Old Feb 01, 2013, 07:54 AM
helicow is online now
Find More Posts by helicow
Gravity gets me down.
helicow's Avatar
USA, FL, Brooksville
Originally Posted by ArnhemAnt View Post
Good advice.
However $2.25 for a pack of 10 and then $15.00 shipping to Australia......??
You could use unused female deans in a pinch to cover the exposed pins.
Just an idea.
helicow is online now Find More Posts by helicow
Old Feb 01, 2013, 08:34 AM
Snowflake6515 is online now
Find More Posts by Snowflake6515
Michael
United States, ME, Wells
Joined May 2008
Deans Caps
An alternative is to cut pieces of heat shrink tubing and shink to a loose fit; i.e., tight enough not to flop off with moderate handling, but not so tight that you struggle with getting 'em off.
I leave a length above the tops so that, after it is shrunk, it can serve as a "handle" to remove/place the caps.
IIRC, I took a spare male Deans, wrapped a layer of masking tape around the exposed male pins, then did the heat shrink bit. I vaguely recall that might have been a little on the loose side; been a while. Hence, my suggestion to not overly shrink the tubing on just the bare pins.
Michael
Just an idea.
Snowflake6515 is online now Find More Posts by Snowflake6515
Old Feb 01, 2013, 04:14 PM
ArnhemAnt is offline
Find More Posts by ArnhemAnt
Australia, NT, West Arnhem
Joined Mar 2012
Thanks for the suggestions guys. I will give it a go as I am sure I will come up with something that will work.
ArnhemAnt is offline Find More Posts by ArnhemAnt
Old Feb 03, 2013, 12:10 PM
cloud_9 is offline
Find More Posts by cloud_9
Jim in the Desert
United States, NM, Las Cruces
Joined Aug 2007
Sorry for the dumb question (and I have not read the entire thread, sorry). What power supply specs are needed to realize full potential of this charger?
thanks
Jim
cloud_9 is offline Find More Posts by cloud_9
Old Feb 03, 2013, 12:50 PM
ggcrandall1 is online now
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
From the PL8 Users Manual:
To take advantage of PowerLab 8’s full power capability, the power source should be
26.35V DC (higher voltage does not improve output power), and capable of delivering a
minimum of 60A to PowerLab 8’s input. Per Ohm’s law, 26.35V x 60A = 1581W. However,
it is generally not advisable to pull 100% of available power from a DC power
supply. Therefore, if you want to attain 1344W of output power to an 8s Li battery, the
power supply should be capable of 1700W or higher for best results.
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Old Feb 03, 2013, 03:46 PM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
thanks
Jim
Also remember the power supply requirements depend on cell count. For instance I can max out my Powerlab8 with 6s packs using a 24v, 45 amp supply.
Gregor99 is offline Find More Posts by Gregor99
Old Feb 03, 2013, 04:32 PM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
thanks
Jim
Your best bet is to experiment yourself with calculators on the Revolectrix website.
Ohmic is offline Find More Posts by Ohmic
Old Feb 04, 2013, 09:31 PM
picco007 is offline
Find More Posts by picco007
SA, TX
Joined Sep 2009
Hey everyone! I'm a newbie to the PL8. I've tried to find the right answer and I don't think i have found what I need. I am trying to do a storage charge or discharge on my batteries. I'm wanting to know if there is a setting that i am missing that I can set the charge to one of the presets that say all lipo storage and with a push of a button it will either charge or dishcarge the battery to the set voltage without me having to select charge only, discharge only. Can anyone help me?
I have tried to use the storage charge preset but it charges it fully, I searched and one person said the had a present for storage and the charger knew to either discharge or charge to the storage value. Can someone tell me where in the software or in the charger to set this up to storage charge or discharge?
I'm doing only 2S and 4S at this time.
Thanks in advance
picco007 is offline Find More Posts by picco007
Old Feb 04, 2013, 10:14 PM
Gregor99 is offline
Seattle
Joined Sep 2007
If the settings for the storage preset (preset #7), has not been altered, and the LiPo pack over storage level, the pack be discharged to 3.85v per cell. If the pack is below storage level, the pack will be charged to 3.85v per cell.
Old Feb 04, 2013, 10:19 PM
picco007 is offline
SA, TX
Joined Sep 2009
Thank you, they were altered.....My fault, I will copy and paste it....that should do it, correct?
Old Feb 04, 2013, 10:25 PM
Gregor99 is offline
Seattle
Joined Sep 2007
Restore from the library preset and that should be fine. Use copy and paste to restore library preset 8 to regular preset 7.
Old Feb 04, 2013, 10:30 PM
picco007 is offline
SA, TX
Joined Sep 2009
I was looking at my library and #7 preset is 1s/2s small non balanced, Preset #8 is All Brands Storage Charge and #9 is High power storage charge. So I updated the presets to factory default settings. Now i'm using Preset #7 and it automatically started to discharge and or charge to storage voltage.
I will begin to rebuild my library but I want to know what I changed to make it not storage charge or discharge automatically.
Thanks.
Old Feb 04, 2013, 11:10 PM
Gregor99 is offline
Seattle
Joined Sep 2007
Probably charge voltage or discharge voltage.
Old Feb 04, 2013, 11:47 PM
picco007 is offline
SA, TX
Joined Sep 2009
I'll take a look at that more carefully. Thanks
Old Feb 08, 2013, 01:34 AM
apper001 is offline
Find More Posts by apper001
Switzerland, ZH, Zürich
Joined Nov 2012
just experienced the level of customer service at revolectrix, worth every bloody penny
apper001 is offline Find More Posts by apper001
Discussion Sneak Peek! 2, 1:8 scale scratchbuilts ooby Scale Boats 34 May 22, 2015 10:41 PM
Discussion Proposed schemes for 2010 season RAF BAe Hawk display-sneak peek! Matt Halton Electric Ducted Fan Jet Talk 3 Dec 20, 2009 03:11 AM
Discussion Sneak Peek at the New Creation Museum Miami Mike Life, The Universe, and Politics 38 May 30, 2007 05:01 PM
Hey Mr. Lin, how about a sneak peek at the Hellcat? splatman GWS (Grand Wing Servo) 1 Jul 05, 2003 04:43 AM
