Old Mar 10, 2011, 06:15 AM
bob_nj is offline
Find More Posts by bob_nj
bob_nj's Avatar
Vineland, N.J.
Joined Sep 2003
Internal
What I was referring to is the "balancer" in this link ->
http://www.fromeco.org/products/05frc2sbal/
The statement below is referincing a 2S2P IronCore pack.
When I inquired about how it works, this is what Kurt from Fromeco told me;
The Balancer has a micro controller on it. Basically it looks at set 1 "doesn't mater what side, and lets say that set 1 actually has the Positive "+" to the positive side of the cell, so it sees a voltage of 3.02... Now the micro controller switches sides, now it is looking at set 2 and Positive on 2 is actually hooked to negative side of the cells, so it reads -3.12. At that point the balancer will come on and drain set 2 down to about -3.07.. Once it has done this it will shut off and go to sleep, 5 seconds later it will wake up and start all over again.
bob_nj is offline Find More Posts by bob_nj
Old Mar 10, 2011, 08:24 AM
Pen is offline
Pen
Find More Posts by Pen
Pen
FPWhat?
Pen's Avatar
United States, AL, Huntsville
Joined Sep 2008
Originally Posted by bob_nj View Post
Noticed you've been a member since 2007, and you have 4 posts.
Is this your post for the year (-:
He'll answer you next year.
Pen is offline Find More Posts by Pen
Old Mar 10, 2011, 08:31 AM
bob_nj is offline
bob_nj's Avatar
Vineland, N.J.
Joined Sep 2003
I Don't Think There's Anybody Back There!
Old Mar 10, 2011, 02:50 PM
Fred Marks is offline
Find More Posts by Fred Marks
Ijamsville, MD, U.S.A.
Joined Mar 2001
Post deleted for further edit.
Fred Marks is offline Find More Posts by Fred Marks
Old Mar 10, 2011, 11:20 PM
dards is offline
Find More Posts by dards
Joined Dec 2007
If you are satisfied with the internal balancer on the pack, charge it using an "unbalanced" preset.
I had a Fromeco pack with an internal balancer.
I disabled the internal balancer, added a tap using the wires from the internal balancer that were already there, and then balanced the pack as usual.
Hope that helps
Bob
Haha Good one!
But comment like that from someone who has made 300 odd posts over 8 years time period. Its quite funny!
dards is offline Find More Posts by dards
Old Mar 11, 2011, 07:09 AM
bob_nj is offline
bob_nj's Avatar
Vineland, N.J.
Joined Sep 2003
Sorry, and no disrespect intended.
I thought the smiley (-: would indicate that it was purely in jest.
Old Mar 12, 2011, 02:34 AM
KiloOne is offline
Find More Posts by KiloOne
Dale Kramer
KiloOne's Avatar
United States, NY, Hammondsport
Joined Jul 2004
Why 10A limit for internal discharge?
If there is a 100 watt limit on internal discharge why is there also a 10A limit?
I am cycling a 5000 mah single cell to determine its capacity change over a large number of cycles and I can only do a 2c discharge at 37 watts because of the 10A limit.
If I could do a 100 watt discharge I could at least do 5c.
Dale
KiloOne is offline Find More Posts by KiloOne
Old Mar 12, 2011, 09:19 AM
Jack Doherty is offline
Find More Posts by Jack Doherty
CPII HD & PL8 beta tester
Jack Doherty's Avatar
Aubrey, Texas
Joined May 2009
Dale
Dale,
Just a suggestion. Connect you PL8 to your car battery and charge the 5000 mAh batteries at their max C rating and discharge at 20 or 30 or even 40 amps. That will really speed things up the process and also give a more realistic battery condition/capacity. I do that all the time, charge at 40A and discharge at 40A, however, I am doing this with 10C chargeable NanoTech batteries.
Jack
Jack Doherty is offline Find More Posts by Jack Doherty
Old Mar 12, 2011, 09:27 AM
KiloOne is offline
Dale Kramer
KiloOne's Avatar
Joined Jul 2004
Since I am doing hundreds of cycles I would need to float charge car battery and I am not sure how the float charger would interact with the PL8, probably be OK, anybody tried float charging and regenerative discharging at the same time?
Dale
Old Mar 12, 2011, 10:56 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
If you trickle charge the Pb and its' voltage gets to high it will reduce the Regen. ability.
A single 5000 mAh cell should not use more than approx. 1.7Ah for a charge and with most of it being returned to tyhe Pb you should be able to do a number of cycles before the Pb needs any addational charge.
Charles
Old Mar 12, 2011, 11:14 AM
KiloOne is offline
Dale Kramer
KiloOne's Avatar
Joined Jul 2004
Charles,
While your suggestion would work, it is not very practical in my case where I want to just have the cycling run 24 hrs a day without bother.
I guess my question really is why is there a 10A limit if there is already a 100watt limit?
5c would be just fine if I could do it internally.
Dale
Old Mar 12, 2011, 06:52 PM
Tim Marks is offline
Find More Posts by Tim Marks
President, FMA, Inc.
Tim Marks's Avatar
Joined Mar 2008
Charles,
Dale
Hi:
The answer to your question is, in addition to a wattage limit, there is a current limitation on the transistor used for internal discharge as well.
Tim Marks
Tim Marks is offline Find More Posts by Tim Marks
Old Mar 12, 2011, 09:47 PM
KiloOne is offline
Dale Kramer
KiloOne's Avatar
Joined Jul 2004
Thanks Tim,
I somehow envisioned the same device would be used for internal as external just a different load.
Dale
Old Mar 13, 2011, 07:46 AM
Tim Marks's Avatar
Joined Mar 2008
Thanks Tim,
Dale
Hi:
No. For internal discharge, a transistor switch effectively is the load. For external, the current path is same as for charging (through the power section); but reversing direction of current flow due to syncronous operation. During external discharge, the load is the input battery; hence, very little heat is generated.
Tim
Old Mar 15, 2011, 01:42 AM
RCnGuy is offline
Find More Posts by RCnGuy
What's Nitro?
RCnGuy's Avatar
United States, IL, Schaumburg
Joined Dec 2007
Ok 14 months after the announcement and 9 months after owning one I have a question... Well, maybe a 2nd or 3rd
Is there a Lipo balance only mode on the PL8? I have a 3s 2200 pack that had 1 cell about .2V out of balance. I had to put it on my Hyperion DUO 3 in balance mode as I could not find a balance mode on my PL8. This was after completing a "storage mode" charge on the PL8.
Is this feature actually missing?
If it is, I want to suggest adding it in a future firmware update.
Dave
RCnGuy is offline Find More Posts by RCnGuy
Discussion Sneak Peek! 2, 1:8 scale scratchbuilts ooby Scale Boats 34 May 22, 2015 10:41 PM
Discussion Proposed schemes for 2010 season RAF BAe Hawk display-sneak peek! Matt Halton Electric Ducted Fan Jet Talk 3 Dec 20, 2009 03:11 AM
Discussion Sneak Peek at the New Creation Museum Miami Mike Life, The Universe, and Politics 38 May 30, 2007 05:01 PM
Hey Mr. Lin, how about a sneak peek at the Hellcat? splatman GWS (Grand Wing Servo) 1 Jul 05, 2003 04:43 AM
