Old Jan 12, 2013, 12:28 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
I can't quite figure out what charge state in volts corrisponds to the fraction of mAhs stored. I know that 3.85v is 50% and ~4.2v is 100% charged. (Please correct me if I'm wrong.) I don't think that a linear interpolation between the two values is correct though.
State of charge as a percentage is available during the charge in addation you can open the CCS , choose a Preset ,click on the Fuel Tab and see the % and Voltages or use this link for a PL fuel table I have posted many times
http://www.rcgroups.com/forums/attac...5&d=1299261126.
Charles
Old Jan 12, 2013, 04:28 PM
JimHSoars is offline
Find More Posts by JimHSoars
United States, OK, Tulsa
Joined Jun 2003
Thanks Charles.
- Jim
JimHSoars is offline Find More Posts by JimHSoars
Old Jan 13, 2013, 07:54 AM
bob_nj is online now
Find More Posts by bob_nj
bob_nj's Avatar
Vineland, N.J.
Joined Sep 2003
Single Cell Anomoly??
I'm trying to revive a Dremal pack one cell at a time.
They are .700 NiCads.
I can get around 8 minutes into a single cell cycle but then the "Wrong Cell Count" error keeps popping up.
I've used bananas and a modified node harness that works for other things.
I'm using a nicad preset and it looks to be configured properly.
Any ideas?
Bob
bob_nj is online now Find More Posts by bob_nj
Old Jan 13, 2013, 10:30 AM
apper001 is offline
Find More Posts by apper001
Switzerland, ZH, Zürich
Joined Nov 2012
advanced settings explanation
proud owner of a pl6 here!
just found out that i need some support in finding out the correct meaning of the advanced settings, any pointers ?
haven't come round to reading this complete thread.
thx,
apper
PS. i know this is the pl8 thread
apper001 is offline Find More Posts by apper001
Old Jan 13, 2013, 11:30 AM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
Hover over the option and there will be a popup text that gives a brief explanation of each option. If anything is unclear, check to see if its in the manual. If its not listed, or the manual is unclear, post a request for info in this forum.
Gregor99 is offline Find More Posts by Gregor99
Old Jan 13, 2013, 11:37 AM
JohnathanSwift is offline
Find More Posts by JohnathanSwift
Greenland
Joined Mar 2012
thx,
apper
Fellow travelers are always welcome!
JohnathanSwift is offline Find More Posts by JohnathanSwift
Reply With Quote  (Disabled)
Old Jan 13, 2013, 08:18 PM
jocanon is offline
Find More Posts by jocanon
jocanon's Avatar
United States, AZ, Phoenix
Joined Jul 2010
Does anyone know how to hook up an 8s lipo that has 2 X 4 cell JST-XH balance plugs to the PL8? Is there a separate adapter that needs to be purchased for the two balance plugs?
jocanon is offline Find More Posts by jocanon
Site Sponsor
Old Jan 13, 2013, 11:18 PM
Gregor99 is offline
Seattle
Joined Sep 2007
Very carefully. That's a serial connection which is easy to get wrong and cause short. I posted about my 8s setup recently.
http://www.rcgroups.com/forums/showt...s#post23618087
Old Jan 13, 2013, 11:43 PM
jocanon is offline
jocanon's Avatar
Joined Jul 2010
Just to be clear, this is the battery I am talking about:
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
So the only way to charge it on a PL8 us to series charge it? Is there an adapter ready made for this that can be purchased from FMA or anywhere?
Thanks for your help.
Site Sponsor
Old Jan 13, 2013, 11:54 PM
mrforsyth is offline
Find More Posts by mrforsyth
So. Cal.
Hey Jeremy,
One of my buddies has the same battery and searched high and low for the series JST-XH adapter and could not locate one. As such, I fished a few connectors out of my bin and brewed one up for him.
To make one, you'll need a 9 position JST-XH male and two five position JST-XH female connectors and simply wire the two female connectors to the 9 pin male connector. I color coded both the two males on his battery and the two female connectors on the adapter with red and black sharpies so it would be extremely difficult to let the magic smoke out.
Greg's photo is excellent and shows exactly how to wire it up.
Mark
mrforsyth is offline Find More Posts by mrforsyth
Old Jan 14, 2013, 12:00 AM
jocanon is offline
jocanon's Avatar
Joined Jul 2010
Thanks guys, looks like I will have to do the same.
Now, is it still possible to parallel charge 3 of these batteries? I usually parallel charge 6 4s lipos without problems on my FMA paraboard, that is a total of 24 cells which 3 8s's would also be 24 cells.
Site Sponsor
Old Jan 14, 2013, 12:05 AM
So. Cal.
No problem at all. I have parallel charged sixteen 3S batteries at the same time before. That's 48 cells.
Incidentally, David has 8S JST-XH pigtails so you can pick up some of these and all that you would need to complete your adapter are some 5 position JST-XH female connectors. I likely have some in my bin. PM me if interested.
8S JST-XH male pigtail: http://www.progressiverc.com/8s-jst-xh-pigtail.html
Mark
Old Jan 14, 2013, 12:32 AM
Gregor99 is offline
Seattle
Joined Sep 2007
As Mark says, no problem at all. The MPA parallel board does support up to six 8s packs.
Old Jan 14, 2013, 12:33 AM
jocanon is offline
jocanon's Avatar
Joined Jul 2010
Nice, gotta love it
Site Sponsor
Old Jan 14, 2013, 08:38 AM
jocanon is offline
jocanon's Avatar
Joined Jul 2010
Alright, on this 8S battery you have two 4s balance plugs coming out and one main power lead. So I understand now that I need to get a 9 position male JST-XH and connect it to two 5 position females to make a balance wiring adapter. From the pictures I can see that the two females are color coded, one red and one black because I gather if you hook them up the wrong way you will short them. So my question is, how do I know which balance connectors go to which? Can someone point me in the right direction that will show me how to wire and connect this up without smoking the battery?
Jeremy
Site Sponsor
Discussion Sneak Peek! 2, 1:8 scale scratchbuilts ooby Scale Boats 34 May 22, 2015 10:41 PM
Discussion Proposed schemes for 2010 season RAF BAe Hawk display-sneak peek! Matt Halton Electric Ducted Fan Jet Talk 3 Dec 20, 2009 03:11 AM
Discussion Sneak Peek at the New Creation Museum Miami Mike Life, The Universe, and Politics 38 May 30, 2007 05:01 PM
Hey Mr. Lin, how about a sneak peek at the Hellcat? splatman GWS (Grand Wing Servo) 1 Jul 05, 2003 04:43 AM
