Old Sep 12, 2010, 07:09 AM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
Yes, I tried that first. The Mastech will acually reach 31.5 volts..., but no luck. I think I actually squeeked out a few more amps into the charger with the voltage at 24.
??? Do you mean more amps out of the charger? For any given power out of the charger you will get more amps into the charger at lower voltage. If the charger error appears at 22A input that's 528W input at 24V but 660W at 30V so you should get 25% more output power at 30V input at the same limiting input current.
kgfly is offline Find More Posts by kgfly
Old Sep 12, 2010, 07:17 AM
SpeedVision is offline
Find More Posts by SpeedVision
United States, MI, Grand Rapids
Joined Sep 2007
Haha, I'm doing a good job of creating confusion.
I meant to say that I could set the charge rate a few amps higher without generating the error if I lowered the PS voltage. In either event, the amps knob was set wide open.
Regardless of the nuances or settings, I should be able to crank up the Mastech and let the PL8 rip without breaking a sweat.
SpeedVision is offline Find More Posts by SpeedVision
Old Sep 12, 2010, 08:00 AM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
According to the PL8 power supply spreadsheet from FMA, I was under the impression that the PL8 does not benefit from any voltage > 24v.
Ohmic is offline Find More Posts by Ohmic
Old Sep 12, 2010, 10:07 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
I have had a theory for a while now that some of these Supply Unstable errors are due to the simple(?) fact that the PL8 ramps up the charge rate extremely fast.
Way back here
http://www.rcgroups.com/forums/showp...postcount=1140
a user noted the difference even between using the CCS and the PL8's controls to start a charge..
His error was
'charge lead over current error'
but perhaps these errors are related.
Some of my testing has shown that if I use a single 12V /30A server power supply and set a 6S charge rate high enough to cause the charge rate to be limited due to supply limits that the PL8 fans surge off and on at the start of the charge which would seem to indicate that the power supply is in fact dropping below 10.5 volts even though the PL8's or CCS display does not indicate such.
If one uses the PL8 controls and starts the charge rate at a lower rate then bumps the rate up in steps the power supply will not see such a heavy load all at once.
Charles
Old Sep 12, 2010, 10:39 AM
Jeff_edge540 is offline
Find More Posts by Jeff_edge540
Mis-guided heli guy
Jeff_edge540's Avatar
Austin, TX USA
Joined Mar 2007
I found that the PL8 was overshooting my 30 amp set charging rate at the beginning causing this error. However, the latest firmware update seems to have fixed the current overshoot.
http://www.rcgroups.com/forums/showp...postcount=1519
***VERSION 2.04 8-23-10*** Reduced Amps overshoot to prevent false trips.
Jeff_edge540 is offline Find More Posts by Jeff_edge540
Old Sep 12, 2010, 11:12 AM
Southern Pride
Ramp ups
Eagle Tree is not as fast as a scope but is best I have on hand.
Both chargers were being powered by 12V /30A IMB 235 server power supplies is series for 24V @30A.
Charles
Old Sep 12, 2010, 12:14 PM
Joined Sep 2007
Charles
Interesting! This confirms the very erratic amp readings I was seeing on the Mastech display...it was wild enough to catch my attention immediately. Volts on the display were constant at 24.
Old Sep 12, 2010, 01:18 PM
Southern Pride
Just for comaprison,
CP 10 took approx. 1 min to ramp up to 10-11 amps.
This is an old one I ran long ago but shows what ramp up times use to be in years past. I well remember my TP1010C taking well over a minutre to reach 10A charge rate.
Perhaps chargers are getting in to big of a hurry to get the job done.
Charles
Old Sep 12, 2010, 02:10 PM
klhoard is offline
Find More Posts by klhoard
Collierville, TN
Joined Aug 2003
Does connecting a large 12V Pb battery in parallel with the power supply smooth out the spikes? I know its not a permanent solution . . .
klhoard is offline Find More Posts by klhoard
Old Sep 12, 2010, 02:29 PM
Southern Pride
If by spikes you mean short term voltage drops then simple answer is yes.
Please note that my graphs above are the chargers output not the power supplies.
Post here where a 12V PB was used in parallel with ps.
http://www.rcgroups.com/forums/showp...postcount=1575
Note that the power supply was in fact also a Pb charger and thus had over 12V out put.
Charles
Old Sep 12, 2010, 04:00 PM
Joined Sep 2007
Mastech 3050EX Charge attempts
Here 4 attempts to charge a 6s A123 pack.
I used my EagleTree and it was connected between the Mastech 3050EX power supply and the PL8.
So, in this case "pack amps" and "pack volts" actually represent the current and voltage coming from the Mastech...
First three charges ended a few seconds after the ramp up ending in "Power Supply Unstable" error and the charge was automatically terminated.
First attempt - 25 amps charge rate - fail
Second attempt - 22 amps charge rate - fail
Thrid attempt - 20 amps charge rate - fail
Fourth attempt - 18 amps charge rate - success if you can call it that...
Hope this helps...
Old Sep 12, 2010, 05:38 PM
kgfly is offline
Joined May 2006
Charles
Well that does seem ridiculously fast current ramp up to me. In this application, adding a few seconds to the overall process time is neither here nor there. Pacing the current ramp-up so it goes from zero to set-point at say 1A/s would make the PL8 a much kinder and more tolerant load and possibly avoid these problems. It is also interesting to see how "noisy" the load is compared to the other 30A charger. Could you please post the PL8 current ramp plot at an expanded time scale so we can see the details between 110 and 140s? What was the ET sample rate (IIRC 5 sample/s is the max rate)?
Old Sep 12, 2010, 05:53 PM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
I suppose that depends on how you define "benefit". I believe the PL8 requires at least 24v to deliver 1000 watts. Increasing input voltage may not increase output power, but it will reduce input amps which I would say is beneficial. Any time you can trade volts for amps (higher volts, lower amps) its easier on the components and often times more efficient.
Gregor99 is offline Find More Posts by Gregor99
Old Sep 12, 2010, 06:03 PM
Joined Sep 2007
Between 110 and 140? That's where the charger was "thinking".
Here you go! Sample rate is 4x per second. This is the first attempt at 25 amps charge rate.
Keep in mind that the charger thinks for about 45 seconds before it demands any current. When it does, this is the kind of ramp up you get. I don't know enough to say if this is reasonable or not. I don't think it would be an advantage to FMA if such a narrow range of PS's would work with thier charger...
Old Sep 12, 2010, 06:08 PM
Gregor99 is offline
Seattle
Joined Sep 2007
Very interesting indeed. Although I don't think that is noise. It looks more like current fluctuations which may be intentional. It would be good to hear from FMA as to whether or not these current fluctuations are by design. It would also be interesting to see of the current fluctuations only happen at high charge rates. Watching the CCS charge current, I've never seen this. But I've never charged higher than 12 amps.
Discussion Sneak Peek! 2, 1:8 scale scratchbuilts ooby Scale Boats 34 May 22, 2015 10:41 PM
Discussion Proposed schemes for 2010 season RAF BAe Hawk display-sneak peek! Matt Halton Electric Ducted Fan Jet Talk 3 Dec 20, 2009 03:11 AM
Discussion Sneak Peek at the New Creation Museum Miami Mike Life, The Universe, and Politics 38 May 30, 2007 05:01 PM
Hey Mr. Lin, how about a sneak peek at the Hellcat? splatman GWS (Grand Wing Servo) 1 Jul 05, 2003 04:43 AM
