Old Jan 14, 2010, 09:32 PM
fung is offline
Find More Posts by fung
Flying-Hobby
Joined Dec 2003
HeliArtist V2 FAN SYSTEM
......I will get in few days
fung
www.flying-hobby.com
fung is offline Find More Posts by fung
Old Jan 14, 2010, 10:26 PM
SidewaysLS4 is offline
Find More Posts by SidewaysLS4
Redjestird Youser
SidewaysLS4's Avatar
Joined Jan 2009
Cool! Who's got a V1 and what is different?
I'm wondering...do the blades still angle out from the offset root hole after spooling up?
SidewaysLS4 is offline Find More Posts by SidewaysLS4
Old Jan 14, 2010, 10:42 PM
fung is offline
Flying-Hobby
Joined Dec 2003
after i got i will post a new test and i know it more light and twins crank
fung
Old Jan 14, 2010, 11:35 PM
Super_Hornet is offline
Find More Posts by Super_Hornet
Singapore
Joined Jan 2004
The most important thing is...do this newer version has a build in speed up gearing in order to make the fenestron tail spin faster than usual x4.2?
Super_Hornet is offline Find More Posts by Super_Hornet
Old Jan 15, 2010, 12:11 AM
msppc is offline
Find More Posts by msppc
www.heliflying.com
HK
Joined Mar 2003
Absolutely right!!!
msppc is offline Find More Posts by msppc
Old Jan 15, 2010, 06:00 AM
Redjestird Youser
Joined Jan 2009
Yeah, I'd like to see someone test this with the higher tail ratios that can be built into a T450.
Old Jan 15, 2010, 01:55 PM
Gautier is offline
Find More Posts by Gautier
Joined Mar 2007
Hi Mr fung
An idea if it will be avaible for trex 500...
Best regards
Gautier is offline Find More Posts by Gautier
Old Jan 15, 2010, 08:23 PM
Hoverup is offline
Find More Posts by Hoverup
2013 GRAND SPORT CORVETTE
Hoverup's Avatar
Golden Gulf Coast
Joined Jul 2002
fung
Fung - Are you going to send me a V2 replacement for the V1 that I bought for $129.00USD and does not work?
Regards - Boyd
Hoverup is offline Find More Posts by Hoverup
Old Jan 18, 2010, 04:14 AM
fung is offline
Flying-Hobby
Joined Dec 2003
Regards - Boyd
hi boyd
i will send u v2 too.
fung
Old Jan 18, 2010, 08:12 AM
Hoverup is offline
Hoverup's Avatar
Golden Gulf Coast
Joined Jul 2002
hi boyd
fung
Thanks Fung. Hope this works better.
Old Jan 18, 2010, 09:38 AM
BlackTitanium is offline
Find More Posts by BlackTitanium
3D and Scale RC Heli Pilot
BlackTitanium's Avatar
Monroe, WA
Joined Jan 2007
Regards - Boyd
@ Boyd - Did the fan not work at all, or did it just not work with a 4 blade head?
@ Fung - If you're going to display advertisement photos of the fan tail on a EC-135 with a 4 blade head, then you are promoting that the fan tail will work with a 4 blade head.
You must fully test the fan tail with a 4 blade head, to make absolute sure that it will work, and then recommend the required motor, ESC, and pinion that works best.
If it will not work with ha 4 blade head, then you should not display it with a 4 blade head. And, you must put a disclaimer in your advertisement that it is not suitable for a multi blade head.
BlackTitanium is offline Find More Posts by BlackTitanium
Old Jan 18, 2010, 10:33 AM
Hoverup is offline
Hoverup's Avatar
Golden Gulf Coast
Joined Jul 2002
Only tested with a four blade head on the premise that anyone paying $129.00USD for a fenestron/tailfan is not likely to opt for a two blade head. To the best of my knowledge, no full size heli with a fenestron has a two blade head and for sure has no flybar. This was my thinking at the time.
Sorta supports my reply above. Agree with you 100% BT. I will report results as soon as I have the V2 from Fung.
Cheers - Boyd
Old Jan 21, 2010, 12:26 PM
PHIL.H is offline
Find More Posts by PHIL.H
Yorshire. UK
Joined Jul 2006
fenestro tail.
There's a bloke on a German heli forum(rc-heli.de) has designed his own fenestron, his forum name is heliroland. The hub is slightly like the heliartist one but looks a little smaller. It has no shroud so is fixed directly to the boom and tail blades are slim, more scale like and it actully fits inside the tail ring of the fuselage and not on the edge like the heliartist one!!! It fits the align ec 135 or similar fuselages that have 90mm tail ring opening. the heliartist v1 tail fan did not fit into my align fuselage so the heliartist one must be about 1 or 2mm bigger, that how close it was to not quite fitting. Iv'e adapted mine to a tailcase and have just started to do some test flights . I may do a thread on it later.
Anyway here are some pictures of helirolands fenestron, also he has flying video on youtube with copterx 4 blades head in which he is doing his final testing and then maybe in about 6 weeks or so going to start production of his fenestron.
PHIL.H is offline Find More Posts by PHIL.H
Old Jan 21, 2010, 12:58 PM
PHIL.H is offline
Yorshire. UK
Joined Jul 2006
Fenestron tail
I joined this group just so i could follow the thread. It looks like its the most successful 450 size fenestron to date or at least what iv'e seen so far. He started with a 2 blade head then went on to the copterx 4 blade.If you put heliroland in youtube he will come up and he's got 3 videos of it flying, 2 with 2 blade head and 1 video with 4 blade head. He says he will not put it to production until he has got it perfect! He says when it available it will be sold as to preference for the buyer i.e. for either 2 blade head or 4 blade head so he must have some type of speed up gearing developed for it. Also it can be adapated for diferent models i.e. mini titan has 14mm boom where as trex boom is 12 mm. So its looking promising soo far. The only problem is the forum is in German and the google toolbar translater doesn't translate every word quite the same so some posts are confusing and some words are un-translatable to english.
The forum = rc-heli.de THREAD = it flies EC 135 for T-rex with Fenestron.
regards Phil.
Old Jan 21, 2010, 01:28 PM
PHIL.H is offline
Yorshire. UK
Joined Jul 2006
Fenestron tail
These are the only other ones i can find on his thread, (Helirolands T-rex in align ec 135 with fenestron).
regards Phil
Discussion HeliArtist Tail Fan System for 450/500 size EC-135/EC-120 BlackTitanium Scale Helicopters 172 Jun 20, 2012 09:53 PM
Off Site Kyosho Jet Ducted Fan System brand new gliders Aircraft - Fuel - Jets (FS/W) 0 Jan 09, 2010 09:08 AM
Build Log HeliArtist Mini Hughes 500D w/Gaui 200SE V2 FES BlackTitanium Scale Helicopters 17 Jan 01, 2010 11:14 AM
Sold HeliArtist Hughes500E V2 pnoypilot Aircraft - Electric - Helis (FS/W) 2 May 16, 2009 09:29 PM
Sold HeliArtist Airwolf fuselage V2 - brand new - take advantage of my blunder omster Aircraft - Electric - Helis (FS/W) 3 Apr 19, 2008 06:39 PM
