View Poll Results: How has your MSR 5in1 held up
Received a bad 5in1 1 2.44%
I physically broke my 5in1 in a crash 4 9.76%
5in1 burned up or just (stopped working) 4 9.76%
Over 30 flights and no problems at all" with my 5IN1 32 78.05%
Bought a new board just in case (for a back up) 0 0%
Voters: 41. You may not vote on this poll
Old Jan 15, 2010, 05:46 AM
Hellysmack is offline
Find More Posts by Hellysmack
What package dear?
Hellysmack's Avatar
USA ILLINOIS
Joined Nov 2002
Poll
I closed the other threat and believe this poll would give clear results. I realized it would be better to start fresh because I could not fix other.
Hellysmack is offline Find More Posts by Hellysmack
Old Jan 15, 2010, 04:11 PM
skeppley is offline
Find More Posts by skeppley
2 Turbos...Nope 1 Big one
skeppley's Avatar
United States, PA, Lake Wynonah
Joined Aug 2004
voted and bumped
skeppley is offline Find More Posts by skeppley
Old Jan 15, 2010, 04:21 PM
haproot is offline
Find More Posts by haproot
Joined Dec 2009
Flown the hell out of it.. probably at the very least 100+ flights and no issues really. Replaced one servo collar that's it.
haproot is offline Find More Posts by haproot
Old Jan 15, 2010, 06:15 PM
keocak is offline
Find More Posts by keocak
United States, FL, Palmetto
Joined Sep 2009
Mine has even taken a trip into the kitchen sink! While my wife was doing dishes! pulled it out of the water, unplugged the battery and let it all dry out overnight. put battery back in and it has anouther 50 plus flights on it! I thought it was a gonner.
keocak is offline Find More Posts by keocak
Old Jan 15, 2010, 09:25 PM
Matt.R is offline
Find More Posts by Matt.R
Joined Jan 2010
I have no idea how many flights I've done on my MSR but heres how many parts I've simply worn out(not broken):
3x Flybars (ovaled out --now I just fill/drill them out with epoxy)
2x Blade Grips (Eventually horizontal slop develops between the spindle and grips)
1x Servo (motor simply spazzed)
The axle probably needs to be replaced some time soon as well.
No problems with the 5 in 1 whatsoever.
I'd guess that I'm around 175-200 flights.
Edit:
I averaged it out and I think I'm somewhere between 168-180 flights
Matt.R is offline Find More Posts by Matt.R
Old Jan 17, 2010, 09:08 AM
rhuber40 is offline
Find More Posts by rhuber40
rhuber40's Avatar
Mason, Ohio
Joined Jul 2007
msr
Around 200 flights, have not broken anything. Flew it into the dogs water, came out dried it with my monokote heat gun (Carefully, Take the canopy off before you try this and hold the heat gun no closer that 2 feet from the board)
Smelling like a rose; no problems since.
rhuber40 is offline Find More Posts by rhuber40
Old Jan 17, 2010, 12:06 PM
hydro_pyro is offline
Find More Posts by hydro_pyro
Blade mSR freak
hydro_pyro's Avatar
Irish Hills - SE Michigan
Joined Jan 2010
Mine died after one week of flying. First, the antenna wire fell off (why to they wrap it around a thin plastic part that can wiggle and vibrate??) An unlucky crash a few days later killed the 5-in-1, probably from part of the LHS r/c track striking a component on the board during an unlucky crash.
The stock canopy does not fit. It rubs up against the board, and provides minimal protection against common household objects jabbing under the edge of the canopy and damaging the fragile SMD components and/or the servo gears.
Here's my fix for the board fit problem: http://www.rcgroups.com/forums/showp...&postcount=309
hydro_pyro is offline Find More Posts by hydro_pyro
Old Jan 17, 2010, 02:26 PM
Matt.R is offline
Joined Jan 2010
I copied you as soon as I saw that post the other day. ;D
Thanks!
Poll MSR 5in1 Mother board? Hellysmack Micro Helis 10 Jan 14, 2010 01:07 PM
Wanted dead blade msr 5in1 (or motor connectors) sideburn Aircraft - Electric - Helis (FS/W) 2 Nov 06, 2009 04:38 PM
Discussion How do you know it’s time to replace the blade grips on your MSR? mikeflys Micro Helis 6 Sep 20, 2009 09:32 PM
Discussion How do you have your mic hooked up? jsullivan05 FPV Talk 8 Sep 03, 2009 01:17 AM
