This thread is privately moderated by Nathan Schmoekel, who may elect to delete unwanted replies.
Old Jan 14, 2010, 09:10 AM
Nathan Schmoekel is offline
Find More Posts by Nathan Schmoekel
ground penetration specialist
Nathan Schmoekel's Avatar
USA, MI, Grand Rapids
Joined Apr 2007
FAQ
Altimeter links
I keep seeing the question........What altimeter should I get? /or/ What altimeter do you use?
A forum wide search of the word Altimeter used to result in no directly informational threads, just random posts here and there which required too much reading.
This thread changed that and aims to make it easier to find information on the subject of altimeters.
Please post links and any personal experiance you may have with altimeters, or related acessories. I will try to keep editing this first post with those links so the info will be easier to find and fumble through. Lets try to limit the conversation and not tangent too far into complex features of data logging systems which contain altimeters, just provide a link and a bit of basic info and or your experiences (good or bad). Thanks
Links: If you find outdated information here please post or PM me so I can update it.
Winged Shadow Systems- How high Altimeter, http://www.wingedshadow.com/products.html
Related Posts- #2, 48 Winged Shadow Systems is no longer in business, but the web site is still up for informational reference.
Soaring Circuts- RAM 3, http://www.soaringcircuits.com/
Related Posts- #3, 28-33
Magellen, http://www.magtechinc.net/index.htm
Related Posts- #9
Zlog, http://www.hexpertsystems.com/zlog/
Related Posts- #5
Eagle Tree Systems, http://www.eagletreesystems.com/inde...&product_id=60
Related Posts- #6-8
LoLo, http://www.lomcovak.cz/lolo/lolo.html
Related Posts- #23
Altimax Altimeter, http://mysite.verizon.net/resrqa3z/airtek/id66.html
Open Altimeter, www.openaltimeter.org
Open Altimeter- RC Groups Thread, http://www.rcgroups.com/forums/showthread.php?t=1342829
Related Posts- #40-46
Other interesting posibilities
Post# 13 - DYI assistance
Post# 22 - Hitec Aurora telemetric GPS system. http://www.hitecrcd.com/products/new...ic-system.html
Post# 25 - Variometer http://www.pitlab.com/skyassistant-variometer.html
Related Threads
http://www.rcgroups.com/forums/showthread.php?t=1612305 This thread addresses altimeter accuracy...a who's who of experts is in on the discussion.
Nathan Schmoekel is offline Find More Posts by Nathan Schmoekel
Last edited by Nathan Schmoekel; Sep 04, 2014 at 05:00 PM. Reason: Updating/adding links
Old Jan 14, 2010, 09:23 AM
ScottLister is offline
Find More Posts by ScottLister
Lebanon, Maine
Joined Nov 2004
I did a mini review of the How High altimeter when I reviewed the arrow pro. You can check it out here: http://www.rcgroups.com/forums/showt...rrow+pro+build
Scott
ScottLister is offline Find More Posts by ScottLister
Old Jan 14, 2010, 09:47 AM
bjue is offline
Find More Posts by bjue
NorCal
Joined Nov 2009
I was just starting to look at these too, looking forward to what others have to say. There's also the Soaring Circuits RAM3 http://www.soaringcircuits.com. It's twice the cost of the how high and I don't think it gives the immediate readout, but it will store 18+ hours of data sampling at the 1 sample/sec, and you can select up to 10 samples/sec. You have to offload the data into a pc, but you get get much more than just your peak altitude, you can get your whole flight or your whole flying day recorded, and graphed and you can determine sink rates and other info.
Brian
bjue is offline Find More Posts by bjue
Last edited by bjue; Jan 14, 2010 at 12:18 PM. Reason: more info on sampling rates
Old Jan 14, 2010, 09:52 AM
Ralph Weaver is offline
Find More Posts by Ralph Weaver
Ralph Weaver's Avatar
Indianapolis, IN USA
Joined Nov 2000
I have:
RAM 3 which works well and is very small. http://www.soaringcircuits.com/
RC Altimeter Basic, a bit larger but includes read out and electric height limiter. http://www.magtechinc.net/RCAltimeter.htm
Zlog, nice also with display. http://www.hexpertsystems.com/zlog/
I also have a SkyTraceGPS http://www.magtechinc.net/SkyTraceGPS.htm
and a SkyAssitant http://www.magtechinc.net/SkyAssistant.htm but these are a bit too big for HL use.
Ralph Weaver is offline Find More Posts by Ralph Weaver
Old Jan 14, 2010, 11:19 AM
Guz is offline
Guz
Find More Posts by Guz
Guz
Gutless wonder
Guz's Avatar
Tempe, AZ
Joined Dec 2005
I can relate some info on the Zlog in DLG's.
I have a MOD4 Zlog, which has a micro USB connector soldered on the board for downloading data. It is a nice system. But it looks like they are no longer offering the MOD4, but have gone back to the MOD3, which requires a separate USB dongle to interface to download data (sold separately).
The thing that I have found for using the Zlog to evaluate DLG launch height, is to change the sampling rate. The unit is set by default to sample once ever second, to slow to find your launch height. By increasing the sampling rate to "100 milliseconds" (0.1 sec) either by the software, or pressing the buttons on the unit, you can evaluate your launch height more accurately.
The unit is nice that you can put it in your plane, start logging, and do a set of launches (~27 min till the memory buffer fills up at 0.1 sec sampling rate), take a break, download the data (a laptop is needed, or a small netbook) and then look at how you did.
One nice feature of the software is that with a press of the button after you download the data, it will correct drift. That is, since the unit works off of barometric pressure, during the course of gathering data the general barometric pressure may either increase or decrease and it will skew the data either up or down. So I generally land the plane on the ground, let it sit for a second or two between launches, so when I have the data loaded on my laptop the "fix drift" will be more accurate.
If I'm not concerned about looking at my launch height but want to see how high I can go in thermals, I will change the sampling rate back to 1 second (~4.5 hours of data in the memory buffer).
If you want to quickly see your maximum height you don't have download the data to your computer. Just stop recording, and press a button and the maximum altitude will be displayed on the LCD screen.
The Zlog does get it's power from the receiver. Now if you don't have an open servo channel on your receiver, not to worry (example: you use a 4 channel Rx). It is a pass through device. That is, you disconnect a servo, plug the Zlog into that channel on your Rx, then plug the servo into the Zlog and the servo functions as normal.
One thing I have found, is DON'T use the Zlog as a pass through for your battery to the Rx. It can't handle the current for some reason (even though the specs says it can) and it cut power in and out randomly. At least mine has this issue, it may have been corrected in newer versions.
The one down side of the Zlog is that is big. It won't fit in some DLG's (the Stobel for example).
I've been having fun lately with my fellow pilots, when we all catch a good thermal and have generally maxed out. I will yell "OK, everyone, take a guess at how high my plane is!" Everyone yells out what they think (example: 5-6 hundred feet). Then after I land I look up what the altimeter says and let everyone know. It's amazing how far off we can be (myself included). So far CptSnoopy has been the most accurate.
Guz is offline Find More Posts by Guz
Old Jan 14, 2010, 11:50 AM
tai626 is offline
Find More Posts by tai626
San Gabriel Valley, CA
Joined Mar 2008
Stand alone altimeter from Eagletree:
http://www.eagletreesystems.com/Stan...standalone.htm
Weight = 4g.
tai626 is offline Find More Posts by tai626
Old Jan 14, 2010, 11:57 AM
tai626 is offline
Joined Mar 2008
This one has the real time read out:
http://www.eagletreesystems.com/Sail...sailplane.html
Yes, it is more complex. and weight more: 28g. The weight is ok. To throw high you need a ballast anyway.
The Hitec Aurora 9 will have the similar feature for later this year.
Tai
Old Jan 14, 2010, 12:15 PM
flyingj is offline
Find More Posts by flyingj
Jeremy D Stott
flyingj's Avatar
Ogden, Utah
Joined Nov 2004
The only issue I didn't like with the Eaglstree 4g is the 4' resolution.
flyingj is offline Find More Posts by flyingj
Old Jan 14, 2010, 12:35 PM
bjue is offline
NorCal
Joined Nov 2009
Originally Posted by Ralph Weaver View Post
I have:
The SkyTrace is a very cool device, see here http://www.bayrc.com/boards/viewtopic.php?t=5026
Also, down toward the bottom of this page http://www.bayrc.com/boards/viewtopi...=4925&start=45
Old Jan 14, 2010, 05:09 PM
bbbp is offline
Find More Posts by bbbp
a.k.a. Bob Parks
Glendale, AZ
Joined Jun 2008
Altimeter Software
I like the RAM3 software, with the start and end markers to determine the time of any single throw. And the Zero Start / End do work well for getting the plots straightened out for printing.
The ZLOG unit fits in my Lighthawk I cargo bay and the readout is nice for seeing in the field your altitude.
On my larger sailplane the SkyTraceGPS is the most fun, 3d KML files shows exactly whre your flight went, overlaying Google Earth photos and terrain! It needs a faster sample rate and I usually lose lock for a couple of seconds in steeper turns.
I had to mount it outside the fuselage (too much carbon). I built a bubble pod from some plastic packing material. Heated it up and stretched it over the unit & plane canopy, and taped it down.
On another aside, I have excellent service on my RAM3 from Randy Brust. I tried to download my battery instead of the Ram3 and fried the cable. It was fixed and returned for the price of postage!
Bob P
bbbp is offline Find More Posts by bbbp
Old Jan 15, 2010, 12:53 AM
Noel Robbins is offline
Find More Posts by Noel Robbins
*Read*Rise*Return*Repeat
Noel Robbins's Avatar
USA, TX, Austin
Joined Nov 2009
Thanks Nathan for starting up this thread. -Noel R.
Noel Robbins is offline Find More Posts by Noel Robbins
Old Jan 15, 2010, 12:09 PM
Joined Apr 2007
Thanks all for contributing. ...And your welcome Noel. (His post on the Predator II thread inspired me to start typing).
I know there can't be many more altimeters out there besides what has been posted so far, but I'd like to get this thread over 20 (usefull) posts.
The thread links that bjue provided in post #9 are definetly in allignment with the intentions of this thread. Those are the kinds of things people might like to see before they decide to buy one or another brand. Links to reviews and other usefull comentary will also be cataloged into POST#1.
I would like to see more personal accounts from people who are using altimeters. Problems you may have had, features you really like, maybe some of you had one kind and changed to another to solve a personal need?? Stuff like that...
Keep it comming, but also keep it focused....Thanks!!
Nate
Old Jan 15, 2010, 01:42 PM
Stuart B is offline
Find More Posts by Stuart B
AKA RustyKnee
Dorset, UK
Joined Dec 2006
if you want to write your own software to create one (there is a good start for the software already written supplied with it) is this
http://www.ti-estore.com/merchant2/m...30-Chronos-915 although even with the ineternals only, might be too big for dlg.
I have one I want to play with (when I pull my thumb out)
Stu
Stuart B is offline Find More Posts by Stuart B
Old Jun 05, 2010, 05:13 PM
frostyspeed is offline
Find More Posts by frostyspeed
No motor? No problem!
frostyspeed's Avatar
Monterey, California
Joined May 2010
Weight = 4g.
Do you just plug this into your rx? Is there a way to download to a pc or does it only show you peak alt?
frostyspeed is offline Find More Posts by frostyspeed
Old Jun 05, 2010, 06:18 PM
Joined Apr 2007
My understanding is that the Eagle Tree stand alone unit only gives the peak readings unless they are also attatched (in flight) to the E-logger. In other words the stand alone altimiter by itself has no way to memorize all flight data, just the peak.
For DLG the unit is only usefull for launch height data, provided you are launching and then landing without catching a better ride....
If you are looking to record full flight data the Ram-3, Magelan, and Z-Log are the choices. Check to be sure, but I think most of those also give some indication of peak altitude with out a PC.
Question Barometric altimeter giving erroneous readings Carlyle Harper Eagle Tree Systems 6 Feb 02, 2010 12:30 PM
Question Eagletree Airspeed and altimeter on Heli? AeroM'ck'y Eagle Tree Systems 4 Sep 13, 2009 09:17 PM
Sold Ram 3 altimeter shhhhh! Aircraft - Sailplanes (FS/W) 3 Aug 31, 2009 08:48 AM
Wanted Zlog Altimeter or How High Altimeter Bohh33 Aircraft - General - Miscellaneous (FS/W) 1 Feb 11, 2007 09:52 AM
