Old Jan 15, 2010, 08:17 PM
SteveM732 is offline
Find More Posts by SteveM732
SteveM732's Avatar
United States, OR, Beaverton
Joined Feb 2008
Originally Posted by jfetter View Post
I do have 2 questions though. First, Charles is right, if you're planning on using a USB-to-serial dongle, please consider a mini USB port instead, USB is a standard on computers today and all the Serial dongles I have are piling up! Second, wouldn't you expect this much power to lend itself to a dual port charger? Why the single?
The PL8 uses the same type of interface as seen on the 10S and Multi4 so you'll still need an FMA dongle. I too am a fan of integrating the USB hardware, but its a trade-off I can live with.
Lastly, I scanned the specs twice but didn't notice if this charger measures IR? For me, this will be a new requirement for all chargers I purchase, it's one of the few tools we have to measure battery performance compared to a point-in-time and frankly the only way to compare cells from vendor-to-vendor and generation-to-generation.
Yes, it measures IR when charging and using both the balance tap and main leads. You can also plot IR for each cell if you have it plugged into your PC while charging. Another interesting graph that you can make is of cell charge (in mAh) versus volts. Of course these are in addition to the normal plots of cell voltage, pack voltage, current, and fuel level.
SteveM732 is offline Find More Posts by SteveM732
Old Jan 15, 2010, 08:18 PM
everydayflyer is online now
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
USB to PL8 interface is same as Cell Pro 10 , Multi charge 4 other than this one is faster and I believe it is the same as the one used with Co Pilot II but stand to be corrected.
Yes it measurs cell IRs and it does it faster than the CP10, some where in the order of 3 minutes into a charge as long as cells are at less than 75% full at start.
As noted above Smart balancer under development for super safe/ easy parallel charging.
I have charged 4ea. 4S 3300 LiPolys configured as 8S2P at 30amps. I habe also charge a single cell 120 mAh LiPoly. 10mA -30A 1-8S covers a lot of battery packs.
Charles
everydayflyer is online now Find More Posts by everydayflyer
Old Jan 15, 2010, 08:23 PM
SteveM732's Avatar
Joined Feb 2008
PL8 action shot
I thought I'd share a picture of the PL8 in action. It is powered from a pair of deep cycle batteries wired in series and is charging a 4S2P and 3S2P A123 pack wired in series using a pair of special cables that come with the PL8.
Note that the appearance of the faceplate on the final product will be different, see post #1 for a look at the final product.
Old Jan 15, 2010, 09:43 PM
zguy is offline
Find More Posts by zguy
Team SCHC
zguy's Avatar
SoCal
Joined Dec 2005
SOLD!
When, how much and will you be offering a matched power supply?
VERY nice work!
zguy is offline Find More Posts by zguy
Old Jan 15, 2010, 10:13 PM
RCnGuy is offline
Find More Posts by RCnGuy
What's Nitro?
RCnGuy's Avatar
United States, IL, Schaumburg
Joined Dec 2007
Tim (and the beta team)
THIS IS AWESOME!!! I need a higher powered charger for my 6s 5000+mAh packs and this is just the ticket. I'm going to be building a portable/field charging station with a 1000W generator and 15V, 70A switching power supply.
I've been using your 10s charger and have been researching, looking for something more powerful.
Is there an expected release date?
Dave
RCnGuy is offline Find More Posts by RCnGuy
Old Jan 15, 2010, 11:34 PM
Jack Doherty is offline
Find More Posts by Jack Doherty
CPII HD & PL8 beta tester
Jack Doherty's Avatar
Aubrey, Texas
Joined May 2009
Dave
Dave,
To get the full power (1008 watts) of the PowlerLab you will need two 12 volt Pb batteries or a 24 volt 50 amp power supply. A 12 volt Pb battery or a 12 volt 50 amp power supply will give you 516 watts. 50 amps is the max current the PowerLab will accept. I am including a screen shot of the power supply page.
Jack Doherty
Jack Doherty is offline Find More Posts by Jack Doherty
Old Jan 15, 2010, 11:45 PM
Bajora is offline
Find More Posts by Bajora
KA6KHM
Bajora's Avatar
Joined Sep 2004
Yeah, now THAT is a serious charger!
Bajora is offline Find More Posts by Bajora
Old Jan 16, 2010, 12:03 AM
RCnGuy is offline
What's Nitro?
RCnGuy's Avatar
Joined Dec 2007
Thanks Jack.
The generator that I'm planning to use is:
<http://honda.northerntool.com/generators/honda-eu1000ian.htm>
and the power supply is:
http://cgi.ebay.com/1000W-13-8V-72A-...3D10%26ps%3D63
I "may" opt for a slightly smaller power supply (since I really don't want to go with a larger generator) but I haven't really found any between 40A and 70A I would also prefer to keep it 16v or less so that I can use my CellPro 10s charger if need be.
Any suggestions?
Originally Posted by Jack Doherty View Post
Dave,
Jack Doherty
Old Jan 16, 2010, 12:36 AM
Big Fil is offline
Find More Posts by Big Fil
Santa Rosa, CA
Joined Jul 2007
Looks promising. Can any of the beta test group put up a pic showing the screen after charging a 6S 5000 at full power?
Big Fil is offline Find More Posts by Big Fil
Old Jan 16, 2010, 01:16 AM
SteveM732's Avatar
Joined Feb 2008
Will a 7S 4600mAh A123 pack do?
Old Jan 16, 2010, 01:23 AM
jfetter is offline
Find More Posts by jfetter
HAL... Open the damn doors!
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
OK, most of us that are serious will certainly buy one, let's drop the formalities now, price please? If you guys participating in the beta program can't speculate, how about contacting someone from FMA to get on and post the MSRP?
Jack
jfetter is offline Find More Posts by jfetter
Old Jan 16, 2010, 02:26 AM
brw0513_2 is offline
Find More Posts by brw0513_2
Joined Dec 2006
Thanks for giving us this opportunity to provide comments.
I hope there will be a serious effort toward "charger memory management".
As an example, my current charger (competitor's product) has a "mAh cut-off" value that is a global setting, not pack specific. It is a giant PITA. I hate it when I find my A123 pack charging has terminated early because I forgot to change the value from my earlier 900mAh NiMH pack. Or worse, if my cut-off has inadvertently been over-specified for the current duty.
I want to be able to assign a specific pack and charging method (e.g. pack chemistry, cell count, charging mode, current, mAh cut-off, time cut-off etc) to a specific memory "slot" and have the charger remember everything about that particular pack and my previously decided charging strategy . The applicable memory "slot" name should also be user "name-able".
Perhaps the PC software could also have a library function, so pack details can be uploaded and downloaded by the user into the charger's memory. It would be a shame if you had more unique battery packs than memory positions in the charger.
Please don't make the PC a compulsory part of every charge cycle.
Lastly, please give some serious thought to adaptor boards. I hate the usual juggle that really requires three hands to insert the balance adaptor to the board. Why not fly leads instaed?
Thanks.
brw0513_2 is offline Find More Posts by brw0513_2
Old Jan 16, 2010, 03:22 AM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
Based on the charger specifications, with a 15V/70A supply you should get about 640W output power which equates to about 27A into a 6S lipo. That is over 5C for a 5000mAh pack which is pretty good
I am also curious to know whether FMA will be offering a 24V/50+A SMPS ? With the rush of 600W and higher chargers coming out this year there is clearly a market for an affordable high power SMPS. There is a good IOTA DLS-27-40 (27V/40A, 1000W) unit but it is $400.
kgfly is offline Find More Posts by kgfly
Old Jan 16, 2010, 03:30 AM
Himalaya is offline
Find More Posts by Himalaya
Himalaya's Avatar
Joined May 2009
OMG That is a MONSTER charger, Finaly a KW charger available! gotta order one.
Himalaya is offline Find More Posts by Himalaya
Old Jan 16, 2010, 05:07 AM
ggcrandall1 is online now
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Thanks.
Yes you can set up presets for individual packs. This is easily done via the computer interface. Once done you can transfer the preset to the charger and then the charger will be able to access that preset without the computer.
Also when a preset is selected on the charger you can specify whether to Charge, Discharge, Cycle, or Monitor the pack. Also you can override the Charge Amps and Discharge Amps.
New adapter boards are being developed but we haven't seen them yet.
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Discussion Sneak Peek! 2, 1:8 scale scratchbuilts ooby Scale Boats 34 May 22, 2015 10:41 PM
Discussion Proposed schemes for 2010 season RAF BAe Hawk display-sneak peek! Matt Halton Electric Ducted Fan Jet Talk 3 Dec 20, 2009 03:11 AM
Discussion Sneak Peek at the New Creation Museum Miami Mike Life, The Universe, and Politics 38 May 30, 2007 05:01 PM
Hey Mr. Lin, how about a sneak peek at the Hellcat? splatman GWS (Grand Wing Servo) 1 Jul 05, 2003 04:43 AM
