PM
salazam is offline
Joined Sep 2010
The TX IR is only visible via camera when you push on the throttle. All I can think is check the polarity of the batteries, simple yet sometimes overlooked.
Old Nov 05, 2010, 03:13 PM
gaheli is offline
Find More Posts by gaheli
Joined Nov 2010
Power Loss
Good afternoon all. I have an odd issue. I have two S107's (red/yellow) and my sons love to watch them fly. They are about two weeks old, but with a six and four year old at the controls they have seen some tough action. One of 107's is now seemingly losing power to the main rotors and while they rotate, they do not create enough lift to raise the craft in the air. I have replaced the blades as well as the gyro weight bar, and allowed for adequate charging, but it simply doesn't have the power to lift off. I'm hoping for some suggestions as I am just getting acquainted with the mechanicals.
Thanks in advance!
gaheli is offline Find More Posts by gaheli
Old Nov 05, 2010, 03:20 PM
ToMaT is offline
Joined Nov 2010
Kurt and salazam, thanks for your answer. Actually, I think that my TX arrived to me broken. I charged the heli via usb and I am using new batteries. I tried Duracell alkaline and Sony rechargeable. When I push on the throttle there is no IR signal testing it with a camera.
Somebody here knows how to solve this problem with my TX? Thanks again!
Old Nov 05, 2010, 03:26 PM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Thanks in advance!
Probably the shaft holding the lower blades is slipping on the axis, that has been reported on numerous occasions, sometimes even on new helis.
SoloProFan is online now Find More Posts by SoloProFan
Old Nov 05, 2010, 03:31 PM
gaheli is offline
Joined Nov 2010
Thanks for the reply SoloPro. Since I might be suffering from a common issue, is there a preferred procedure to test and repair? Given the delicate nature of the craft, not sure I want to grab my needle nose pliers and attack it!
Old Nov 05, 2010, 03:41 PM
salazam is offline
Joined Sep 2010
Kurt: I turned the back ones around to give it more stability, I agree, landing is half the fun!
Old Nov 05, 2010, 03:43 PM
salazam is offline
Joined Sep 2010
Regular canopy weighs 3 grams, the huey body minus paint and "glass" windows = 13 grams. hmm...
Old Nov 05, 2010, 03:47 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
There must be a guide hidden in this topic, or another. I think some of the S107 "pioneers" instantly know where to find the procedure.
Old Nov 05, 2010, 06:40 PM
killbucket is offline
Find More Posts by killbucket
I'm FAMOUS
Joined Mar 2010
Oh, I like...if you see any other model of copter this customized cosmetically, it's a clear statement of its reliability.
In any case, a full new set of mechs are an Ebay-away.
killbucket is offline Find More Posts by killbucket
Old Nov 05, 2010, 07:01 PM
Kurt is online now
Upstanding Member
Kurt's Avatar
Joined Sep 2003
Sal, I'm no expert but unless you can see something seriously wrong (like big chunks missing from the blades) it sounds like the motor(s) and/or battery may be toast.
Many people get 50++ flights, including crashes. Maybe you got particularly weak samples, or maybe you ran the batteries too low, over-stressed them by charging&running them too fast, etc.
I'm going to start following others advice to limit flight time to <3 minutes and allow 10 minutes+ of cool down inbetween charging and flights.
Maybe others can offer other advice, but I think you either need to replace the motors (which aren't cheap at $4 each from xheli-.com) and/or battery, or buy a whole new one for $27.
I've got a couple of the lighter $20 "6010 Phoenix" on the way from xheli.com, might be the way to go.
cheers
For Sale 3-channel Micro IR S107 Metal HoneyBee Helicopter No.ES0107 (with Gyro) mictopwin Aircraft - Electric - Batteries & Chargers (FS/W) 8 May 09, 2011 01:47 PM
Discussion V-max .vs. Falcon-X .vs. Syma 3 S107? 7immy Mini Helis 12 Apr 07, 2011 04:11 PM
Discussion Mosquito 3CH Radio Control Helicopter Version 2 by Syma Wayno-san Micro Ready-to-Fly 39 Dec 26, 2010 02:36 PM
