Old Feb 18, 2013, 11:27 PM
the_canuck is offline
Find More Posts by the_canuck
Where's the wind?
the_canuck's Avatar
United States, CO, Denver
Joined Jun 2004
Here's a link to my machine build:
http://www.cnczone.com/forums/cnc_wo...l_monster.html
Go Big!
Andrew
www.canuckengineering.com
the_canuck is offline Find More Posts by the_canuck
Old Feb 19, 2013, 08:34 AM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
Esc32
Hi People
I just wanted to make you aware of the ESC32. It is built for multirotor helis, but I think it could be interesting for use as a spindle controller.
It sports a closed loop mode and can be controlled over a serial interface.
In closed loop mode, you can control the RPM with extremely high accuracy. Upper limit is 20V/50A, but requires proper attention to cooling.
More info here:
http://autoquad.org/esc32/
http://www.viacopter.eu/shop/esc%C2%...ad-esc32/17-93
Id be willing to send a sample to someone on this thread that wants to play around with it, and see and document if it can be used for spindle control.
Michael, er du interesseret?
JussiH is offline Find More Posts by JussiH
Old Mar 11, 2013, 07:56 AM
blackmoon is offline
Find More Posts by blackmoon
flying beam
blackmoon's Avatar
through the Looking Glass
Joined Apr 2008
blackmoon is offline Find More Posts by blackmoon
Old Jun 20, 2013, 05:11 PM
legout is offline
Find More Posts by legout
Joined Jun 2012
Hi Michael,
this thread has inspired me building my own cnc router . Some time ago I asked for an alternative to your base build with cement and you gave me the tip to build a torsion box.
I came up to construct my own cnc, as I want a larger working area and a torsion box. Find below some pics of what Im planing to build.
Unfortunately, I have to find someone to cut all parts on his cnc machine .
Comments are welcome.
legout
legout is offline Find More Posts by legout
Old Jun 21, 2013, 07:11 AM
michaelghammer is offline
Find More Posts by michaelghammer
michaelghammer's Avatar
Denmark
Joined Dec 2004
Hi Legout
Im glad this thread inspired you to move ahead and design your own version.
Your design looks well engineered and should perform well.
If you cant find a place to get your parts cut, you could make a quick and dirty version from cheap wood and then let it cut your parts with this. Youll be surprise how easy it is to cut nice parts with a b... ugly machine thrown together in a couple of hours using nails, screws, glue and zip-ties.
I plan to make a new machine with slotted parts just like you. All handcut parts will be replaced with new and redesigned CNC cut parts. Bought some very inexpensive drag chains for the new machine on Ebay that work great. You should incorporate some of them in your design: drag chains
Good luck with the build and feel free to post updates in this thread.
- Michael Hammer
michaelghammer is offline Find More Posts by michaelghammer
Old Jun 22, 2013, 12:19 PM
legout is offline
Joined Jun 2012
Hi MIchael,
thanks for your comment.
Are there already any pictures available of the machine you are planing?
Hopefully I do not have to build a quick and dirty machine. But up to now, I havent found andybody to cut my parts.
I will post here if there are any news.
legout
Old Jun 24, 2013, 05:23 AM
Denmark
Joined Dec 2004
Hi Legout
Nothing to show yet. Im still working on finishing my new house and hobby related stuff is still a long time away.
- Michael Hammer
Old Jul 03, 2016, 12:01 AM
coleman jr is offline
Find More Posts by coleman jr
Joined Jun 2016
HELP !! what modify on proxxon MF70 ?
hello, can someone help me for convert my new MF70 ?
I want , as first step, modify the spindle to ER11 with diameter arbor 12, and then also replace original motor with a brushless motor. I not know brushless motor and what model type could work fine with a spindle ER11.
I need also of replace a bearing of spindle ?
coleman jr is offline Find More Posts by coleman jr
Old Jul 03, 2016, 12:11 AM
Joined Jun 2016
Originally Posted by mlmcquiggjr View Post
Hello could be possible mount a spindle C12 (diameter 12mm) ? or whitch better ?
Build Log CNC router table build hawaiianspork226 CAD/CAM 94 Jun 01, 2010 11:49 AM
Discussion CNC router 1st steps?????? imsofaman CAD/CAM 15 Jan 17, 2010 07:59 PM
Discussion Looking for CNC router services Fossil1977 The Builders Workshop 0 Nov 14, 2009 08:00 PM
Discussion DIY CNC Router Kits D.S. Dynamic Soaring 4 Oct 12, 2009 12:02 AM
Discussion CNC Router for the DIY'r GLIDERGIDER The Builders Workshop 2 Dec 01, 2008 02:49 PM
