This thread is privately moderated by Nathan Schmoekel, who may elect to delete unwanted replies.
Old Mar 27, 2012, 10:45 PM
hayataro is offline
Find More Posts by hayataro
DLG addict
hayataro's Avatar
Japan, Tokyo
Joined Jan 2005
Hi guys,
I found a affordable laser height meter. Please refer my blog.
http://moogagaga.tou3.com/Entry/84/
Haya
hayataro is offline Find More Posts by hayataro
Old Apr 20, 2012, 08:21 AM
Piper J3 is offline
Find More Posts by Piper J3
Full Scale Piper Cub Driver
Piper J3's Avatar
Hinckley, Ohio
Joined Nov 2008
I've been flying the new HobbyKing Altitude Logger http://www.hobbyking.com/hobbyking/s...dproduct=22630 and it really works great. Easy to set up and use. Extremely small. I suspect this would be perfect for hand launch.
See my post http://www.rcgroups.com/forums/showp...86&postcount=6
Piper J3 is offline Find More Posts by Piper J3
Old Jun 21, 2012, 01:21 AM
Jwmflying14 is offline
Find More Posts by Jwmflying14
United States, CA, Lompoc
Joined Nov 2010
Hey guys, very interesting thread.
I have a topsky disser on the way and am ordering a predator 2. I would like to do an affordable lightweight altimeter. I don't need the most accurate, more the best logging, however it would be awesome to compare launch heights of the two!
Jwmflying14 is offline Find More Posts by Jwmflying14
Old Jun 21, 2012, 12:34 PM
bbbp is online now
Find More Posts by bbbp
a.k.a. Bob Parks
Glendale, AZ
Joined Jun 2008
I have three different altimeters that fit in my DLG's, plus a GPS and an older ZLOG unit with a built in display that are both too large for DLG's.
The three DLG units I have are the How High, a RAM3 and an OpenAltimeter. I like the RAM 3 software best, but it requires downloading to see the altitude readings.
The How-High is small, lightweight and simple, a blinking LED counts out the altitude on the field but does not have downloading capability for the data.
The OA unit is larger, is capable of downloading data, and can be programmed to give on field readings of the altitudes by beeps, the battery voltage (if using its on board regulator otherwise it sees the regulated input) and has a lost model alarm controlled by a transmitter switch. That feature is really nice. Its software is useful, but currently does not have some of the features I like that the RAM3 software has incorporated.
The data files are usually ASCII files but are completely different in content. I suppose a halfway good programmer could write conversions so the data could be used between software apps.
BP
bbbp is online now Find More Posts by bbbp
Old Aug 24, 2012, 08:08 AM
Machineman is offline
Find More Posts by Machineman
Aussie F3K Team
Melbourne, Australia
Joined Jun 2008
Live telemetry is best
My flying really improved when I got live telemetry and I can read the altitude off the screen.
Using a logger does not give you that instant feedback and hence the correlation between what you changed and the result is lost because of the time delay to get the information.
I went and bought a Graupner MC20 (any good system will do) with 4 altimeters (they fit easily in my Stobel, Salpeter, Fireworks, Steigeisen and Concept X2) and the Smart Box display. The Smart Box (or TX screen) gives live altitude, max altitude, sink rate/s, sink rate/3s and sink rate/10s.
Here's how I use it:
1. Launch height improvement.
I have the Tx screen set on my flap pre-set screen and the SmartBox reading Altitude.
Launch, look at the screen to check altitude, pull brakes, land adjust my flaps or elevator trim and relaunch. This takes about 45s per turnaround.
Move backwards and forwards between settings, style, effort, techniques, 2 stage launch or 1 stage launch and you very quickly learn what works with the instant feedback loop to your brain.
I added between 8 - 10m to the launch height on all my planes in 45 minutes on each plane and I now go to a comp knowing I am getting the best launch I can - a great feeling.
2. Flap settings in light air.
Watch the sink rate/10 seconds and switch between modes during the same flight and you can quickly see what is the best flap/trim setting for the same patch of air.
3. Flap settings in thermals.
Catch a thermal and watch the climb rate/10 seconds screen change as you change flap settings backwards and forwards in the same thermal. Awesome information. You learn that the stronger the lift the more flap you can use.
4. Watch how fast your sink rate is when you are not in lift after you launch, it makes you move fast rather than sitting in crap.
This is just a snap shot. My point is my flying has improved significantly with instant feedback telemetry. Give it a go - you will not be dissapointed.
Cheers,
Marcus
Machineman is offline Find More Posts by Machineman
Old Aug 24, 2012, 08:35 AM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
Marcus,
I've seen improvement with telemetry as well, though I still haven't switched over for my contest radio.
The only one of these that I don't pay much attention to is 3. In a thermal my climb rate is usually directly proportional to my ability to stay centered.
I have used it primarily to tune launch height via alteration of climbout angles, camber settings, preset timing, etc.
I also trim in some really still air to set min sink rates playing with camber and elevator trim (speed) settings. It has improved my dead air times by almost 20 seconds on average, indicating that my stuff wasn't even close to optimally set up before.
Unfortunately now the large gains are gone and I'm back to fiddling for very incremental improvements.
tom43004 is offline Find More Posts by tom43004
Old Aug 24, 2012, 04:10 PM
samc99us is offline
Find More Posts by samc99us
Aurora Builder
United States, MD, Lusby
Joined Nov 2003
Very interesting information. 20 seconds in dead air is pretty significant. Significant enough that I am surprised similar settings weren't achievable before using a timer? Or is it just much faster with the telemetry?
samc99us is offline Find More Posts by samc99us
Old Aug 24, 2012, 04:12 PM
tom43004 is offline
tom43004's Avatar
Joined May 2002
Much faster. You can compress hours of trimming into a 15 minute session. 20 seconds is easy to find if you gain another 10 feet of launch height and optimize your min sink settings even just a little bit.
Old Aug 27, 2012, 02:04 PM
jfinch is offline
Find More Posts by jfinch
hot air rises...
jfinch's Avatar
Pleasant Grove, UT
Joined Jul 2005
I can totally see how that would be beneficial. Optimizing launch is easily and quickly done using the Open-Altimeter (no telemetry) by launching, landing, listening to the beeps, making an adjustment and relaunching over and over. 15-20 min is all it takes to optimize wing settings and climb angles. To be able to see sink rates "live" would be awesome... so why doesn't the 8FG support telemetry
jfinch is offline Find More Posts by jfinch
Old Sep 01, 2012, 06:21 PM
numba is offline
Find More Posts by numba
Fly, tinker, fly, tinker....
numba's Avatar
United States, WA, Snohomish
Joined May 2012
Mac software?
It looks like this question was asked back in 2011 with no responses. Anyone have or know of an altimeter and software combination compatible with Mac OS? I know I can use a Windows emulation or Boot Camp, but I'd rather go native if possible. Thanks.
numba is offline Find More Posts by numba
Old Sep 01, 2012, 08:00 PM
eosglider is offline
Find More Posts by eosglider
Addicted to lift
eosglider's Avatar
United States, FL, Miami
Joined Jul 2010
OpenAltimeter is.
eosglider is offline Find More Posts by eosglider
Old Sep 04, 2012, 10:55 PM
jasonafriedman is offline
Find More Posts by jasonafriedman
F3K all day
Joined Dec 2011
Hey I was wondering how the "how high" would compare to the eagle tree "micro sensor v4" for launch height.
jasonafriedman is offline Find More Posts by jasonafriedman
Old Nov 20, 2012, 02:48 PM
Nathan Schmoekel is offline
Find More Posts by Nathan Schmoekel
ground penetration specialist
Nathan Schmoekel's Avatar
USA, MI, Grand Rapids
Joined Apr 2007
Hey! Here's something new... Altimeter info via bluetooth!
http://www.rcgroups.com/forums/showthread.php?t=1773710
Nathan Schmoekel is offline Find More Posts by Nathan Schmoekel
Old Dec 12, 2012, 01:03 PM
bbbp is online now
a.k.a. Bob Parks
Glendale, AZ
Joined Jun 2008
Please change the openaltimeter link to just www.openaltimeter.org
THe order link is not operational anymore.
Old Dec 21, 2012, 12:14 AM
flydreamrc is offline
Find More Posts by flydreamrc
Joined Oct 2009
FlyDream released Bluettoth model for altimeter (Used for Android system).
http://www.rcgroups.com/forums/showthread.php?t=1786846
flydreamrc is offline Find More Posts by flydreamrc
Question Barometric altimeter giving erroneous readings Carlyle Harper Eagle Tree Systems 6 Feb 02, 2010 12:30 PM
Question Eagletree Airspeed and altimeter on Heli? AeroM'ck'y Eagle Tree Systems 4 Sep 13, 2009 09:17 PM
Sold Ram 3 altimeter shhhhh! Aircraft - Sailplanes (FS/W) 3 Aug 31, 2009 08:48 AM
Wanted Zlog Altimeter or How High Altimeter Bohh33 Aircraft - General - Miscellaneous (FS/W) 1 Feb 11, 2007 09:52 AM
