The FMA Multi4 charger Manual covers the CCS interface and Presets fairly well. The PL8 having 4 Control switches makes moving around to /in the different menus much easier.
Many here know me and I am very hard to please. This charger can be as simple to use as a CellPro 4 or Cell Pro 10 but with power / range that is unreal. Charge rates from 10 mA to 30amps. ,1S to 8S LiPoly along with all the other battery chemistries . The out of the box User's presets cover more options than most will ever need. The class I refer to as Power users can tweak to their heat's content.This charger gives the user almost unlimited excess to all options ,the only choices which are not available are ones which would knowingly create Safety Issues. An outline of the Mulit 4 Presets and CCS is located here: http://www.fmadirect.com/faqs.htm?category=45 FYI I do not own a Multi 4 so had no prior experience with the computer interface other than with the Cell Pro 10 which is extremly limited in comparison. I found the CCS very intutive and was up to speed in a very short time. Once again the PL8 out of the box will serve most users just fine but the ability to fine tune is there for those who desire their own custom settings. Charles |
Joined Nov 2006
Guys, we have an answer from an FMA engineer on the PL8 project regarding the use of the Opto Isolated interface as it is rather than a direct USB connecter. Here it is:
If for some reason the user were to remove ground from the power supply while the competitors charger were running, up to 50 amps could go directly to the mother board of their computer thru the USB cable. Somehow, I don't think 28 gauge wire will handle 50 amps. The ground circuit is made thru the earth ground of the power supply and computer supply. This is why all our chargers use opto isolated USB interfaces. It can't smoke the computer. |
Joined Nov 2006
If you guys participating in the beta program can't speculate, how about contacting someone from FMA to get on and post the MSRP?
Jack[/QUOTE] I know the guys at FMA want to get this information to you as soon as they can, so please be patient. Things are going very well with this project, but they need a bit more time before making commitments regarding price and schedule. |
Good Day Fellow RCers
I thought some of you might like seeing some screen shots of a 5 cycle charge/discharge I did last night. These cycle were on an old, old ElectriFly 640mAh 2s battery. So nice to have a battery management system that will do both charge and discharge as many times as you want. Just set it up, click start and watch it do its thing. Jack Doherty |
A few more pictures and screen shots.
It is so nice to parallel charge 3 3000mAh @ 2C 15A (max current for these batteries) for my Trex 500 at the same time in less than 25 min. If I had them, I could charge 6 of these batteries with the PowerLab in the same time. Jack Doherty |
The first thing I did was make a series parallel harness / adapters so I could charge 4 ea. 4S as 8S2P.
I have charged 4ea/ 4S 3300 LiPolys using these at 30 amps. or 4.5C rate. Added a 840 watts plus graph. Update Now that V1 has been replaced with V2 available max. Amps is 40 above could be charged at 6C. charles
Massachussets
Joined Nov 2005
Jack Why does the Ahr in and Ahr out differ and gradually decrease? |
Ah good observation. Notice that I said the battery pack is an old, old pack. As you can see from the graphs it is only accepting 42mAh to 47mAh in and it was a 640mAh battery when new. As packs get old and resistance increase the temperature during multiple charges increase which affects the capacity of the battery, hence the gradual decrease. This is a great instance to show the power of the PowerLab in diagnosing the quality of a battery pack. In this case very bad battery. Jack |
| Thread Tools | |
| Discussion Sneak Peek! 2, 1:8 scale scratchbuilts | ooby | Scale Boats | 31 | Jul 24, 2011 08:30 AM |
| Discussion Proposed schemes for 2010 season RAF BAe Hawk display-sneak peek! | Matt Halton | Electric Ducted Fan Jet Talk | 3 | Dec 20, 2009 03:11 AM |
| Discussion Sneak Peek at the New Creation Museum | Miami Mike | Life, The Universe, and Politics | 38 | May 30, 2007 05:01 PM |
| Hey Mr. Lin, how about a sneak peek at the Hellcat? | splatman | GWS (Grand Wing Servo) | 1 | Jul 05, 2003 04:43 AM |
