Model: 274R8-87 Catalog #: 274-012 $2.99 http://www.radioshack.com/product/in...ductId=3014502 Just realized they are only rated @ 10 Amp |
Joined Jul 2010
Matt |
Joined Jul 2010
The specs say accepts 18ga wire so i don't know if larger would fit but they are rated for 36A. According to this pdf, max wire size 12awg. Matt |
Nebraska
Joined Jul 2003
Stackable Banana Plugs
These are stackable plugs rated at 36A for 12 to 18 AWG wire. However, 12 AWG silicone and even 13AWG silicone wire (e.g., Dean's Ultra wire) will not fit in this connector. Not only is the silicone insulation too large to fit in the hole, the wire itself also won't fit. That has been a common problem I've found in sampling numerous stackable banana plugs from different sources. Instead of stackable banana jacks, I just made up a few 12 AWG "Y" cables and used a standard 4mm bullet on the ends which plug into the charger. I also placed a 35 amp fuse in each positive wire. I use the "Y" connectors to charge two 5S 5300 pattern packs in parallel at 23 amps and neither the wire nor connectors get warm. Mike |
USA
Joined Jan 2002
I've been using these retractable sleeve 13awg banana connections for several years now. The ones with 13awg wire are rated for 36A. If you buy one red/black set and then cut them in half you have two sets for your charger which is what I did.
http://www.testpath.com/Categories/B...eeves-1810.htm |
USA
Joined Jan 2002
Does the charger monitor the individual cell voltages indefinitely or does it stop after a period of time? I'm wondering if it might be appropriate to replace the "Done" message with something that more accurately reflects that the charger is still monitoring the pack and that enter needs to be pressed to end the charge process and save the charge/discharge data. |
Page 31 & 32 of the manual 10. When the operation is complete, PowerLab 8 will “beep beep beep” several times and the display will show ELAPSED [time] / [chemistry] DONE. Press INC and DEC to review data screens. 11. Press and hold ENTER. Screen displays CHARGER STOPPED. 12. Press ENTER or BACK to return to the User Preset list. 13. Disconnect the pack from PowerLab 8. PowerLab 8 is ready to charge another battery (step 3). |
Port Washington, WI
Joined Sep 2008
Man I can't believe I missed that, I have scoured that manual. And it was in a bright yellow box to boot!! Feeling stoopid now - thanks for the help. Thanks, Mike |
| Thread Tools | |
| Discussion Sneak Peek! 2, 1:8 scale scratchbuilts | ooby | Scale Boats | 31 | Jul 24, 2011 08:30 AM |
| Discussion Proposed schemes for 2010 season RAF BAe Hawk display-sneak peek! | Matt Halton | Electric Ducted Fan Jet Talk | 3 | Dec 20, 2009 03:11 AM |
| Discussion Sneak Peek at the New Creation Museum | Miami Mike | Life, The Universe, and Politics | 38 | May 30, 2007 05:01 PM |
| Hey Mr. Lin, how about a sneak peek at the Hellcat? | splatman | GWS (Grand Wing Servo) | 1 | Jul 05, 2003 04:43 AM |
