Old Jun 11, 2010, 03:41 PM
write2dgray is offline
Find More Posts by write2dgray
write2dgray's Avatar
United States, NJ, Princeton
Joined Dec 2006
Originally Posted by mrhelichopper View Post
...One small question the reples did raise for me is: If packs have been supplied as parrallel packs and charged as such safely for a few years now, why do we need safe parallel adaptors?
Kind regards once again
mrhelichopper
Polyfuses are integrated for protection against the potential inrush current of grossly mismatched (state of charge) packs or a possible inadvertent (i.e. backward polarity) connection.
- David
write2dgray is offline Find More Posts by write2dgray
Site Sponsor
Old Jun 11, 2010, 04:47 PM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
<snip>
mrhelichopper
I think that since LiPo's have greatly increased in capacity per cell there are fewer 2p packs being produced. So now packs charged in parallel aren't as likely to be matched as when they were assembled as 2p. Also with the advent of higher wattage chargers parallel charging is more prevalent. And taking a relatively inexpensive precaution is a good idea.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Jun 11, 2010, 05:55 PM
Jeff_edge540 is offline
Find More Posts by Jeff_edge540
Mis-guided heli guy
Jeff_edge540's Avatar
Austin, TX USA
Joined Mar 2007
Please help me understand why you would connect multiple PL8's together to be controlled by a single (master) charger..
Wouldn't it be more convenient to have each charger to work independently?
Jeff_edge540 is offline Find More Posts by Jeff_edge540
Old Jun 11, 2010, 07:59 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Depends, say you have two 6 ,7 or 8S that you run in series. You fly them together and charge them together. Two PL8 in Primary / Secondary configurateion means you only set the Pri. and the Sec. follows along. The same goes for large packs up to 8S which you use in parallel.
It is very simple to go from ganged ( Primary / Ext. ) back to two seperate ones and besides no one I am aware of offers a single case 2,000 watts charger.
Charles
Old Jun 11, 2010, 08:09 PM
Southern Pride
mrhelichopper
FMA wants to make parallele charging as safe as possible. As I posted very early in this thread I charged both 4ea. 3 S and 4 ea. 4S Lipoly as 6S2P and 8S2P in order to be able to test this beast at high output levels. That was the only way I could really load it with my meager 3 and 4S 3300 LiPolys. My series / parallel adapters had no safety devices what so every but I was extremely careful and knew the pack's histories, and that all balancing leads / connectors were in excellent condition.
If you read tens of thousands of post like I do then it would obvious that many make all kind of mistakes when attempting parallel charging. Seems I read a post a week where some one toasted a parallel charging board or worse.
Charles
Old Jun 15, 2010, 03:56 PM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
Originally Posted by Tim Marks View Post
Hi:
The PL8 manual is nearly finished. We are going to a new format for it that ties into the CCS directly. It's one of those so-called on-line help manuals. So there's some coding involved that will start soon. We could release a simple PDF version, but we also intend to publish the first production version of the CCS as soon as the manual is complete. This way customers can download and install the CCS (don't need a charger now to actually see how things work in there), and read the manual from within the CCS as well. I hope this can all be ready some time next week.
Tim Marks
Hi Tim, any update on when the PL8 CCS will be available?
Ohmic is offline Find More Posts by Ohmic
Old Jun 15, 2010, 03:59 PM
cmulder is offline
Find More Posts by cmulder
Ireland
Joined Apr 2001
comparison table
is there a table that compairs the new 1kW chargers so i can have a more simpler overview to see wich suits my needs most?
For example weight is a issue since it influence shipping cost.
cmulder is offline Find More Posts by cmulder
Old Jun 15, 2010, 06:41 PM
Mis-guided heli guy
Austin, TX USA
Joined Mar 2007
until the PL8 ships - there is only one 1kw charger currently on the market.
Old Jun 15, 2010, 07:54 PM
redgreen is offline
Find More Posts by redgreen
Joined Apr 2007
Is the first batch being assembled / tested, or are they still being held up by the manufacturer?
redgreen is offline Find More Posts by redgreen
Old Jun 15, 2010, 10:04 PM
gww528 is offline
Find More Posts by gww528
gww528's Avatar
United States, FL, Jacksonville
Joined Mar 2008
I called FMA yesterday. They are testing this week and shipping next week!
gww528 is offline Find More Posts by gww528
Old Jun 16, 2010, 12:59 PM
Tim Marks is offline
Find More Posts by Tim Marks
President, FMA, Inc.
Tim Marks's Avatar
Joined Mar 2008
PL8 Charge Control Software (CCS) is available!
The PL8 Charge Control Software (CCS) is available for download and install at the following link: http://www.fmadirect.com/new_applica..._software.html This Windows program does not require that you have the PL8 in order to install and run the software. Check the on-line help with direct access to pertinent information by clicking the "?" buttons throughout the various tabs.
Tim Marks is offline Find More Posts by Tim Marks
Old Jun 16, 2010, 01:14 PM
Mis-guided heli guy
Austin, TX USA
Joined Mar 2007
Sweet! Thanks Tim.
Can I use the CCS with the 10S?
Old Jun 16, 2010, 01:42 PM
Howard Matos is offline
Find More Posts by Howard Matos
AR-15 BRD!
Howard Matos's Avatar
Frederick, MD
Joined May 2002
Originally Posted by Jeff_edge540 View Post
Sweet! Thanks Tim.
Hi,
The Cellpro 10S has it's own CCS. Here is the link:
Cellpro 10s Charge Control Software
(File type: Web Reference The Cellpro 10s charge control software adds many new features to the charger. Edit presets, configure power supplies, change charger settings and update to the latest firmware. Requires the FUIM2 two way PC interface.
Howard Matos is offline Find More Posts by Howard Matos
Old Jun 16, 2010, 01:46 PM
Mis-guided heli guy
Austin, TX USA
Joined Mar 2007
Thanks Howard. I use the 10s's software - i was just wondering if I could use both chargers with the PL8's software. I guess the 10S need to stay with it's own CCS?
Old Jun 16, 2010, 02:37 PM
RCnGuy is offline
Find More Posts by RCnGuy
What's Nitro?
RCnGuy's Avatar
United States, IL, Schaumburg
Joined Dec 2007
Howard, I'd also like to know if I can use the FUIM3 interface with my CP 10S charger?
Dave
RCnGuy is offline Find More Posts by RCnGuy
Discussion Sneak Peek! 2, 1:8 scale scratchbuilts ooby Scale Boats 34 May 22, 2015 10:41 PM
Discussion Proposed schemes for 2010 season RAF BAe Hawk display-sneak peek! Matt Halton Electric Ducted Fan Jet Talk 3 Dec 20, 2009 03:11 AM
Discussion Sneak Peek at the New Creation Museum Miami Mike Life, The Universe, and Politics 38 May 30, 2007 05:01 PM
Hey Mr. Lin, how about a sneak peek at the Hellcat? splatman GWS (Grand Wing Servo) 1 Jul 05, 2003 04:43 AM
