Old May 14, 2003, 03:01 AM
OldSchool
OldSchool
Guest
n/a Posts
Do you really need less nitro if you run with a tuned pipe?
I remember reading somewhere that tuned pipes are designed to run on
low or no-nitro fuels. If this is true, it could be a money saver.
Has anyone else heard this? Found this to be accurate?
Thanks!
Old May 15, 2003, 03:01 AM
Beav
Beav
Guest
n/a Posts
Re: Do you really need less nitro if you run with a tuned pipe?
"OldSchool" <OldSchool@here.com> wrote in message
news:dbu2cv4aq46pv7upes6dtqu59b5pv1fvs0@4ax.com...
It's a bit arse about face, the pipes aren't designed to run with (or
without) a specific type of fuel, but a specific type of ENGINE.
Engines in Europe have historically been high compression engines which
don't need nitro (and in fact don't LIKE nitro) but they DO need a tuned
pipe if power is high on the list of "must have's".
Japanes engines are usually LOW compression engines, designed to run on high
nitro content fuel (compared to European/FAI fuels) but they still benefit
from the use of a tuned pipe. They benefit more from the pipes with some
internal mods though (like raising compression ratios slightly) so it's not
always a case of "fit a pipe and sit back to watch the fireworks"
Best combination going is the Rossi 60, a Rossi pipe and manifold, tuned to
the right length for your helicopter. Piece of piss to use, and cheap as
chips to buy and run.
Beav
Please note my E-mail address is "beavis dot original at ntlworld dot com"
(with the obvious changes)
Beavisland now lives at
www.beavisoriginal.co.uk
Discussion do l really need a gyro jazsop Fuel Heli Talk 11 Jun 25, 2006 07:57 AM
Discussion What do we really need? BACKEMFNRG Life, The Universe, and Politics 18 Feb 09, 2006 12:48 PM
Lost Models... what do we really need? AnthonyRC Aerial Photography 56 Jan 14, 2006 09:05 PM
Will a brushless motor be damaged if you run it with just 2 leads connected Cincy E-Flyer Power Systems 11 Jun 10, 2005 01:14 AM
You do not really need lipo's to start a fire..; WimH Batteries and Chargers 6 Mar 16, 2004 08:03 AM
