Collierville, TN
Joined Aug 2003
Not a miracle drug, but it sure is a productivity booster. I just ordered four more Safe Parallel adapters and will be rigging my 2 PL8's for 4P charging. . My charge box is going to look like a sow with eight little piggies . . . . . |
Seattle
Joined Sep 2007
#3 Chem Name / CHG 0.00a #7 Elapsed Time / Chem / Mode #4 Start Fuel / Start Low cell I can understand the support concerns Tim raised. But leave as hidden and those that know what it can be used for can enable it. |
Australia, WA, Perth
Joined May 2007
I think I found a bug in 3.27.
I'm not at home, so I can't submit a dump, but hopefully someone else can replicate it. On a storage charge (preset 7), I have the charger on the new screen. When I press INC 4 times, it goes to the cell voltage page. I then press DEC 4 times to return to the status page. When done slowly, all is well, but if I scroll through the pages rapidly, the. charger throws up error code 156 (network buffer full??) Anyone else able to do that, or am I lucky?
USA
Joined Jan 2002
Last I recall only one person requested balanced storage discharge and that was implemented fairly quickly. |
Seattle
Joined Sep 2007
I didn't think so when I charged 6 packs a little while back only to find all the packs were wildly out of balance. I ended up finishing each pack individually. Even though they were almost fully charged, it took each pack 10 to 15 minutes each. Multiply that times 6 plus the time for the original parallel charge. No so much of a productivity booster.
I've noticed that if I'm cycling packs that have recently used or balanced, its far less of an issue. But if the packs have been sitting for a couple weeks, it seems safer and faster affair to charge them individually. Here is an example from today. These packs were cycled last Saturday, so this is not as bad as it can get. After parallel charging 2x 6s 3300 at 3c each, cell #1 was 4.195 on pack1 and 4.167 on pack 2. A difference of 0.028v. Not horrible, but far from perfect. Considering these cells were connected directly together during the entire charge it makes you wonder how this can even happen. To answer that question, I thought it would be interesing to see how long it would take for the cells to equalize if I left them connected to the parallel harness (not being charged). After 5 minutes the delta had only dropped to 0.023v. After 10 minutes the gap was down to 0.015v After 25 minutes it was down to 0.005v. Considering that at 3c the charge time only lasts about 15 minutes, this may not be enough time for parallel cells to equalize. It seems that if you are going to parallel charge, lowering the charge rate to 1c would help alot, giving the cells more time to equalize. But at that reduced rate, the charge time would be considerably longer and it may not be any faster than charging the packs individually. I'm also considering charging to 4.15v. Then allow the parallel packs to set for 15-20 minutes, alowing the cells to equalize. Then restart the charge and let the PL8 rebalance the cells. Or perhaps I just need to buy 3 more Powerlab8s
The tech docs are excellent!
Very clear and helpful. My control sw should be up soon. Thanks! Sent from my thingamajig www.eraviv.com |
Snip from a recent post Quote:
IMO if each feacture which was not understood by many was simplie elimimated the PL8 would become a lot like a CP10XP very quickly. Fact is I have used PowerLab 8 s rather extensively for a fairly long period in time and no fooling thousands of charges and I do not claim to understand all of its' capabilities. Charles |
For those who may be unaware the Balance Power % of bypass was first introduced in the CellPro 10 years ago. One solution is not not upgrade past V 3.25 unless you really want the consolidated screen and the Parallel Yes to multiply the set charge rate intead of dividing it. Charles |
Seattle
Joined Sep 2007
What I was asking is: "Is there a limit within the charger with regards to the storage different screens?" If not, why not just make the balance percentage screen hidden to address the customer confusion issues?
I've been waiting for the parallel charge logic change for some time, so I'm reluctant to give that up. |
Balance % Screen Update
Hi:
O.K. Wow! We never dreamed removing the BAL % screen would result in such an outcry from users! Sorry for that. But clearly we need to reconsider this decision based on your collective feedback. Since it seems that some customers truly value this screen, and those who do are likely well equipped to manage screens using the CCS, here's what we'll do: 1) There are currently 13 data screens available in the PL8, not 11, as Gregor99 indicated. If you use the pull-down on the screens tab to choose the screens to assign to a preset, you can count the total there. Not every screen applies to every chemistry. The Greeting screen is mandatory, but it still needs to be counted. 2) We think it would be a mistake to sacrifice any of the other data screens to put the BAL % screen back in, nor is it necessary. This solution would likely just result in the same outcome: somebody else will miss whatever screen we chose to remove entirely, and there really is no support issue with the other screens used on the PL8. 3) What we plan to do is add back the BAL % screen as the 14th screen. We won't add it back to the presets by default and hide it as has been suggested, because then a Factory Default would be required with the next firmware revision. 4) Any customer who truly values the BAL % screen will be able to add it to one of the EMPTY screens of any Li preset using the CCS. Currently there are 12 screens provisioned for each Li preset, but only 11 are utilized by default. So a customer can add the BAL % screen back as the 12th EMPTY slot and still have this old screen as well as all the other screens if he so chooses. Optionally, he can replace any screen with the BAL % screen. 5) We will have to release changes to beta testers again. I can not put a precise time-frame on it at this time, nor can I say in what revision it will appear; but it will likely occur in v3.28. As usual, once beta testers give us the green light, we'll release it to the public. I would estimate this to require about 2-4 weeks to accomplish. In the mean time, we recommend that customers weigh the value of new features in the v3.27 release, and make a decision for themselves whether to keep it or revert to v3.25 to get the BAL % screen back. It is important to note that this plan should meet the criteria we established to remove a "support headache" while at the same time providing customers with a product that does not sacrifice functionality. Hoping this makes everybody in PL8 land happy! Tim Marks |
| Thread Tools | |
| Discussion Sneak Peek! 2, 1:8 scale scratchbuilts | ooby | Scale Boats | 31 | Jul 24, 2011 08:30 AM |
| Discussion Proposed schemes for 2010 season RAF BAe Hawk display-sneak peek! | Matt Halton | Electric Ducted Fan Jet Talk | 3 | Dec 20, 2009 03:11 AM |
| Discussion Sneak Peek at the New Creation Museum | Miami Mike | Life, The Universe, and Politics | 38 | May 30, 2007 05:01 PM |
| Hey Mr. Lin, how about a sneak peek at the Hellcat? | splatman | GWS (Grand Wing Servo) | 1 | Jul 05, 2003 04:43 AM |
