Old Oct 06, 2010, 04:12 PM
Sailhigh is offline
Find More Posts by Sailhigh
High Lift Coefficient
Sailhigh's Avatar
SF Bay Area, USA
Joined Feb 2003
Hobby People is now selling them under a different name
Sure looks like a S107 to me, though the pic isn't very clear.
http://www.hobbypeople.net/index.php...li-w-gyro.html
sean
Sailhigh is offline Find More Posts by Sailhigh
Old Oct 06, 2010, 04:33 PM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
sean
Looks like one to me as well.
As for the "I just need to get another heli" problem, there are much worse hobbies. This one is good for hand eye coordination, working on fine mechanical things, and flying releases stress. It sure is much cheaper than going to a shrink...
SoloProFan is online now Find More Posts by SoloProFan
Old Oct 06, 2010, 04:56 PM
Redfisher is offline
Find More Posts by Redfisher
Nice day for RC'ing
Redfisher's Avatar
Palmerston On. Canada
Joined Jul 2010
Looks like they just changed the stickers.
Redfisher is offline Find More Posts by Redfisher
Old Oct 06, 2010, 06:57 PM
ViperR is offline
Find More Posts by ViperR
Who's scaring the kittens
ViperR's Avatar
Joined Apr 2002
Hmmmm, My FireBird's (Nellie & Hughes 300 modded) have well over 70+ flights on each and they charge and run strong like new. I only fly each around 3 min max on each and let them cool well over an hour before re-charging. I only charge on a USB to computer. This is all as per KillB's recomendation.
ViperR is offline Find More Posts by ViperR
Old Oct 06, 2010, 07:01 PM
Nice day for RC'ing
Redfisher's Avatar
Joined Jul 2010
I just had #53 on my ebay s107 and its still going strong.
Old Oct 06, 2010, 07:16 PM
edwong3 is offline
Find More Posts by edwong3
edwong3's Avatar
Central Florida, USA
Joined Sep 2010
#55 Coming Up!
Cool! You won't believe this but I am going to be doing #55 in just a few minutes!
Happy flying,
Ed
edwong3 is offline Find More Posts by edwong3
Old Oct 06, 2010, 10:43 PM
Duck05 is offline
Find More Posts by Duck05
No. Calif Bay Area
Joined Aug 2010
sean
Why buy from them for $39 when you can get one via Amazon for $29 (and sometimes a bit less)???? And a "real" S107 to boot...
Duck05 is offline Find More Posts by Duck05
Old Oct 06, 2010, 11:17 PM
salazam is offline
Find More Posts by salazam
Joined Sep 2010
just got my sh 6020-1 and it is in NO way better than the S107. It's heavier and more sluggish and probably like a half inch bigger. Although plenty of room under the canopy for a 240 mAh battery.... maybe that'll help. Although probably not.
salazam is offline Find More Posts by salazam
Old Oct 06, 2010, 11:38 PM
arbilab is offline
Find More Posts by arbilab
Fly Runaway Fans
United States, TX, Fort Worth
Joined Jan 2009
Someone said 6020 was faster forward than 107. Is it, salazam?
arbilab is offline Find More Posts by arbilab
Old Oct 06, 2010, 11:58 PM
shock is offline
Find More Posts by shock
High Voltage
shock's Avatar
Motorcity
Joined Sep 2010
s107 Helicopter flight (2 min 7 sec)
Notice the camera can see the IR signals while our eyes cannot
shock is offline Find More Posts by shock
Old Oct 07, 2010, 06:43 AM
Nice day for RC'ing
Redfisher's Avatar
Joined Jul 2010
I never knew that, very cool.
Old Oct 07, 2010, 06:45 AM
robocat is offline
Find More Posts by robocat
Joined Oct 2010
No back/forward - blown FET
UPDATE: this is likely to be a Syma clone.
I broke half of the rear propeller. So I tried to replace it by pulling it off the rear motor, and the rear motor came apart.
I think I must have tried to fly the heli in that state, because now the H-bridge FET transistors are blown... presumably because the brushes of the rear motor were short-circuited (no rotor between them).
Moral: be careful replacing the rear propeller!
Fortunately I still have 4 other S107's left - I bought a few to hack
Here are some pictures of the main heli circuit board (This revision has 2.1mm diameter barrel plug for charging - not same as s107-18 pictures I have seen elsewhere).
The Gyro is an Invensense ISZ 650.
Shock: Very cool that you can see the IR!
robocat is offline Find More Posts by robocat
Old Oct 07, 2010, 06:57 AM
robocat is offline
Joined Oct 2010
Photos of remote control internals
This is the Remote Control revision that has a 2.1mm diameter barrel plug for charging the s107 heli (other versions have a rectangular two pin plug). Probably similar to those already posted, but another set of photos can't hurt!
Removing the throttle return spring on this revision is a bit difficult - it is not on the outside of the joystick metal support case.
Instead you have to forcibly wrench it out from inside of the joystick metal support case (don't let it ping back inside, or it is very difficult to get hold of again, and the throttle won't move freely).
Old Oct 07, 2010, 08:49 AM
killbucket is offline
Find More Posts by killbucket
I'm FAMOUS
Joined Mar 2010
Cost-Reduction strikes! I bet it's cheaper to use the new part, even though IT is probably costlier than the old injection-molded plastics.
A Human had to place and lube those.
killbucket is offline Find More Posts by killbucket
Old Oct 07, 2010, 10:22 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Has it already been confirmed that helis with a round plug are genuine Syma? Both my rev 3 and rev 5 have a square plug.
For Sale 3-channel Micro IR S107 Metal HoneyBee Helicopter No.ES0107 (with Gyro) mictopwin Aircraft - Electric - Batteries & Chargers (FS/W) 8 May 09, 2011 01:47 PM
Discussion V-max .vs. Falcon-X .vs. Syma 3 S107? 7immy Mini Helis 12 Apr 07, 2011 04:11 PM
Discussion Mosquito 3CH Radio Control Helicopter Version 2 by Syma Wayno-san Micro Ready-to-Fly 39 Dec 26, 2010 02:36 PM
