Old Jan 15, 2010, 02:03 PM
JJ OROŅO's Avatar
Joined Feb 2009
2.4GHz FHSS Futaba 4YF
This is the 2.4GHz FHSS Futaba 4YF 4-Channel Radio System
with the R2004GF Receiver.
Transmitter and Receiver only, Servos not included
FEATURES: FHSS (Frequency Hopping Spread Spectrum) eliminates frequency pins and signal interference-pushbutton transmitter/receiver linking with no binding plugs R2004GF receiver has coaxial antenna that can be positioned inside model for optimum reception Power Down Mode - reduces RF power for 90 seconds, simplifying ground checks for interference All-channel servo reversing for more installation options Power and servo reversing switches are located down and out of the way for convenience and to avoid accidental changes Battery meter features one Green and one Red LED for easy-to-read GO/NO GO status Elevon mixing Spring loaded trainer toggle switch for instant "OFF" Gimbals have knurled tops for a better "feel" on the sticks and to prevent finger slippage One year limited warranty through manufacturer beginning at date of purchase
INCLUDES: 2.4GHz FHSS Futaba 4YF 4-Channel Transmitter R2004GF Receiver, FUTL7617 On/Off Switch Harness and Charge Cord Neck Strap Instruction Manual
REQUIRES: AA Batteries: Four for transmitter NOTE: A RX NiCd or battery box is NOT included because radio system is designed for Park Flyers and thus power will be provided to the RX via the BEC Electronic Speed Control (ESC)
SPECS: Transmitter; Transmitting Frequency: 2.4GHz band Power Requirement: Four AA cells Current Drain: 90mA Trainer Port: Micro Receiver; Power Requirement: 4.8 - 6V shared with servo Current Drain: 30mA at no signal Size: 1.54 x 1.02 x 0.39" (39 x 26 x 10mm) Weight: 0.49oz (14g)
http://www.futaba-rc.com/radios/futk4200.html
This new Futaba have no info about the range, and use FHSS technology (as Corona).
what do you think?
JJ OROŅO is offline Find More Posts by JJ OROŅO
Old Jan 15, 2010, 02:49 PM
DougV's Avatar
United States, FL, Miramar
Joined Dec 2007
That's just an inexpensive park flyer system.
Not compatible with FASST.
Doug.
DougV is offline Find More Posts by DougV
Old Jan 15, 2010, 03:54 PM
Joined Aug 2008
look at that stubby antenna!
Doug.
lucasavaitor is offline Find More Posts by lucasavaitor
Old Jan 15, 2010, 08:51 PM
Melbourne, Australia
Joined May 2006
Are you kidding ? If it really is not FASST compatible then it is an utterly daft concept. It strands users so that when they want to upgrade Tx they need all new Rx, which means there is no brand lock-in. Why would any mfr do such a thing ?
kgfly is offline Find More Posts by kgfly
Old Jan 16, 2010, 09:25 AM
JJ OROŅO's Avatar
Joined Feb 2009
Doug.
hi DougV. I think is a expensive Park Flyers sistem, the Spektrum have full range, and a aditional chanel with the same price!
this radio is like Hobby King 2.4, but four times more price.
Is not compatible with FASST, because use FHSS techonology, same made by Corona, so i think its a Corona Park Flyer sistem in a Futaba Case for $ 99.
Regarts
Old Jan 28, 2010, 07:13 AM
Joined Mar 2007
The manual says to never use a "dry battery" on the Rx. What do they mean by that?
Cheers,
Earl
Earl Boebert is offline Find More Posts by Earl Boebert
Old Jan 28, 2010, 12:57 PM
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
Hi Earl,
That's an old term for non rechargeable primary batteries, such as Doooracells and Engeezers
I fly Futaba, but sometimes I wonder about their lack of marketing savvy
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Jan 28, 2010, 04:08 PM
Joined Mar 2007
Thanks. Why would they give such a warning? The radio is for a small sailboat, crashing is not an issue, 100 meters range is plenty.
Cheers,
Earl
Sold Airtronics Receiver - RDS/SD 8-ch 2.4GHz FHSS-1 bigslopegrin Aircraft - General - Radio Equipment (FS/W) 1 Jan 10, 2010 02:47 PM
Sold Airtronics 2.4ghz MX3 FHSS TX + 92324 FHSS RCVR markw365 Cars - Accessories (FS/W) 1 Sep 26, 2009 01:03 AM
Question Airtronics RX60 6ch 2.4GHz FHSS-1 Park Flyer Receiver old_dude Radios 1 Sep 11, 2009 09:28 AM
Sold ** 2 Airtronics 2.4ghz FHSS Receivers ** Robert Parisot Aircraft - General - Radio Equipment (FS/W) 2 May 29, 2009 02:10 PM
Sold Airtronics M11 FHSS-2 2.4ghz with Case MikeATL Cars - Cars and Parts (FS/W) 2 Apr 17, 2009 01:05 PM
