Old Oct 05, 2010, 12:42 AM
Did you check the FAQ already?
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Originally Posted by kross1 View Post
We had 2 Syma S107's that had a wire break off of the front motor, right where the wire enter the motor. The wire could not be easily reconnected.
I took the REAR motor from 1 bird, and installed it into the FRONT of the other bird, reversing the polarity on the 2 wires when I soldered them to the circuitboard.
WORKS FINE.
The 2 motors (front & rear) are the same, they just have different color leads. You can substitute the front or rear motors, you simply have to make sure you get the polarity correct as they rotate in opposite directions.
Now, why the wires broke, see my next post!!!!!!!
The motors should be different. The brushes inside have a different orientation, so it has less drag on the collector when it turns CW or CCW. You can swap them, but they won't last as long when swapped. More coaxes have this, also indicated by different colors of the endcap, and not just the wires.
SoloProFan is offline Find More Posts by SoloProFan
Old Oct 05, 2010, 01:08 AM
Is it charged-up yet?
Tom DB's Avatar
Miami, FL
Joined Sep 2010
Interesting you should mention that. My R3 does indeed have black and white endcaps, but my R5 has two black endcaps. I hadn't noticed that before.
Tom DB is offline Find More Posts by Tom DB
Old Oct 05, 2010, 06:14 AM
kross1's Avatar
USA, NY, Dryden
Joined Feb 2010
Time will tell, I'll let you all know! It's about time to buy new birds, our are so whipped!!!!!
kross1 is offline Find More Posts by kross1
Old Oct 05, 2010, 06:38 AM
Hovering is a way of Life
jtravel's Avatar
Arizona
Joined Aug 2010
Originally Posted by Duck05 View Post
The one S107 we had that displayed the loss of power behavior was not the battery; when swapped out with a new one (along with the PCB protection circuit board) it displayed the same symptom right away. The assumption was the main board caused the issue but never had to verify that as the supplier provided an exchange.
Interesting, I assume this Was the power loss after 2 min issue?
jtravel is offline Find More Posts by jtravel
Old Oct 05, 2010, 10:39 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Sounds like someone goofed up during asembly...
Old Oct 05, 2010, 10:42 AM
Nice day for RC'ing
Redfisher's Avatar
Palmerston On. Canada
Joined Jul 2010
Mine has blacks caps on both.
Redfisher is offline Find More Posts by Redfisher
Old Oct 05, 2010, 10:48 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Wires also same color?
Old Oct 05, 2010, 11:09 AM
edwong3's Avatar
Central Florida, USA
Joined Sep 2010
Blank and White
If you guys are talking about the colors of the end bells on the motors, the motor closer to the nose is black, and the rear facing motor has a white 'cap' as you call it.
Happy flying,
Ed
edwong3 is offline Find More Posts by edwong3
Old Oct 05, 2010, 11:21 AM
Nice day for RC'ing
Redfisher's Avatar
Joined Jul 2010
Nope the front motor has blue,red and the rear has black,white.
Old Oct 05, 2010, 12:54 PM
Tom DB's Avatar
Miami, FL
Joined Sep 2010
Same here on both revisions.
Old Oct 05, 2010, 05:23 PM
No. Calif Bay Area
Joined Aug 2010
That's what I had thought too but one other aspect was after loss of altitude the copter could not get off the ground the battery was not out of power. You could keep running the rotors for quite some time afterward.
With a new, fully charged battery (and new on the battery PCB) it did the same thing leading to the belief the main board was the issue.
Duck05 is offline Find More Posts by Duck05
Old Oct 05, 2010, 05:26 PM
No. Calif Bay Area
Joined Aug 2010
Happy flying,
Ed
All of mine are that way (Black cap red/blue front; White black/white rear).... All rev 3s including the Firebird....
Old Oct 05, 2010, 05:32 PM
jtravel's Avatar
Arizona
Joined Aug 2010
Same goes for my Rev 5 S107 and Firebird
Old Oct 05, 2010, 05:39 PM
Nice day for RC'ing
Redfisher's Avatar
Joined Jul 2010
Enough talk, Time for a flight!
Old Oct 05, 2010, 07:29 PM
Joined Oct 2010
New S107 owner
Hi,
Bought the s107 at a computer fair yesterday for $35.
I used it today, worked straight out of the box. A couple of small crashes but nothing too big.
Eventually the power went, so I connected the usb cable with power switch set to on and the red and blue light was on, a few moments later just the red was on then nothing, an hour later, no charge, no anything.
There's a greeen led blinking on the back too for awhile.
Ocassionally it'll swirl and quickly pita out.
Any trouble testing measures I can take?
Jeff
hdtvjeff is offline Find More Posts by hdtvjeff
For Sale 3-channel Micro IR S107 Metal HoneyBee Helicopter No.ES0107 (with Gyro) mictopwin Aircraft - Electric - Batteries & Chargers (FS/W) 8 May 09, 2011 01:47 PM
Discussion V-max .vs. Falcon-X .vs. Syma 3 S107? 7immy Mini Helis 12 Apr 07, 2011 04:11 PM
Discussion Mosquito 3CH Radio Control Helicopter Version 2 by Syma Wayno-san Micro RTF 39 Dec 26, 2010 02:36 PM
